06-18-2018, 05:28 PM | #91 | |
You know when you order things, and then totally forget about them till they arrive in the post?
Yeah that happened with me and these differential bushing kit... I was planning to freshen up the rear, and order a 2 way so I thought that I might as well get this if I'm dropping the rear. I was looking at Serialnine bits but they changed their pricing policy to American funds while still shipping out of Canada. After speaking to a few Aussies, I was put on to a guy who mills them (for a third of the price) so I figured why the heck not! I've booked an alignment and I still need to find the time to get the fenders rolled as I'm rubbing at the moment. I'm starting to get excited about this thing again as it's starting to come together, and the parts pile is starting to get smaller (I swear). Quote:
No I'm currently running the stock setup for the RCA. I'm still researching the various things I could do and run for the front. I think I might just get a full angle kit and call it a day. I'm just the worst at this HAHA! I'm going to take proper pictures, once I can finally catch up with the things I need to do to it. I'm going to go a little bit lower. I am already having a fun time driving around with the stock bumper height as is, and my kit is much lower. |
06-19-2018, 01:15 PM | #93 | |
If you had the little fender liners(There will be holes on the inner fender lip), it's a PITA to roll without getting little dents in those areas. Are you gonna pull the rear subframe to do the bushings? If you do, I need a favor.
06-19-2018, 04:51 PM | #94 | |
For their adjustable rear lower arm for the IS300 (JZX110) I'd agree and realize that. For their other arms, I don't believe that it's the case. I bought these when they first dropped and had to wait as they were still manufacturing them in house. I don't know if its the same for the S Chassis items as well.
Megan Racing currently doesn't produce rear (or front) suspension bits for my current chassis. I know that they do make engine and transmission mounts, and some other smaller bits. Quote:
As to the bushings, if I get the time I plan to do it myself (with help). If I'm pressed for time, I'll just take it to a local trusted shop and have them install everything. Let me know what you need, and I can see if I can help you out. |
07-02-2018, 03:15 PM | #95 |
Alright so my care package from Driftmotion has arrived. I had ordered a bunch of refresh items (Cam seals, valve gasket set, exhaust gaskets, etc) and main item, the Tomei elbow...
I also have been spending time on Up Garage and YAJ (I really shouldn't) and found a HPI turbo manifold on the cheap. So cheap that I couldn't pass on it, so the email was sent to Streeter and it's on it's way! Also had him order up a J-pipe delete kit from HPI so those two items should leave around the same time (fingers crossed). Since I'm sticking with a bottom mount setup, I'll be looking for a CT15B replacement as mine is getting rather tired, and up there in KM's. Checking to see what the turnaround time would be for rebuilding the stock one with larger steel internals (or billet). And speaking of Streeter, the gauges have arrived as well... I have no clue as to where I'm going to mount all of these so I'll be looking to see where other owners have placed them. I was toying with the idea of cutting into the dash, and installing them above the glove box... But Damon says otherwise HAHA! I also managed to take this thing in for an alignment... Good times Now that it's sorted, I will get the fenders rolled, and lower it a bit more. Other then that, I've been driving this thing around, and enjoying it! |
07-04-2018, 06:16 PM | #97 |
Minor update... Managed to get my fenders rolled so there's no more rubbing. I managed to blow out a fender but he repaired it without making it look like crispy bacon... Big shout out to Ontario Fender Roll for the speedy service on a long weekend.
Yeah, and I'm okay with that. I'm going to drive it around and see if I'd like to dial out some of that rear camber. In all honesty, I won't know that till I test fit that kit again. |
10-10-2018, 01:25 PM | #99 |
no its not. they make their stuff in Russia (although they may source some of their matl's from megan). their arms just look like rebranded megan stuff + painted that pink/purple color.
they use poly bushings for the 'soft' side of their arms while megan uses pillowball bushings (lexus/Toyota rear end stuff). the rear lowers like the same, but you can see the difference in the patterns/pickup points;furthermoree the FUCA uses the same sliding design to adjust the ball joint, but the way the hardware clamps the sliding balljoint is flipped between the two. there are also minor variances in the balljoint shape between the two. I have their FUCA for my IS and its okay, nothing special. will eventually replace with S9. |
10-11-2018, 07:29 PM | #100 |
Man what a good thread! I went through a similar process of parts ordering when I built my 1jz 350z. Love the simplicity of it all and the vskf’s Look rad! Also super excited to see the BH sticker on the right light haha
10-13-2018, 11:44 AM | #104 | |||
Plenty my man... I guess I've been slacking so I got you!
Thanks my man! I'm starting to get excited about it myself. Ordering parts is fun, but the pile is starting to get a little overwhelming Oh and BH ALL THE WORLD Quote:
I've set myself a goal of making this thing cool, making the panic attack parts pile small, and seeing everyone at the next Final Bout. I'mma die trying You can't be out here making it seem like this thing leaves my garage HAHA I'm totally saving this GIF Famous last words from me... |
10-13-2018, 12:08 PM | #105 |
Alright it's time for an update...
So it's been some time and things have been arriving, and I've been searching for other items I need in order to get to my goals. Shout out yet again to Streeter... My HPI J-Pipe delete kit, and HPI version 1 manifold arrived... I'm rather happy with the purchases and I can almost button up the hot side of this thing... Last on the list? A damn turbo! I had one lined up, but the deal fell through unfortunately. I'm on the hunt for a CT15B replacement since I'm sticking with the bottom mount setup. Billet or Steel larger internals and I'll up the boost a bit to party. I could do Tomei or rebuild the stock one. I'm not looking to shoot to the HP stars, so I'm still researching. I'm leaning towards having the stocker rebuild. I also need to get a new clutch, and I'm currently speaking to Driftmotion to see what they recommend. I want to keep a street feel, so I'm not looking to purchase a heavy, chatty clutch. I want it to feel like a single stage, take weekend track abuse, and hold 400 HP. I also ordered a few engine bay tune mods. Should look nice once everything is together. I'm also on the hunt for valve covers. I want to refinish them in my little ones favourite colours so I've been keeping an eye on YAJ and various Facebook groups I'm a part of. It's now boost season, so we are counting down the days still it's storage time... Come back warm weather... |
10-15-2018, 05:22 PM | #107 | |
I've got a line on something, and I might be on to quite the come up! |
10-28-2018, 08:44 AM | #108 |
Alright, so it's time for a update since its cold and raining outside.
Last week was the last drift event of the season from a good group of guys running a new series in our province. The series is called Drift Jam, and it's EXACTLY what I love. Cool cars, great people, and good vibes all around. The track is actually a go kart track and is tight and technical. It really made me envious of all of the drivers. It was a two day event, and I went up with AreOhWhy (Same one whom helps me out a TON)... He decided to dress up his car for the "spooky vibes" There were a few out of town peeps who you all might recognize... And people were throwing it down all day long... Hanging out, being around great people really got me excited to get cracking on my own car. I really want to make it out to an event next year... I REALLY hope that I get to drive this track in my own car next season... Everyone I spoke to had a blast, and I hope that the series continues to grow. This was just the added motivation I need to get things done... Hopefully the winter is mild so that when Roy (AreOhWhy) and I get cracking, I'm not totally hating life HAHA I'm riding this excitement wave, and trying to get remaining parts lined up. I've decided on a clutch finally. I'm keeping the HP under 400 so I don't need (nor want) something aggressive. From what I was told I can get away with single plate. I'm also going to order up the rest of the gaskets I need from Driftmotion while I'm at it. I'm still on the hunt for a rear differential... I've got time to see if I can scoop up one cheaper on YAJ before giving up and telling Streeter to get me a two way from Tomei or Kaaz. I've also spoken to the person who I want to have paint my kit and she said she should be ready for me in the new year.... AWESOME! Having a once over on my car I'm going to have her fix up a few things on the fenders as well. While going over my car, I realized that I need new corner lights, and I'm thinking about a roof wing... |
10-29-2018, 07:02 AM | #110 |
Drive the car as is and upgrade when needed. Its how you learn what the car needs ect.
Hoping to see this out at one of our events next year
-Jordie Lewis '93 Skyline Type M |
10-30-2018, 07:18 PM | #112 | |
I have been, and keep track of things that need attention and things that I'd like to change. After a few streeting sessions, I've noticed that there's things I'd like to address now, rather then being on the sidelines at the track because something broke.
My rear subframe needs some love, including the rear diff bushing so I'm going to address that as well. Once I'm happy with having a nice "base" to start with, I believe it will in turn will last with whatever I decide to throw at it. I'll take a look my man, thanks for the heads up! |
11-21-2018, 07:33 PM | #113 |
I figured I was due for an update, so here's where I'm at...
I've been looking for a new turbo. I want to keep it CT15 as I'm sticking with a bottom mount setup. I'm not looking to push the envelope, or get silly with wanting a wack load of power. I'm not going down that rabbit hole. Anyways, I've mentioned that I had a deal lined up with a local for a rebuilt turbo, but he ended up selling it, along with his car. After I got the funds back I've been looking for a deal, and or trying to figure out who can rebuild one for me. We've been in this situation... you should be in bed sleeping, but you're cruising through YAJ. You're telling yourself, just a few more pages then you'll hit the sack. That's what I was telling myself till I stumbled onto this.... Nice! I told myself... after doing a little digging and terrible translating I think I came up on something rather nice, for a third of the price. As I understand it, the seller had sold his car after attending a few events, and reverted a lot of items back to stock. He said there's 1500 Km's on this thing (I'm not fussed if theres more really). He hit 380HP at one bar (14PSI) with a similar setup to what I'm planning to run. He had a few other items listed, but this one was the one I had to have... So I hit up Streeter, and kept my fingers crossed that I wouldn't be out bid. Turns out, that luck was on my side and I scored this for an AMAZING deal! I'm still super happy and feel rather lucky. Since it's a used turbo, I needed lines, hoses, and gaskets... Quick stop on eBay and... Now that the hot side is sorted, I need to further into a clutch. After doing some further research, I think I'm going to spend the added dollars, get something Japanese (OS Giken or ORC). I still want a single, and from what I've read it should be enough for my setup and plans on driving this thing. |
12-17-2018, 10:29 PM | #114 |
Alright so I've got more updates...
A rather heavy care package arrived from Streeter... It would have arrived sooner, but there was a postal strike in Canada and it's delayed EVERYTHING! Thank God I completed my holiday shopping early. Everything looks great, and in all honesty, it looks barely used. So now the hot side of things is complete! With the added power I'm looking to upgrade the clutch. I was looking at a few options... Something from Driftmotion (Action)... After really thinking about it I decided to spec something out from a Japanese brand. I was looking at the ORC 409D (and 559D if I could swing it price wise). I also had the OS Giken TR-2CD on the list. I was advised to look at a twin disc for more "future proofing" but I think that would be kinda overkill for the power levels I'm planning to run. And as you'd have it, like usual... I'm on Up Garage when I should be fast asleep and... Found this Exedy Hyper single... It's new, and $600 less then what it usually is priced out for... I had to act fast, and luckily I did as there was another one that was snapped up in the wait time that was a bit less (new but no box). Streeter again is the plug, and it should arrive in 6-8 weeks... Oh and so that this isn't just a parts that are arriving post, I installed this... I've got some ideas for some exterior bits I'd like to pick up and have painted while having the kit painted so I'm going to check what the quality and availability is looking on them... I won't be able to really get cracking on this thing till the new year as it's the holiday season, and I'm heading to NYC for new years. That being said, I've got help and the drive so lets see how far I can take this before I want to light it all up in flames |
12-27-2018, 10:01 PM | #117 | |
Same here! Turn up the boost and make a bit more jelly. I've read that the boost controller kit for the Power FC is a bit meh, but I need to speak to the tuner more about it. Worst case, I'll just have to get something else to manage boost settings. |
01-01-2019, 12:15 AM | #118 |
Exedy Hyper single is a great clutch. Have one on my 1jz VVTi and R154 with similar turbo and upgraded valve springs and it holds well, smooth engagement, and no sore leg
01-19-2019, 08:41 AM | #119 | |
That being said, lets catch up a bit while the snow is falling outside. The new clutch arrived, and... BRAND NEW for the LOW! Man I'm hyped about it. I always tell people that there's still deals to be had on Up Garage or YAJ. Also big shout out to Jesse for the quick turnaround. I was able to snap it up before anyone else could get on it. And while I'm at it, I'm planning to pick up some added bits for the install. New flywheel bolts, clutch release bearing, and clutch release hub. I've got a line in over at Driftmotion, but I'm waiting a little bit since the exchange rate is meh, and I just got back from NYC for New Years vacation. Since I'm making a big push to get this thing out there for the upcoming season, I've been asking people for help, advice, and any leads to get things done. It's actually been working out quite well to be honest. I have a new person who can get my kit painted thanks to my man Mike (cool S15, Check him at FBG). So that means once the weather gets a bit nicer outside, AreOhWhy (when he finds the time) can get to trimming and fitting this thing! I also want to style up the exterior a bit so I'm pricing out a few fun bits. I'll just have to suck up the terrible exchange costs to having something cool Once I get those quotes back, I'm most likely going to go a head with it and have them here in time for test fitting things, and taking a look at if the image I have in my mind can happen... I'm getting super excited people! |
11-29-2019, 03:13 PM | #120 |
Alright, so an update is LONG overdue... once I have some time to sit down and really get into things...
I’m the spring, I decided to stop being lazy and get my things in order. Made the parts pile a little smaller... |
