![]() Join Date: Nov 2005
***NEW***WSRD Brake Line Kit!
![]() Hello everyone! We have completed our brake line kit for the s-chassis. This kit works for S13/Z32/Z31 OEM master cylinders. These lines are teflon-lined -3 stainless braid with another teflon coating over top to protect them from abrasive damage. They route down, under the crossmember, and to each front brake and rear brake line. These even work with the OEM S13 brake line brackets! Installation is quick and easy! These are NOT DOT approved and for racing/off road use only! (Master cylinder not included) Introductory price is $170 shipped! *Please note these kits are made-to-order and have a two week lead time* You can order here: http://www.whalentuned.com/nissan-240sx.html ![]() ![]() ![]() We also have the prototype kit (first picture) for sale! These were used on my daily driver for two weeks and function perfectly, the lines are just a bit too long and they are NOT compatible with brake line brackets. $120 Shipped!
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 11-13-2014 at 06:14 AM.. |
We can very easily make a RHD kit, the line to the rear hardline would be much shorter on a RHD car, the other two lengths would work perfect.
#6 | |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
If you make some for RHD, I might grab a set from you if I decide not to run the BB eliminator kit.
REVIEW |
We have these lines custom made by XRP to our length and end-fitting specs.
We are hampered by our lack of S14 test car :/. If you switch masters, everything will work perfect! RHD sets are easy to make, these are built-to-order so we can make you a set specifically whenever you'd like!
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
OH MAN!!! SOOOOOOOOOOOOOO MUCH WANT HAPPENING RIGHT NOW!
Ill be ordering a set of these after the holidays! Ive been wanting to get rid of my metal hard lines sooooooooo bad! Planning on making a clutch line that runs from the master to the slave? |
Trader Rating: (130)
Awesome. You don't happen to also make a rear z32 caliper on s13 brake line kit, do you?
#11 | |
The clutch line is definitely in the works. Thanks! Not yet, I'm working on getting the standard soft lines replaced all around and then we'll have Z32 conversion lines as well.
These kits are made to order, so whenever you're ready, just order up and we'll make the lines and ship them to you!
#15 |
To conect it to the rear line on the chasis do you just have to cut the rear line and flare it and put a flare nut on? Or how do you go about getting that hooked up?
#17 | |
Yes. These will work with any brake lines designed to work with the OEM hardlines.
Yes, absolutely.
#24 | ||
Thanks!
Sounds good! Price will be the same for RHD kit! Quote:
Yessir! No additional parts needed!
#26 |
