#123 | |
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() Feedback Score: 13 reviews
That is ebay rubber lip. I wouldn't recommend it if you are using it for high speed as it will deform under high speeds. ![]() Just picked up the head.. got busy weekend ahead. |
#124 |
Love the build
Thought you may want to look into this https://www.rhdjapan.com/jun-high-fl...ctric-fan.html |
#125 | |
.................................................. .................................................. ... Almost done with putting the engine back in. some wiring to do for the new injectors/ rearrange intercooler pipe, etc. Next event is on 5/13 so gotta get moving to finish and have it tuned. will report back! ![]() |
#126 | |
![]() Join Date: Jul 2009
This is what I'm afraid of, finally gonna get a compression test after owning my s14 sr for 4 years ![]()
ig : koukimonst3r |
#127 | |
![]() ![]() completed everything ![]() ![]() went back to Koji for another session; I guess this is what proper dyno numbers look like on 2871r .86. It's hard to see but first set of graphs is high boost (19psi) with hood open (350hp 330hp with hood closed) /low boost (15psi) with hood closed (291hp) Second set of graphs is before the head gasket/ ID injectors / Freddy manifold (260hp) / after (350hp) All tuned on 91 pump gas To summarize: don't go high compression for turbo unless going e85. ![]() |
#130 |
Cool. I had problems with the Greddy, but on an entirely different turbo lol.
Standard gate does have problems both keeping shut at the higher boost levels and just impeding flow/causing back pressure in general. |
#131 | |
Yeah I'm gonna do a compression test on thursday, track day on the 14th, hopefully the numbers are good. I have a Tomei 7960 with a failed internal, went external turbosmart 40mm and it stopped my boost creep.
ig : koukimonst3r |
#132 | ||
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 5/13/2017 Nissan challenge rd. 4. Engine was running strong w/ egt max at 1350 F, ect max at 209 F, and oil temp max at 210 F. This was probably the first time engine ran this good finally.. of course I had to mess something up. I forgot to tighten the oil cap so it flew off somewhere ![]() ![]() went to test out the camping gear and realized I didn't have blanket lol. slept in the 4runner with the heat on ![]() went out to autozone to buy a stupid oil cap cover. this is the second time I had forgot to tighten that cap.. ![]() New Number for remaining of 2017! ![]() Hapy with the result Best lap time of the day was 1:23:36 which was enough to win the Class 2! ![]() |
#135 | |
Hey Ted! Welcome back to zilvia! hope to see your work on here! If you guys wanna see ted's welds instagram: heliarc_hustler |
#136 |
My compression numbers were 160, 160, 156, 160. Track day went fine except I now have a turbo manifold problem for the 3rd time . Upgrading flange studs to arp and adding locking tabs as well as stover lock nuts. It may also have to do with my cusco engine mounts, chopped the test pipe and added a flex pipe.
What did you use to keep yours together?
ig : koukimonst3r |
#137 | |
The key to all the woes is simply the exhaust to transmission mount bracket. That and a flex in the downpipe is what cured my problem. If you think about it, the turbo is in a constant state of trying to pull away from the manifold (turbo is hanging down off the manifold). Couple that with several thousand heat cycles and vibrations and no matter type of adamantium you use for hardware, the turbo and manifold will inevitably separate. The problem is exacerbated with more power (heat) and track usage (heat cycles). The studs is what the issue is btw, and NOT the mounting/locking hardware. The studs themselves see several thousand heat cycles and end up stretching and contracting hundreds of thousands of times with no cooling being available. Once the studs are compromised, the locking hardware is useless. And this is why I ALWAYS recommend OEM Inconel studs and not any aftermarket bling bling trash. That or the TSE $100 kit from the miata guys (Inconel studs and stage 8 locking hardware). Not sure how many times I have said this to folks lol. a few options 1) weld a bracket to the compressor housing and suspend the turbo/manifold combo off the engine 2) Run the exhaust/transmission bracket with flex section 3) Weld them together. |
#139 |
#141 | |
Cheapest solution is factory hardware + tack welds. or v-band. If you go back few pages, you will see how mine was welded. Thank you! .................................................. .................................................. .................................................. .................................................. ............................................... Put carpet back in to run Global Time Attack Street Class! ![]() looking forward to 6/3/2017 |
#142 |
![]() Join Date: Dec 2014
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
Enjoyed the build so far. If you're interested, there is another time attack league called racefreely (ig: racefreely) that has events at grange motor circuit. The next event is July 22. I've taken my car to the canyons a few times but this is going to be its first (and my first) track shakedown.
Anyways, keep up the good work! Those look like good times and the car looks good, too! |
#144 | ||
.................................................. .................................................. .................................................. .................................................. ....... Entered GTA (Global Time Atttack) rd. 3 @WSIR. Personal best time of 1:32.411. 2nd place in Street class. I will update with in-car footage. ![]() ![]() Images above by Amanda Gift SNAPS Studio If sharing please give photo credit by tags & hashtags. Photo: @snapsstudio #snapsstudio @globaltimeattack #globaltimeattack ![]() ![]() Images above by Matt Viramontes MCV Imagery If sharing please give photo credit by tags & hashtags. Photo: @mcv_imagery #mcvimagery @globaltimeattack #globaltimeattack |
#145 |
water temp peaked out at 225. I'm gonna switch over to nismo thermostat.
I was talking to Koji and he told me that there is alot of timing pulled at that temperature. I don't think I should be this much slower than e90 m3.. |
#146 |
![]() Join Date: May 2006
you have any idea if time attack is done in the midwest. so i can get track time.
#148 |
ARP studs, OEM Nissan locking tabs and stover lock nuts held fine! Sayonara turbo manifold problems. Followed you on instagram too!
ig : koukimonst3r |
#150 |
![]() Swapped to nismo thermostat ![]() temp @ around 170 degree F cruising. Hopefully this helps out at the track! Not sure if I can make it to next GTA but will definately go to the next nissanchallenge on 8-20-17! |
