07-10-2014, 03:22 AM | #1 |
beginner drift talk
Let me be clear and state that I am literally just learning the basics and have only just started attempting to get sideways a month ago.
I only have a few questions plain and simple. Let me go ahead and say I have stock springs with kyb struts I find it kind of hard even with my sr to break loose like I see all the guys able to slide out so easily and I have to really kick that clutch to get it to respond. One question is will excessive clutch kicking hurt my car? When I say excessive I mean just when needed and not just mashing on it randomly. One other thing. Coilovers. Do they make you break loose easier? Does have your cars centee of gravity lowered with harder suspension help you easily break loose because I imagine with my setup because of the suspension travel and how light the setup is that, that is also part of the reason its hard for me to break loose. Am I right or wrong? Just looking for some incite from someone who knows these things thank you Also sorry about the messy post im typing from my phone and it's not that easy to make the post look nice |
07-10-2014, 03:29 AM | #2 |
Weld the diff or buy a 2-way, buy an HKS WG actuator and turn up to 11psi, stiffer shock/spring rates will help but you don't need 12k/10k to go skidding.
I also recommend looking up the drift bible.
07-10-2014, 06:05 AM | #3 |
+1 to drift bible. With stock KA I had good luck with a super crude setup of airing my rear tires up to like 60psi (stock 195/60 tires like to roll), turning coilovers to full stiff in the rear, welding diff and most importantly relax. I'm still a noob too but what I've learned is beginner level drifting is pretty easy once you relax and let the car do the work.
First event I was way too controlling and put every input I could into a drift. I started to do much better when I did those settings I mentioned above and just sat back in my seat firmly and used a bit of weight control and plenty of clutch kicks. I started doing 2nd gear (slow), mild scandinavian flicks with a well timed clutch kick to initiate. Keep your head turned in the direction where you want to go and don't be afraid to let go of the wheel to let it spin around countersteering. |
07-10-2014, 09:23 AM | #6 |
My best advice to you, and anyone else thinking of getting into drifting is to read this entire thread. A TON of great info from experienced drivers.
http://jdmchicago.com/forums/showthread.php?t=26215 Also, stick to simplicity. An SR is all you need power wise. Focus on: A quality set of coils, new or used Bucket Seat Steering wheel Welded diff. A working E-brake. No hydro. The more reliable your car is, the more seat time you'll get. Please don't think of an LS, 1/2JZ, or RB swaps. If you do not have the experience/skills, these setups will only hinder your learning. Hopefully this helps! |
07-10-2014, 11:31 AM | #7 |
with an sr getting it to "break loose" should be easy lol
you shouldnt even need to clutch kick, just power over, like floor it and turn at the same time even in my s13, which is totally stock (stock KA, open diff, stock suspension) i can do good donuts/figure 8s and im not even that good of a driver
@tannermwilson |
07-10-2014, 01:03 PM | #8 |
I'm perfectly fine, if you ignore the fact that you're trying to heckle me and read that this guy is complaining about struggling to break loose with an SR then he must be barely breaking 200 hp to the wheels or still needs to learn how to initiate. In my world we call that under-powered.
07-10-2014, 01:13 PM | #9 | |
07-10-2014, 03:47 PM | #10 |
Thanks for the help guys.
And yes I am a total noob to drifting and the most ive ever really done is donuts around a concrete circle that me and some firends go and chill at on saturdays. I live up in Idaho so finding a place to drift even track wise is really tricky. I do have a welded diff also some other mods on my sr are gt2871 apexi neo z32 maf and 550cc injectors. But like I said im new to it and I will definetly try some of the stuff I have read about today thanks |
07-10-2014, 04:21 PM | #14 | |
Another solid piece of advice is let someone who knows what they're doing drive, and observe. Get as much pointers as you can. We've had a couple drift 101 events here in Chicago where experienced drivers ride along with you all day giving you pointers. No spectators so no added pressure, just concentration on driving and improvement. |
07-10-2014, 04:27 PM | #15 | |||
Location: bangin on my chest Account: BANNED #fucksupreme
If you cant break traction in an SR its not because the car is under-powered, its because the driver is inexperienced or the motor is shot. Quote:
Seriously, whats wrong with you idiots... if you need to jack the pressure up to 50psi you should consider just driving on a 185 sized tire. Quote:
C:\> del c:\zilvia\f\users\*.* |
07-10-2014, 05:13 PM | #16 |
Yeah I'm very inexperienced I've said it several times and the title of the post includes "Beginner"
But im all ears for learning and taking advice and this thread so far has been very helpful thank you |
07-10-2014, 05:34 PM | #19 | |
I'm trying to help a forum member, leave the bullshit out man, it's not necessary... All you have done is come into the thread with absolutely no helpful information for this curious beginner. You should just get the fuck out of here. |
07-10-2014, 05:43 PM | #20 | |
Drive faster/ rev higher
Your SR will need time to spool the turbo, which means your powerband will be up top, which means low speed shit sucks Out here, I often find myself upshifting from 2nd-3rd with the s15 sr20det I just put in, which has less power than what you have.
07-10-2014, 05:46 PM | #21 |
Pretty much all of the suggestions are true. When I first started all I did was weld the diff, throw some coils on, and dumped some weight. Was able to get my KA to let me slide on through.
All in all, SEAT TIME!! Good luck. |
07-10-2014, 08:11 PM | #22 |
actually this is a pretty good video for getting an idea of techniques.
https://www.youtube.com/watch?v=dCGyDAj_dYw |
07-10-2014, 08:35 PM | #26 |
about the steering wheel, it really does make a significant difference in steering feel and control in my opinion
also stock steering wheels are really ugly
@tannermwilson |
07-10-2014, 08:39 PM | #27 |
Trader Rating: (29)
Feedback Score: 29 reviews
It sounds to me like you are babying the car. Are your clutch kicks at low rpm? As stated above it is a 4 cylinder turbo car and needs to be driven as such. Get those rpms up. I'm not saying bounce it off limiter, but you gotta give that turbo a chance to spool.
07-10-2014, 10:14 PM | #29 |
All right look man there lots of ways you can do this all right. Handbraking is the easiest so the first thing I want you to do, I want you to rip that E-Brake all right. After you rip that E-Brake then I want you to power over
