![]() Join Date: Feb 2011
TIAL bov not closing after decel
So ive been having some idling issues with my Rb25. Everytime I let off the gas the car dies. Ive thought it was something else like a bad sensor or something, but after taking it to Sileighty_85's house last night for some trouble shooting, he noticed that the bov wasnt closing completely after quick revs, causing it to have a massive vacuum leak and nearly die.
Our test to this was to take the vacuum line to a source in front of the bov just to test and see if it would die when the bov saw very little vacuum. It did not die. However, this caused the turbo to surge even when not under a load. So, my question is, do I need to upgrade spring strength? I have no idea what size spring is in the bov right now. I havent been able to find much info on this yet, and im fairly sure that this is the culprit behind my cars idling problem. Any input would be great. Pics for clicks. ![]() |
![]() Join Date: Dec 2004
Trader Rating: (58)
Does raising your idle fix (bandaid) the issue?
I wouldn't ever use the tial bov on a MAF Car.
Alright, I put a new TIAL on there, and no change. I basically just disconnected the vacuum source to the bov for now just to keep it idling till I figure out the issue.
Do I need a stronger spring for the BOV? |
![]() Join Date: Mar 2011
Just curious but why wouldn't you? Is there something about the setup?
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp |
#6 | |
Trader Rating: (58)
Tial Valves are nice pieces, and work well...on MAP cars.
^^ no its when the car dosent have a MAF, a map is a computer designed program that puts injectors pulserate based on manifld pressure..
unles you mean for the op to blow through the maf, that would work deffinately did it on my vg30 for a while..
VG30ET Modded 2nd Gen Maxima |
Well I decided to make a spacer. It helped. Then I raised the idle a tad more and now it doesn't die.
Now I really don't know what it idles at now because the tach isn't calibrated since the RB25 swap. But im working on that. |
Trader Rating: (58)
Ah yes. Blow throgh. Shit. Super shit.
Sure it works, but not for long. You wont' need to reciulate BOV, but the car will still run like dick. Again, those are all bandaides. Recirculate it and have it work.
#14 |
![]() Join Date: Mar 2009
![]() Feedback Score: 8 reviews
pretty much your issue is for the tial BOV's you need to get a stiffer spring casue what is happening is it is staying open. thats what i had to do with mine. I had just got a 10 psi spring and it ran fine. really the only issue with tial bov is if your running the stock t25 it will eventually kill the turbo haha just casue of the stiffness. in which it did end up doing to mine but i did not care cause i went with a 2871r = )
