09-30-2013, 01:15 PM | #15033 |
Clean the headlight switch if you haven't already, it causes the headlights to fuck up. If that doesn't help and it only happened after you did something wiring related then obviously it has to do with wiring. Check your fuses too but you probably pulled a connection apart or sliced a wire or something. Go over it again, there's not really anything else it could be.
09-30-2013, 07:56 PM | #15036 |
with a tuned ecu for larger injectors, could you theoretically use larger injectors than what the ecu is tuned for and turn down the fuel pressure via adjustable fpr to get the engine to run correctly?
09-30-2013, 08:21 PM | #15037 |
I have a quick question, I need a chassis harness (the imder dash, fuse box, and headlight portion) for my s13 and I found one for sale and I wanna get it before someone else does, but does any one know if it matters if the car the harness is comming from a dual or single cam? My s13 was originally had a dual cam, would it matter if the harness came from a single cam? Are they any different is what I'm asking I guess?
09-30-2013, 09:05 PM | #15038 |
You'd have to define correctly... U could get it close to how if ran before it was but def not perfect. If ur gonna do that just temporarily, like to get it back on the road I'd say ya but get it retuned for your new (bigger) injectors ASAP
10-01-2013, 02:27 AM | #15039 |
Bandwagon.
I thought no matter what injectors you have, the fuel pressure stays at 43.5psi with NO vacuum? ~35ppsi with vac.
10-01-2013, 05:33 AM | #15041 | |
10-01-2013, 12:23 PM | #15042 |
My subframe bushings are pretty shot (from the feel of the ride, hopping wheel/hard shuddering on normal clutch engaugement, general clunking and rattling from the rear end when there should be none, etc) but I'm not really in a position where I can drop the subframe off, or use a press.
Am I properly understanding subframe collars, as something that I could slip above the mounting points without entirely removing the subframe, just leave the driveshaft on and take out the mounting bolts to drop it enough to slip the collar on? Any suggestions for products, or techniques? This is an s13. |
10-01-2013, 01:16 PM | #15043 | |
Loosen the 4 bolts as far as you can, put the tops between bushing and frame rail, bottom between the bushing and the washer. |
10-01-2013, 04:13 PM | #15044 |
10-01-2013, 05:01 PM | #15045 | |
10-01-2013, 05:08 PM | #15046 |
Are the JDM and USDM Kouki front/side bumper retainers the same? I know the bumper support themselves are different, but I cannot find anything about the retainers. Sites like The Nismo Shop don't specify USDM or JDM on their Kouki bumper retainers - so I assume they are the same.
Also are the pieces that connect the bumper to the chassis the same for USDM and JDM? The pieces I am talking about are the white ones in this picture: Thanks!
2006 Holden Monaro - 700+whp ; 2014 Holden Commodore SSV - 400whp Last edited by Boosted92; 10-01-2013 at 06:37 PM.. |
10-01-2013, 05:49 PM | #15047 | |
I just don't currently have the means to do the whole job. STANCE Aluminum Subframe Collar Set For Nissan 240SX - Enjuku Racing Parts, LLC It does say if your rubber is in good condition.... but why? Doesn't it entirely bridge the bushing, and effectively make it solid? As it is, it gets in the way of everyday driving, like pulling out of a stoplight. There's a specific way the throttle and clutch have to interact, or I look like I don't know how to drive standard. So it is a probelm that needs addressing, but I don't have the space, time, or equipment to get bushings out of something as huge and heavy as a subframe. *edit* and if those don't eleminate the bushing movement, are there any that do? It seems like it should be possible to have a collar that effectively makes it totally solid. I've also seen people talk about poly inserts that are not total replacements, and seen aluminium "inserts" that don't look to be as thick as the full bushing, but like bulkier collars without the slip-on gap. I'm up for any combination of things that will let me leave the current bushings in, but get the subframe stiffer than stock. *edit- fuck the normal knockoff brands, how about these: https://technotoytuning.com/nissan/s...ars-nissan-s13 Last edited by mechanicalmoron; 10-02-2013 at 12:14 AM.. |
10-02-2013, 01:16 AM | #15051 |
Trader Rating: (24)
Feedback Score: 24 reviews
Has anyone tried to get their car insured and when they check up on your car and look at the odometer, but you have a JDM cluster. Do they care?
REVIEW |
10-02-2013, 02:37 AM | #15052 |
^Depends if the emissions testing center you go to notices. If it has less miles (assuming they don't notice km on the cluster) than what is on your current title they'll know something is up and give you a mark on your new title indicating the odometer is incorrect (usually box C or something along those lines..don't remember exactly)
10-02-2013, 06:40 AM | #15053 | |
You may want to replace those wires that got heated up. That excessive heat condition more than likely caused insulation breakdown and will find a way to short itself later on, or the wire will break inside the insulation, causing a real bitch of a ghost in the machine to find, and prior knowledge of, oh yeah, that was the wire that got hot will not be available in your brain until you have spent a few days and hours trying to figure out what is wrong
1996 Zenki 'Baraketsu Tenshi', Burst Angel My work in progress... |
10-02-2013, 07:51 AM | #15054 |
anybody use rims with big negative offset to drift with? or is this bad? Because I have a widebody and hate keeping 7 or 8 inch wides on all the time to drift because it's ugly. Wondering if i could get some 8 wides with negative offset to look good drifting?
10-02-2013, 08:28 AM | #15055 |
I have ave 3 s14 USDM ecus. I really just need to know which if any is 97-98 automatic. I can't look at the part number on the last two at the moment but i don't think either part numbers match up with the Jim wolf ecu list either so that's why I'm asking.
1)3c - a18b92g00 I know this is 95 manual 2)j6 ? 3)wm ? |
10-02-2013, 09:22 AM | #15056 | |
10-02-2013, 10:47 AM | #15058 | |
10-02-2013, 10:49 AM | #15059 |
It makes no difference.
Tags |
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
