01-14-2009, 12:18 PM | #91 | |
i'm sorry i'm still a baby , all i know is that i'm gonna get super advan's 18X9 FRONT 18X10 REAR for my 98 240 if anyone can tell me the exact offsets i need to make them look flush i'll give them a dollar , i have z32 brakes if that matters |
02-18-2009, 02:23 AM | #94 |
FreshColdBeer.com
Trader Rating: (48)
Feedback Score: 48 reviews
I have some 17x9 for the front and some 17x9.5 for the rear, the wheels are +12 offset. I am wondering what size rubber to put on there, it is going on an s13 with coilovers, not lowered too much, and i honestly am not good with avoiding the curbage, so i want to stay away from the stretched look, any suggestions, will there be clearance issues?
02-18-2009, 09:03 AM | #96 | |
Even then, most that you would have to do is either to hammer the fender well, or to pull the front fenders a little bit. |
07-14-2009, 01:55 AM | #97 |
just out of couriosity who knows if the nismo lmgt1 make any of there offset zero or negative??? kuz my lmgt1 are 18x9.5 offset +14(all 4 rims). any suggestions on what size tires and brand should i get???
10-04-2009, 07:15 AM | #100 | |
i bet you most people would have a TOUGH time fitting 17x13-26 in the rear with bulging 50mm overs.... to put it in persective. i run a 17x9.5 +12 in the front of my s14.... a 17x13 -26 will effective stick out 81mm more.... and dont forget that one needs to turn the wheel for steering..... tubbed fenders would be least of your worries. to my knowledge they do not come in negative or zero offsets. 18x9.5 in the rear should be pretty simple to fit in the front and rear. roll your fenders and hammer the high spots of your wells. |
10-14-2009, 06:12 AM | #103 |
Yo! trying to go 5 lug deep and cheap for my s13 thinking about going with china mustang copy's 17x10 +20 all around anybody know if they will clear the coils in the front???
pretty sure rear should be good just iffy on the front looked through this post found it very helpful just need expert input before i buy thanks sorry for the newbie questions
http://skywalkerindustrial.com |
10-14-2009, 08:30 AM | #104 | ||
I'm kinda like herpes. You may lose track of me, but I'll always be around |
10-20-2009, 12:42 AM | #105 |
Do I need extended wheel studs to run a 3mm spacer for the S14 front? Is it safe to run a 3mm spacer on stock wheel studs?
How long are stock S14 wheel studs anyways? I know Nismo has 50mm and 60mm ones, and Peak Performance is 60mm
268generation.com -United for His Renown- |
10-20-2009, 07:18 AM | #106 |
question
Does anyone know if
18x10+30 front and 18x10 +30 rear with a +30 offset will fit s14 chassis with a stock fenders and with out spacers thanks Last edited by need for drift; 10-20-2009 at 02:01 PM.. |
07-16-2010, 02:51 AM | #108 |
Trader Rating: (26)
Feedback Score: 26 reviews
Wheel / tire size calculator / comparer - RIMSnTIRES.com
My friend sent me this yesterday. Thought I would share. |
12-24-2010, 10:18 AM | #110 | |
rears will fit but the fronts won't. you'll need to run a spacer for the front. "So, will a 17x13 -26 front 17x14 -36 rear fix under a s13, with 20mm front and 50mm overfenders?" yea, that ant gunna happen. even 10's 10.5 is pushing it in the front of an S13. anything over 12" wide in the rear is pushing it. someone ran 18x13 in the rear with 70mm overs. |
01-03-2011, 07:39 PM | #111 |
I have a S14 and I'm thinking about trading for some XXR 521's 18x10 +25 all around. I need to know if they will rub my suspension before I pull the trigger. I'm not a fan of the mexiflush, super poke look and I can't afford overs so I want to avoid spacers.
I used the 1010 calculator and determined that I will have 29mm less inside clearance. Does anybody know what the clearance is with the stock wheels and if I will rub or do I need to crawl under there and measure? I will be running GR2's with Eibach springs. Any help would be awesome. |
01-03-2011, 11:45 PM | #112 | |
Crawl under your car and measure, then convert and calculate, purchase and test fit, then modify (if neccesary), then re-fit. Repeat as needed until you're satisfied. |
01-04-2011, 06:32 PM | #113 | |
Thank you for basically not answering my question at all, lol. Anybody else have any "real" help. Edited to add: I crawled under the car and did the best I could at measuring the clearance between the OEM wheels and the strut housing. I came up with approximately 21mm, give or take. So it looks like the 18x10 521's wont fit without spacers on the front, w/ shocks and springs. Again, there is approx. 21mm clearance between factory wheels and susp, hope this helps someone in the future. Last edited by M4J0R T0M; 01-05-2011 at 06:30 PM.. |
02-26-2012, 12:58 PM | #115 |
help with offsets for my new ssr profesor SP 1 wheels
SSR Wheels - SSR Professor SP-1 18x9 fron 18x10 rear i currently run megan spec rs coilovers and z32 calipers also running 17x8 front +18 and 17x9.5 +20 with tires 255/40/17 rear and 225/45/17 in the front i need more aggresive look please help |
04-07-2012, 06:39 PM | #116 | |
I'll just leave this here...
06-01-2012, 11:51 AM | #117 |
So I'm planning to get 16x10 -12 offset in the rear for my s13 coupe . And 16x10 -/+0 in the front will it work out or should I get 16x9 on the back and 16x8 in the front let me know I need advice with it
06-03-2012, 03:25 PM | #119 | |
0 off-set up front - 12 rears |
07-31-2012, 09:35 PM | #120 |
Okay, so im as new as they come on tire fitment. im trying to make sense of the diagram. ill make this short and sweet. Will a 17x10 +20 offset (6.29 backspacing) fit on the front of a stock 89' 240 hatchback? and 18x10 +20 offset (6.54 backspacing) fit on back? Fenders are rolled. suspension is stock (for now) how big of a spacer will i need? 20 or 40mm wide fenders?
Thanks again for the help. |
