01-27-2009, 04:44 PM | #3001 | |
What is everyones suggestion? I want to take out some camber in the rear. |
01-27-2009, 04:50 PM | #3002 | |
Example: 235/40/17 Federal 595 was wider than the 245/40/18 Kumho Ecsta 712 |
01-27-2009, 05:32 PM | #3003 | |
PARTING/SELLING MY COUPE. PM ME. |
01-27-2009, 07:04 PM | #3006 |
Kodiak no longer makes lips. There are a few companies you can go through....look on the VW forums if you want some options. I used a guy on ebay though. The lips aren't cheap though, expect to spend over 1k on them.
Instagram - SJKnoop |
01-27-2009, 09:36 PM | #3007 |
i have 18x10.5 +5 offset wheels with 245/40s on the back of my s13 hatch does anyone know how wide of over fenders i should run to still be flush? oh and i want to run around -1 to -1.5 degrees camber
01-27-2009, 10:18 PM | #3010 |
Do a decent pull or 30mm overs and slip on spacers till flush, but you will need to do just as much work with the overs than with the pull. Soooooo yea.
http://walk2liv.blogspot.com/ |
01-28-2009, 12:05 AM | #3011 | |
and then "OMGGGGGGZZZZZZ" hahaha |
01-28-2009, 01:08 PM | #3013 |
1k+ isnt too bad, kodiak was asking 250 a lip plus shipping, from UK i think so shipping was bucks. I have spoke with few companies here in so cal area to see how much making custom 18 inch barrels and lips would run me. it all ends up being around 1500 or so. Thanks for the info, I may consider keeping them now.
01-28-2009, 11:39 PM | #3017 |
[quote=240lookis;2600377]Finally got my fitment decent. Good enough to show here.
15x8 -30 195/50 on front 195/60 out back ^^^^^^^^^This is what my kids car will look like at 16. its perfect.^^^^^^^^
AERO-K GARAGE |
01-29-2009, 10:27 PM | #3020 | ||
my question to you is, how did you pull those front fenders? i've obviously rolled and pulled my rears and i've rolled my fronts, but i can't think of a legitimate way to pull the fronts. |
01-30-2009, 09:01 AM | #3022 | |
So then I planned on putting the two new 235s up front, then taking the 245s off and putting them on the rear rims....and hoping to take some camber out of the rear since i would be going slightly skinnier....well we messed up a tire when taking one off so I had to put the 2 new ones up front (which rub while the 245s didnt, makes no sense) and then flip the 2 rears because the inside is showing cords and I have no other tires to put on yet...except the 275s which I can't figure out how to fit. So now the front sidewall looks a tiny bit too big, although fills the gap pretty good, and I dont know what size I should buy for the rear. This is so tedious... |
01-30-2009, 09:22 AM | #3023 |
^^ Maybe 5mm difference you were looking at if they were the same tire. Also the knew one had much more tread. Gotta do some math action. A 235/40 is so slightly smaller than a 245/35 its poop on the tip of a chingada.
01-30-2009, 10:44 PM | #3025 |
can i play in this tread....
18x10 -6 off -1.5 camber 18x 12 -7 off -3 camber (need to fix that) 225/35/18 265/35/18 40mm over fenders front 50mm over fenders rear Last edited by Jdm.I.Am; 01-30-2009 at 11:59 PM.. |
01-31-2009, 01:46 AM | #3026 |
you definitly need some neg camber, then it'll look sick!
rightnow it looks like the wheels are a bit too big.. do you have camber arms?
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
