07-20-2019, 04:16 PM | #1 |
Z32 Maf issues sr20det
New working on cars ended up buying a sr20det s13 anyways. Been working on this car for the past 4 weeks and the last thing is the maf. Ecu is reading code 12. Decided to change the maf to an isr z32 maf and the car dies immediately. The maf before was also a z32 but using the old on the car stays on, idles but only could rev up to maybe 2500 rpms. Not sure if all I need is a tune. Any help would be appreciated thank you.
07-20-2019, 04:20 PM | #2 |
Here's a video of using the new isr maf
https://youtu.be/xon1PQl9ftA This is how it ran before the change https://youtu.be/TglbWysbMFY |
07-20-2019, 05:40 PM | #3 |
Could be that wiring is slightly different. Check the signal wire and 12v matches the new MAF.
Z32 with lq4 swap Desert Street Scene || Dssevents.com |
07-21-2019, 10:12 PM | #6 |
07-22-2019, 01:14 PM | #8 |
Not sure car came with it only numbers that are on it is 1504 but here's the differences between the old and new one
https://ibb.co/cNkzbcW https://ibb.co/yPD6gFt https://ibb.co/v470h5G https://m.imgur.com/gallery/IK1tN2x |
07-22-2019, 03:08 PM | #9 | |
Trader Rating: (130)
Feedback Score: 130 reviews
https://ibb.co/v470h5G ummmmm the one on the left only has 4 prongs the one on the right has 5 this concerns me. |
07-23-2019, 12:34 AM | #10 | |
07-28-2019, 03:39 AM | #14 |
So far I've tried 3 different mafs two isr mafs and one oem all do the same but the on I had on the car when I purchased it. That's the one that keeps the car idling fine but doesnt rev passed 2500
07-28-2019, 12:42 PM | #15 |
Mmmmmmmmaybe you should check your wiring instead?
08-05-2019, 03:54 PM | #18 |
So consider with the new maf plugged in, are there any leaks ? If it’s reading the maf but had a bad vacuum leak it will run like poo
08-21-2019, 10:34 AM | #20 |
http://www.sr20forum.com/240sx/12922...af-sensor.html or this one if pictures help better!
