Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Reviews Forum > Businesses
Businesses Review your dealings with commercial entities here. Remember: Fair and objective. Flaming, accusations, and complaints are not allowed. Zilvia is not a grievance forum.
Old 02-13-2020, 08:01 AM   #1
jdmgtom
jdmgtom's Avatar
jdmgtom has made poor choicesjdmgtom has made poor choicesjdmgtom has made poor choicesjdmgtom has made poor choicesjdmgtom has made poor choicesjdmgtom has made poor choices
Arp
Purchased ARP main head stud bolts and their ARP tread chaser and ARP tread sealer which both was recommended in the instructions for my S13 SR20det. I used the thread chaser in each hole, I cleaned each with compressed air, I made sure every bolt went in smoothly, HAND TIGHTEN ONLY. Went in the torque sequence pattern. 30ft. lb went good, then 60ft. lb.. then when i went to 90 like instructed.. bolt hole #7 to the front RT of the motor would not clcik at 90, so I skipped being scared to strip something. so 9/10 was at 90 ft. lb at this point. Went back to #7 bolt at 80 ft. lb, that clicked then to 85 ft lb...it compelely stripped.. had to removed the head that I just installed with the new Apexi HG to remove that head bolt, had the treading from the block on the bolt.... I pretty much need a new block due to ARP screwing me, don't know if this will be repairable. Being so close to completing my build to just be knocked back down...I regret purchasing ARP and honestly should have reused my OE bolts... that's how my experience using ARP went.
_________
IG - g_t0m
jdmgtom is offline   Reply With Quote
Old 02-13-2020, 12:31 PM   #2
S14rebuild
Did u use the appropriate lube with washers n nut heads?
Old 02-13-2020, 12:43 PM   #3
jdmgtom
jdmgtom's Avatar
the washers & nuts and lube that came in the box with with the head studs? Yes.
_________
IG - g_t0m
Old 02-13-2020, 01:57 PM   #4
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
I have too snapped a ARP fastener torqued to their specifications. I was not pleased with their customer service and in all honesty I would go with another brand now. Sorry for your setback.
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 02-13-2020, 02:09 PM   #5
S14rebuild
Dam, well sorry for the set back...
Ive installed arp headstuds on rb's sr's and ka's atleast 25 sets, never once had on break and how u describe uve installed them ive done the same.... maybe sumone eles can chime in on an issue here
Last set i did was for my sr and i remeber checkn like 7 times the final torque spec of 90fts and found everything from 90 to 80 to 65fts
I elected to go with 80fts and never once had issuses(apexi hg)
And yes the arp paper says 90fts that i did confirm...
Old 02-13-2020, 04:49 PM   #6
TheRealSy90
TheRealSy90's Avatar
You were tightening the nut and not the stud, right? Just checking.
I've also installed ARP head studs at 90 and it didn't pull the threads out. I didn't even chase them beforehand.
Such a good signature.
Old 02-13-2020, 06:22 PM   #7
S14rebuild
Well thats the issue, the stud was turning and not the nut. The clamping force is on the nut..so idk bout blaming arp for this
.the hardware they supplied didnt fail...
Old 02-13-2020, 06:23 PM   #8
S14rebuild
He didnt snap the stud, he PULLED the threads out of the block.....
Old 02-13-2020, 07:42 PM   #9
afishysilvia
Trader Rating: (31)
Yea I saw that I was merely saying how I was disappointed in the quality. I mean metal is metal...there is no saying it’s a one off event. I haven’t had any issues with the other hardware but it did bother me as they’re one of the most prestigious names in the business.
Old 02-13-2020, 07:45 PM   #10
S14rebuild
Gotcha! Always seen arp as top quality but like anything its near impossible to runn 100%
Old 02-14-2020, 09:14 AM   #11
jdmgtom
jdmgtom's Avatar
I should have left it at 80ft.lb... shoulda coulda woulda... I went with ARP due to their big name.. I only wanted the best for my car. Time to take her off the road... need to buy a new reliable car to daily...will have to pull the motor, the cost of a timesert kit is about the same cost of a used block or longblock... minor set back for major comeback.
_________
IG - g_t0m
Old 02-14-2020, 09:46 AM   #12
S14rebuild
Yea, but 80lbs isnt gonna solve the issue, it seems like sum how the stud was turning as u were tighting the nut. Thats how it pulled the threads out the block. The studs are installed hand tight n dont move after that.
Old 02-14-2020, 01:01 PM   #13
TheRealSy90
I mean, even if the stud doesn't turn it can still pull the threads up out of the block.
Doesn't Mazworx have their own proprietary head stud kit (also made by ARP) that's supposed to be the correct fix against this issue?
Old 02-14-2020, 02:19 PM   #14
S14rebuild
^if so then how would that be an issuse with arp studs, and not the threads of the block?
Old 02-20-2020, 08:07 AM   #15
jedi03
get a quick-sert/time-sert kit and you will be good to go...that's rough and frustrating...
Old 02-20-2020, 08:20 AM   #16
jdmgtom
jdmgtom's Avatar
I bought a Time-sert kit Part #2200 for $480 for anybody that may be dealing with similar issue. Kit is made for Toyota/Scion but its a M11 X 1.5 kit and comes with ten 30mm inserts. Should work, will find out.
_________
IG - g_t0m
Old 02-21-2020, 07:41 AM   #17
jdmgtom
jdmgtom's Avatar
https://imgur.com/Z3pZXXv
Time-sert came in and I'm torqued to spec. For anybody in the future, This Kit part #2200 will work for sr20det. Thank you
_________
IG - g_t0m
Old 02-21-2020, 09:01 AM   #18
TheRealSy90
How do you get the shavings up out of the block after drilling and tapping?
Old 02-21-2020, 09:28 AM   #19
afishysilvia
Trader Rating: (31)
Shopvac? Compressed air? Your mouth? Come on lol...
Old 02-21-2020, 12:41 PM   #20
jdmgtom
jdmgtom's Avatar
I rented an air compressor from Home Depot for four hours for $18, taped everything off. Used brake cleaner and compressed air to clean the newly tapped hole from all shavings and WD40/oil residue. A shop vac would be the best option because I blew the shavings EVERYWHERE in my garage. Make sure you wear safety glasses.
_________
IG - g_t0m
Old 03-10-2020, 07:48 AM   #21
jedi03
also iirc, I was close and got scared too so I called ARP and their printed instructions were incorrect...don't quote me but call them to double check...
Old 03-11-2020, 09:22 AM   #22
TheRealSy90
I was thinking in regards to doing studs with the engine in the car.
