#61 |
![]() Join Date: Aug 2015
and now for the rb25 hatch!!!!
fully built motor Parts list Bottom end Parts and Machine work (eagle rods, cp Pistons) N1 Oil pump Extended collar Billet gears Ross Tuffbond Harmonic Balancer Haltech + aux harness + e85 flex fuel sensor Omni 4 bar map sensor Pumpgas 93 and e85 tune 500whp/624whp Headstuds Five-O 1600cc injectors Tomei poncams Oil cooler setup Trans+Spec Stage 3 6puck clutch with 1500 miles on it Steel Driveshaft for rb25 s13 Freddy Intake manifold powder coated with fuel rail Intercooler and piping kit Cxracing manifold modified to work properly modified BW s366 .82 t3 hotside freshly rebuilt Turbosmart Hypergate 45mm with dump pipe 3" Downpipe with 2 bungs Oil Feed and return setup Wiring specialties injector harness wired for Five-O injectors r33 subframe with engine+tranny mounts Boost gauge Oil Pressure Oil Temp Wideband Walbro 450 E85 compatible MSD Voltage Booster ![]() ![]() ![]() |
#68 |
#69 |
little update!!! more parts on the way soon too!!!!
nismo cluster and smokeless ashtray showed up!!!! ![]() ![]() yes thats 805 kilometers, it will be adjusted to my current and led swapped ![]() smokeless ashtray, aka coin holder lol ![]() ![]() |
#70 |
big update!!
hatch is completely torn apart!!!! everything is out!!! time to pull the rb25 from the silvia ![]() haltech!! ![]() Haltech plug and play with aux harness for the clutch switch, map and iat sensors ![]() full -8an feed line! ![]() oil filter relocation and cooler ![]() fuel pump set up for an feed, walbro 450 ![]() and shes out! ![]() ![]() and the dead pedal showed up for the Silvia!!!!!! ![]() |
#71 |
well the silvia is parked for the year i guess!!
![]() ![]() waiting on my roommate to help me remove the hood, then pull the engine ![]() test fit the new cold side pipe, in the other car it went wide and removed the washer bottle, i kept it nice and tight against the frame rail and kept my washer bottle!! ![]() and shes out!! ![]() ![]() picked up some really clean stock taillights, bye bye 50/50's ![]() |
#72 |
well the 240 hatch is gone!!! and so is my gold rb25!!!!! kept the things i needed from the black car, sold things i didnt need anymore, my tomei elbow and mckinney downpipe were sold today, as well as the borg warner s366 is gone! precision 6262 should be here monday or tuesday!!!! next is id1000's and tomei valve springs!!
kept the skyline crossmemember and i picked up a set of fortune auto 500 coilovers with swift spring upgrade! ![]() ![]() |
#73 |
Well it's been a long time!!!! But a lot of parts have been ordered, sold a lot of stuff from built swap to replace it with much better parts, injectors, turbo, haltech, fuel rail and some other sold. Picked up a linkecu G4+, id1050x, radium fuel rail, and adapters, picked up a 12-1 cam trigger set up.
Got the rb26 covers test fitted, gotta do some final filing/smoothing of the vct hole. Gotta send a bunch of stuff to the powdercoater, once everything is back and the weather gets a littler warmer I'll be starting to throw it all back together!! |
#74 |
![]() Join Date: Mar 2016
Awesome build thread Cory, I had messaged you a few weeks ago on ig asking if you had a build thread on here... Fantastic work so far!
Hope to see some more updates in the future ![]()
(づ。◕‿‿◕。)づ T E A M B L O O M |
