![]() Hello, I have an s13 sr20 block, and I plan on using an s15 head with it. The s13 head has a high port, and the s15 a low port. I was just wondering if I would have to change around my intercooler piping at all to make it work? Or would the throttle body sit at the same spot as before with the low port intake?
Thanks! (I am brand new to the forums, so please forgive me if I'm doing any of this wrong) |
![]() Join Date: Jul 2005
13 and 14/15 is two completely different throttle body positions and angles
so yes new intercooler pipes are needed the 14/15 design is more modern, straight shot, it looks better, its easier to make and fit pipes, just all around more suitable what are you gonna do about the vtc oiling situation though? Isn't that a tricky mess |
My plan was to just delete it, id put on the cam gears from the s13 head and unplug the solenoid to make the top end run like an s13 SR.
Thanks for such a quick reply as well! Last edited by matthew_V12; 03-20-2021 at 11:20 PM.. Reason: typo |
Theres an oil feed hole that must be dealt with. I've never done the two different block/head but I do know if you have a hole that used to contain oil and now it doesn't, the passage still exists and can fill with air or somehow cause oil to go places it should not be. Just be careful how you retro fit
Yeah, I will have to compare with my junk S13 head and deal with the differences. I think it'll be alright as long as I'm careful, I don't want to end up with two junk heads haha.
#6 | |
Also, removing the VTC is a huge step backwards. All modern engines have some time of cam timing. You?ll lose gobs of low end torque.
Oh good to hear. Yeah, it would be nice to keep VTC, but I don't think I could make it work with my S13 block because it doesn't have the oil channels needed for it. I still have to look into it further, but for the moment I'm just planning on taking it out.
#8 | |
next, how do you know the head gasket takes care of it? Was the head gasket designed to "take care of the hole" Or does it just block the hole by coincidence? What makes you so sure that it will seal up properly against 60psi or 80psi? That sounds like a disaster waiting to happen In majority of cases where some oil feed high pressure hole is needing to be blocked off, there is some kind of set screw involved, or permanent, reliable solution. If the head gasket was never designed with the blocking of a specific oil passage in mind it may leak over time. Be careful, do research, don't make assumptions. Is all I am saying "people do it all the time" isn't good enough. Does the head gasket manufacturer say that their gasket can be used like that? |
#9 | |
Tags |
intake manifold, intake plenum, sr20 240 s13 sr20det, sr20 240 s14 sr20det |
