![]() text me at 703-864-8176
kevin. ![]() 1988 Nissan Cefiro A31 URL links at the end. it wont let me upload pictures -____- Location: Northern Virginia Means of contact: PM Price: $17,999 obo Description: Hey guys I'm selling my 1988 Nissan Cefiro that was imported thru Japanese classics llc and is 100% legal. The Cefiro came swapped from japan with an s14 sr20det in Japan but was recently replaced with a 1JZ. The car runs great with no issues what so ever as its my daily driver. The car is running off the stock ecu but does need a tune. A piggy back or some type of EMS will make this car even better. The car does have some rust on the rear fender wells but nothing major for its age. Frame rails are rust free and the paint still shines. The rear seats have been removed to accommodate an alumunium battery box but will be included with the sale. Below is the link from when the car was imported. http://www.japaneseclassicsllc.com/1...urbo-sr20.html Engine: Rebuilt 1JZGTE ARP Head Stud Kit 1JZ/2JZ ARP Main Stud Kit 1JZ/2JZ ARP Rod Bolt Set 1JZ/2JZ ACL 1JZ/2JZ Race Bearing Set 1JZ NPR Standard Size Ring Set 1JZ/2JZ Front Main Seal 1JZ/2JZ Rear Main Seal 1JZ Valve Cover Gasket Set 1JZ-GTE (non-vvti) Exhaust Manifold Gasket Heat Shielding Gasket - BOTH Upper and Lower Gaskets 2JZ-GTE Stock OEM Head Gasket 2JZ-GTE Water Neck Gasket 1JZ timing belt 1JZ Serpentine Belt - No AC Pump Installed. 1JZ/2JZ 90deg PCV Valve 1JZ oil pump 1JZ/2JZ/7M Oil Outlet Adapter Fitting With Crush Washer 1JZ/2JZ Thermostat 1JZ Denso Oxygen Sensor 1JZ TPS sensor AZ Performance Oil Drain Flange for 1JZ/2JZ Oil Pan AZ Performance T Series Turbo Oil Drain Flange -10 Custom engine and trans mount Borg Warner S300 177275 Turbo HKS style Tubro manifold Tial 51mm BOV Tial 46mm EWG with extra springs NGK Iridium IX spark plug 6418 / BKR6EIX K&N 4 inch Universal Filter, Short Version Freed Enginering Custom v band downpipe Freed Enginering Custom midpipe with Greedy axel back Custom engine and trans mount Chase bays fuel lines Walbro 255 Fuel pump Alumunium radiator (came with car from japan) HPS Radiator Hoses - Blue Greddy R34 Intercooler using 2.75" Intercooler Piping AEM Wideband ARC Switch panel 1JZ Cam Seal (NON-VVTi) 1JZ Valve Stem Seal for Exhaust Side 1JZ Valve Stem Seal for Intake Side Transmisson/Suspension/Wheels: Dowel Pin For R154 And W58 Flywheel R154 transmission R154 OEM flywheel Marlin Crawler Shifter Socket R154 Marlin Crawler Urethane Shifter Bushing For R154 Transmission ARP Flywheel bolts 1JZ/2JZ Spec Stage 2+ clutch Custom power steering and clutch line Freed Enginering Custom shifter extension for r154 Freed Enginering Custom driveshaft Nismo Differential Tiens Coilovers "super drift street coils" 5- lug conversion New front wheel hubs Z32 brakes all around with Z32 rear e-brake Tien inner and outer tie rods Custom s14 steering knuckles from japan Konig SSM 18x9 +22 and 18x10 +15 "powder coated dark Chocolate brown" Front tires have about 75% life left Rear tires are brand new Interior: Driver side has a fixed Bride type Bucket seat R32 seat for the passenger side Nardi Steering wheel Tomei Shift knob Nismo shifter "Not short shifter" Xplod CD player Drift "buttion" for ebrake New window motor for driver rear door Alumunium recolator battery box. back seat "will come with back lower seat" Exterior: Car came painted pearl white from japan Full ORIGIN body kit Black Plasti dipped door handles 8K HIDs LED blubs for the corners and lisence plate. 35% tint all around. Pics: ""DEFI Gauges shown in the photos will not be included"" I love this car to death and I hate to sell it but I'm focusing on my career so my loss your gain. Please keep the negative comments to yourself. Thanks for looking! https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ https://www.flickr.com/photos/134354...7653003046833/ Last edited by sileighty2jz; 07-21-2015 at 08:33 AM.. |
Tags |
1jz, car for sale, cefiro, jdm, nissan |
