04-05-2016, 07:46 PM | #3781 | ||||
Trader Rating: (58)
Feedback Score: 58 reviews
Dual guides (as answered below) are just simply grinding the one side of the rocker to fit into the guide track. This has been heavily documented on the FWD forums (look up what Miko says) You'll be much happier with JWT S3 or S4 cams, and not buying springs. Quote:
I'd suggest getting 2871r with the 3" inlet / 56 trim. Not that the two bolt is bad, but the 3" is better, and just as easy to work with (if not easier).
04-22-2016, 06:54 PM | #3782 |
Thought id post my dyno results from today.
Was done on a mustang dyno that they guesstimate is roughly 10% off from what a dynojet would have shown. Theyre going to run a car on this dyno and then take it to a dynojet and see what difference it makes. 280hp at 15psi. Stock engine with with .64 2871r, z32 maf, 740cc deatschwerk injectors and an rs enthalpy tune. Dyno tuned by the man himself, Martin [IMG][/IMG] |
04-22-2016, 07:38 PM | #3783 |
I've asked about this before but would like to again based on a discussion I recently had.
I'm using an electronic boost controller, internal WG on a stock SR with the 2871, I reach 15 psi at 4200 RPM. A friend of mine says he hits 20 psi at 3700 psi ( stock SR with poncams) and it's because he did the CodyAce external WG mod. Is this possible? I know an external WG allows for better boost control below 15psi and above 20, but can it really help improve spool that much? |
04-22-2016, 08:30 PM | #3784 | |
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
04-24-2016, 12:19 AM | #3785 | |
I usually log the run 4th gear 2500rpm cruise zero or full vac and full throttle. Logged from the ecu. Thats why I say withing a 1000rpm from whatever rpm I start from.
06-14-2016, 10:28 PM | #3786 |
Hey people, (keeping it gender neutral lol)
I have a built up sr w/ forged internals, bc cams, freddy intake mani, megan exhaust mani... a few others things as well. motor is not in car yet and I still need to acquire some other parts. My question is, I have a reflashed ecu set up for 2871 turbo and 720cc injectors. My goal for the car is around 400 reliable horsepower on a set up I can really beat on. I don't have the turbo or injectors yet and I'm wondering if I should get the 2871 and the 720s and use the ecu I have or just sell the ecu and go with a different turbo and engine manigment system. Of course if I went with a totally new turbo set up it would delay my compleation of the car a bit well I save for the new management. What do some of you think, should I go 2871 on the reflashed or just scrap it? |
06-15-2016, 07:37 AM | #3788 | |
Can you show anything to back up this claim?
06-15-2016, 07:41 AM | #3789 | |
Don't over think this too much. 400hp is not a hp goal that requires over thinking. Only thing I would suggest is going with top feed 1000's. But it's not critical. A simple bolt on T2 20g will get you 400hp also. Won't take very much to get to that hp level.
06-15-2016, 01:48 PM | #3790 |
Thanks for the input. I'm a little bit more concerned about weather I stick with the reflashed ecu or go stand alone but wait a while well I save up for it.
06-15-2016, 02:11 PM | #3791 | |
Stand alone is always going to give you more control but 400hp on a retuned factory Ecu isn't a issue as long as the person doing it knows what they are doing.
06-16-2016, 04:30 PM | #3792 |
Trader Rating: (33)
Feedback Score: 33 reviews
Figured I'd post my results from my recent dyno day. Went with the gt28 style 2871r, with built bottom end and tomei poncams. The results were 331/302 @ 17 psi tuned on an aem v1.
video: |
06-16-2016, 09:00 PM | #3793 |
You've got some Dracula teeth going on there, could be detonation, spark or fuel idk.
Also doesn't look like straight 17psi maybe wastegate or boost controller creeped. if this is a tune run you should have more than 1 dyno done, if its a power pull 350hp should have been closer. iyam I would still try to find out what those dips are. If you're happy it doesn't matter!
06-17-2016, 01:27 PM | #3795 |
I don't want to spoon feed you, but head over to turbobygarrett, compare the turbos wheel size and compressor maps and ratings from garrett and learn yourself some knowledge.
DODOlogic.ca |
06-17-2016, 02:12 PM | #3796 |
You won't spoon feed me a damn thing, I already know the answer. Compressor maps and real world dyno graphs/actual et's are not the same. And you won't show me anything that proves that turbo "blows" the other out of the water.
06-23-2016, 10:47 AM | #3797 | |
Asking me for "proof" is asking me to spoon feed you. you know theres a 35 pg thread on the gtx2867 with users upgrading from a 2871, with #'s and graphs and all the shit you want to be spoon fed. If you used your own fingers to find it you wouldn't even be replying. It's not rocket science to figure out which is better. 2 turbos with nearly identical turbine sides, while one compressor side out flows and is much more efficient than the other. eat your heart out.
DODOlogic.ca |
06-23-2016, 11:26 AM | #3798 | |
LOL. I don't think you know what "blows" away means. I'm seriously not waiting for you to show me anything. Because you won't and I alr day know that. I've been doing this too long and have seen gt vs GTX tests done first hand. And the GTX will simply come on a little quicker. Like I said you won't spoon feed me a damn thing. And I will put money and dyno time on it. Believe that. But you keep believing this 11 blade GTX is some great turbo.
08-17-2016, 09:40 AM | #3799 |
What should I set my rev limiter to? Will be a soft limiter (fuel cut)
S13 SR ~ stock short block AEM v2 GTX28 JW S4 cams Tial 38mm external W.G. 850cc's FMIC 3" exhaust ARP head studs Cosworth HG 92 octane Who wants to guess the HP numbers ??????????????? |
08-17-2016, 04:53 PM | #3801 | |
Throw in dual guides and call it a day. Maybe b15 roller lifters if you feel froggy. |
08-17-2016, 04:57 PM | #3802 | |
Cody have you ever matched the flat shim thickness when doing dual guides? By either machining the guide shims to match the thickness of each flat shim it's replacing. Or you can order Tomei guide shims in different thicknesses even. I've been considering doing this on my own engine just to be sure the lash is super precise. However every dual guide mod I've done on friends/customer sr20's I've always just thrown in the guide shims like usual with no problems. B15 Roller Rocker Lifters are the next thing getting passed onto rwd sr20 owners haha. Used to be my little secret :P |
08-18-2016, 07:46 PM | #3803 |
I am a few weeks off from taking my car down to John Kerr to get tuned. I am super excited to finally get it finished up here in the next few weeks. Just to build the hype for myself what numbers should i be expecting with the following set up?
Red Top GT2871r .64 1000cc Injectors Zeitronix Flex Fuel Kit HKS 256 Cams Nismotronic ECU I have ran the idea to get external wastegate down the road on this set up, would that be worth it on a gt2871? |
10-07-2016, 04:17 PM | #3804 |
I got My redtop tuned last april. This was 15-16 psi with s3 cams and t28 .64 style GT2871r tuned with Nistune.
The power seems low to me, I ended up with only 11 degress of timing through the mid range and climbing to 13-14 degrees up top. |
11-22-2016, 12:57 PM | #3805 |
Update on mine.
Red top Gt2871r .64 1000cc injectors Aeromotive 340 fuel pump HKS 256's Nismotronic Unfortunately my flex fuel sensor went bad so we had to do two different maps. On low boost I made 330 on 93. On e85 we got to about 17psi and made 360/325 when we turned the boost up the clutch spun. Going to be heading back in the spring with a new clutch and flex fuel sensor to max out the boost on e85. Sent from my SM-G900V using Tapatalk |
01-11-2017, 01:05 PM | #3806 |
Unfortunately i have not had the chance to tune or dyno my car since purchasing, and i did no do all the mods myself but i have done a few myself and have more to go before tuning. My set up:
black top sr20 Tomei 256d poncams 2871 turbo fmic 550cc injectors z32 maf upRev 2 custom tune (from years ago from prior, prior owner -_-) Tomei 1.8mm head gasket NA pistons Tomei elbow 6 puck clutch From the butt dyno and comparing to my last 300 hp sr20 s13, i'd say i am making between 340-360 whp at 16 psi on 91 pump gas. I run 100 octane through it every so often, i found it helps out with spool times on my turbo as on 91 it takes until about 3500 to fully spool, where its at about 3200 with 100 octane |
01-29-2018, 12:10 PM | #3807 |
ive just picked up a decent used one of these turbos. I plan on stripping it down to check its all ok and wondered if you guys would recommend porting the wastegate hole in the exhaust housing??, its the smaller .6 that I have and from what I can remember they suffer from creep.
This is a bolt on 'get my car to work' so I can use it whilst I save up for a borgwarner exercise so im not interested in spending money on EWG's or fancy manifolds as I already have the hardware to get it on and running. |
02-18-2018, 04:19 PM | #3808 |
a customer of mine just made 390whp on his 2871R which was a T3 Skyline model *HKS GT-RS bolt on turbo* this was on his SR20DET S13 engine with our Midmount Exhaust Manifold we made for him. Ill try get some dyno charts off him.
04-17-2018, 03:09 PM | #3810 |
No that hole is way too big.... It should be closer to a pin hole size unless you have a fitting on the block that restricts oil.
Turn and Burn! |
