#3781 |
https://www.instagram.com/200sx_type_x/ |
#3782 |
New engine setup Ive been working on for a while. Greddy Trust mid mount setup using original manifold and td06 20gL2 turbo. Matched with radium top feed fuel rail and evolved injection 850cc injectors with staggered tomei cams. All fab work has been done by Garage Autohero. We are just switching out the Power FC for a Link ecu then it will be tuned up and ready to go!
@pwrmves14 |
#3785 |
Damn, what crappy mount kit was used? All of the other LSXs here have the intake sitting an inch below the pinch seam on the fire wall.
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#3786 | |
![]() Join Date: Jun 2012
So I did some research and learned something new. The FAST 102 intake mani sits a little over an inch higher than the stock intake. That's why my LS appears to sit higher than most. What can you do? Still lower than a Holley. At least my hood actually closes. |
#3788 | |
Curious to see what this makes. I had a similar cam setup and a similar turbo before and it was meh. Just dyno’d the new setup and it’s amazing though. Post up some updates when you get it run in! Pics of my bay per rules. Super dirty but I made a new intake and swapped turbos since the last time I posted I think. Also, the headlight/cooling covers were just in for test fit. Going to powder them this week. ![]()
IG:@DustinClement |
#3789 | |
![]() Join Date: Mar 2009
#3791 |
![]() Join Date: Nov 2006
engine bay is still a cluttered mess but slowly working on things to clean it up. I've had this cooling panel laying around for years & finally decided to put it on the car.
#3793 |
Should soon, I only have a base/cruising tune for now. I need to install my new fuel system this week so I can switch over the e85 for final tuning.
#3794 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
Finally finished up my bay for the most part. Still need to add a lower heat shield for the brake lines. I can't wait until the stainless headers start to change colors.
#3796 |
Looks good!
You should tap the bleeder screw hole and put a fitting on it for your swirl pot. Works a lot better than the port on the side, cause the bubbles tend to rise up |
#3797 | |
![]() Join Date: Jun 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
#3798 | ||
Trader Rating: (25)
![]() Standalone? No, that just the crank case breather. Yeah I plan on changing some things up this winter, I may add something like that while I'm in there.
#3799 |
That's unmeasured air being sucked in if you have the other end of your pcv hooked up. Hence the standalone question.
Tuners are big bullies ![]() |
#3800 | |
![]() Join Date: Feb 2007
EDIT: NVM just realized the plugs are angled that way on a KA.
![]() ![]() Friends help you move. Real friends help you move bodies. |
#3801 |
![]() Join Date: Nov 2005
#3808 |
![]() Join Date: Jul 2005
Ah heck I cant resist, this is current progress photo (about 1.5 year and 16,000 miles on it so far)
![]() Still alot to do but for now she pretends to be a reliable daily |
#3810 |
Its a special breed called St. Easterbunnysday parade
also I know you like sr20, and fwiw I would prefer sr20 myself. Problem is 1 sr20 costs as much as 5x of those 5L monsters. Had to take a step back and rethink how to drive a fast car for basically free these days, feel my pain |
Tags |
battery relocate |
