Hard Idle And Sputter
Hey all i have a small problem with my det redtop i know its command,this all started when i checked my plugs out about a week ago,before i was using iridiums BKR5E1x-11 and now im running bcpr6es-11 havent been gaped plug and play, and now im having an issues when revving also driving it sounds like i have a mis and sputters, hard idle soundin like theres a big cam ive checked for vac leaks and now im down to checking for a bad sensor, i have a multimeter as well to check ive heard you can check for tps and a for more sensors near the intake manifold any suggestions correct me if im wrong thanks
You sure you checked for all vacuum leaks, while engine is running, just spray brake cleaner around where you think there is a leak, idle will change when there is a leak, check everywhere, the smallest of leaks can hurt it. A lot of overlooked areas is the brake booster check valve located on the firewall, check all hoses that go to the brake booster, then get back to this thread. You have a vacuum leak due to you running rich and having poor idle, they go hand in hand.
*sniff sniff sniff*... Do I smell sarcasm?
![]() Join Date: Sep 2009
keep me posted on this, I have the same problem but I always thought it was because my turbo elbow is only on with 3 bolts currently, allowing air to escape before the 02 reads it.... am I totally wrong!?
You really need to fix that, exhaust leaks that close to the turbo can cause all kinds of weird drivability problems. Turbo may not spool right either
#8 | |
#9 | |
Well this morning i think ive found my sputterin problem as i was checking the TPS that was good, so while the car was running i pulled coil pack #1 it even started to shake really bad then i put that one back in still shaking thou but not as bad when i pulled #1 off, so i did the same thing #2 #3 #4 and the idle stayed the same so now ima have to get new coil packs i hope this solves the little issue : D
