08-16-2011, 07:38 PM | #61 | ||
What else would you like to know? or would like added?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo |
08-19-2011, 11:00 PM | #62 |
Well here is a link to my completed build of my N/A 2jz and Now inprogress V-Mount 1JZ set-up. I had my N/A motor running in my car since Dec. of 2009 and it has been great never let me down. But I have come to the point of where I am ready for a little more power and a cleaner set-up here is my link I am can try and help when people need it just PM me.
Build Thread http://zilvia.net/f/chat/359644-s13-...upe-build.html
1989 240sx coupe 2jzge swap 1997 t-100 4x4 |
08-29-2011, 07:52 AM | #63 |
Anyone know a place where to get a one piece steel drive shaft?
Also it looks like all the companies for the engine mounts are either out of business (myjzswap), not working (dm-spec), have bad reviews (zerolift, even though i got my 1jz from them and had no problems) or are out of my price range (tech 2). So that leaves me with Turbo Dave, does anyone know anything about these other than the desription? review on mounts/ company? i've never heard of them till now. pictures? |
08-29-2011, 08:06 PM | #64 |
Trader Rating: (41)
Feedback Score: 41 reviews
^ Here ya go. 240SX S13 S14 SWAP ENGINE MOTOR MOUNT BRACKET 1JZ 2JZ | eBay
I've seen people use them before with no issues
"cigarettes killed my father, and raped my mother!" |
08-30-2011, 02:53 PM | #65 |
^ I did see those, I'm just always a little skeptical about ebay parts.
Also emailed the driveshaftshop and they make a once piece steel for the r154 trans and its the same price as a ka/sr drive shat. |
08-30-2011, 04:42 PM | #66 |
^ hey call me at work i can price you on a steel or alum shaft, we do rears, driveshafts, and trans along with other things, i'm going to build mine out of 3in alum with solid joints.
powertrain inc 800 342 1132 ask for chad m-f 8-5 east coast
93 s13 coupe 5 speed- Ls2 swap in the works 97 sc300-gte/v160 |
08-30-2011, 07:55 PM | #67 |
I got mine alum. shaft from shaftmasters.com never had any problems along with 2 other friends of mine.
09-04-2011, 09:39 AM | #70 |
Trader Rating: (42)
Feedback Score: 42 reviews
So instead of spending 500 bucks on a Taiwan vvti manifold I've decided to mod a non vvti for less than half the price. I plan on cutting the non vvti off at the runners a couple inches before the exhaust flange, cutting out a vvti flange and attaching the two.
SW Fab |
09-04-2011, 08:40 PM | #71 |
Trader Rating: (79)
Feedback Score: 79 reviews
This thread is FUCKIN AWESOME! Alot of good ideas for my 1JZ Swap
My Build: The "Coupe De Ville" 1JZ Build!! |
09-04-2011, 10:10 PM | #73 | |
Trader Rating: (79)
but it will probably better to just run a aftermarket Temp Guage IMO....
09-12-2011, 11:07 PM | #76 |
Trader Rating: (79)
We need some more people to give us the secrets on the "How to wire 1JZ/2JZ to 240's"
09-15-2011, 06:26 PM | #77 |
There are no secrets its all in the wiring diagram you have to know how to read that before and then you will know how to do your harness. That shows where you need power switched or constant power everything you need to know.
09-15-2011, 07:10 PM | #78 |
Nice write up. I have a 1j in my 98 240sx and having issues with cooling when i have the AC on. When it heats up im simply turn the AC off and im back to normal. I have dual fans pulling through a mishimoto radiator. The 1j has about 60k miles on it roughly. Stock temp guage as well. Anything I should try? Adding more fans? Last thing i wanna do is vent my hood. Thanks.
09-16-2011, 02:48 AM | #80 |
Trader Rating: (79)
Has anybody tried this Diagram?
09-16-2011, 10:13 AM | #81 |
yea i was thinking of putting one on the condenser. Not sure how much room I have in there though. Should I put it in the front or in the back pulling through to the radiator? Would I have battery problems running 3 or more fans?
09-18-2011, 03:13 PM | #83 | |
09-21-2011, 08:39 PM | #85 |
Checking in to this thread since the other "sites" are down. My car is finally alive after a year of rebuilding Can't fucking wait. Btw flick, your car is fucking siiiiiiiick.
09-22-2011, 02:14 PM | #87 |
Someone correct me if I'm wrong.
The R154 transmission didn't originally come off the 2jz? I see a lot of people swapping the tranny housings with a 1jz housing. Why is that? Then you have to use a 1jz flywheel, but still can use a 2jz clutch kit? |
09-22-2011, 03:02 PM | #88 |
I would love to see someone else that car verify if this would work or not. As there are a few other JZ-S13/S14 cars coming out it would be nice to have diagrams.
Yeah, Pretty shitty what has come of the 2 differant JZ Swap sites. Thanks Deftec. means alot hearing that from someone who has been into JZ-S-Chassis since the beginning it seems. You got your built motor/bigger turbo now? any more info/videos?
09-23-2011, 09:18 PM | #89 |
Nothing really as of recent. The #6 bearing was starting to fail in the engine the last time I took it to the track. Ran a 13.1 @ 107mph. 1.9 60'. So I pulled the motor with just the intention of adding some bearings and throwing it back in, but ended up going overboard.
.020 over pistons 1mm over intake/exhaust valves, springs, retainers 272 cams t78 turbo 100 shot(still awaiting installation) AEM 2 -10an lines to a boost logic rail, 1000cc injectors, AEM pump, fuel cell Kind of went overboard, but it'll be a fun as hell car lol. I don't have video of it running yet, but should have some video/track vids by next weekend if they get it tuned in time. This is the most recent pic I have of it from last month. I'll do a full thread on it once I get the car back. Most of the wiring has been cleaned up. The shop doing it has done a ton of rewiring/fixing some minor issues with it. Sorry to thread jack lol. As for the sites, yes, it's quite shitty and VERY stupid what Sean has done to people. Someone really needs to step in and start doing this shit that is known for good customer service. Ah well, such is life, and maybe someday we'll have a book full of excuses lol.
