11-27-2008, 08:03 AM | #693 |
Im done throwing money at this setup.
If anyone wants my whole setup (Motor, Trans, clutch everything) minus the turbo its yours for super cheap you just have to pick it up. |
11-27-2008, 08:51 AM | #694 |
What intake do you have? Small filter can be a restriction and I've personally seen the stock rubber intake collapse when warm/higher boost.
Lower than a pornstar's morals. |
11-27-2008, 10:30 AM | #696 | |
11-27-2008, 12:51 PM | #699 |
I wouldn't boost the damn thing at all... Good idea to have a wideband on board just incase and none of that stupi apexi narrowband O2 junk.... Get it tuned.....Your motor will thank you for it. Spend 300 for a tune OR 2000 for an engine rebuild... You make your choice and I am not kidding about this.
Yes there is a difference pressure only measures pressure in the manifold but flow is different. Take for an example I have 2 Fans, 1 is a 2" fan and one is a 4" fan. Well the 4" inch fan will produce more pressure FASTER and sustain that pressure longer than a 2" Fan? Well its the same here the T25 is the 2" fan and the 4" fan is a GT2871R.
Turn and Burn! |
11-27-2008, 04:26 PM | #700 | |||||
Trader Rating: (58)
Feedback Score: 58 reviews
In reality, and take no offense to this, but to from a stock setup to a 2871r is a big step, economically. I would put aside a fair amont of money, get quality parts, and do it right once/the first time. Quote:
Think of it this way. 8 psi on a k03 baby turbo will probably get you 180-190 whp, if that. A t25, probably 210 whp. A t28, 230 whp. A GT35, 300 whp, etc etc etc. Quote:
LS1 time
11-27-2008, 04:28 PM | #701 |
fuck a LS1 he already has a 4 rotor we're putting in in the next 2 weeks.
psych... his car got hit so he gotta put that crap back together.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
11-27-2008, 04:42 PM | #703 | |
Trader Rating: (58)
Aw man that bites!!! Is he ok?
11-28-2008, 11:16 AM | #704 |
Trader Rating: (41)
Feedback Score: 41 reviews
okay. how much power you guys think ill make with my set up?
S14 Blacktop Head work -HKS stage 2 cams -HKS springs and retainer -Port and polish -3 angle job -Tomei solid lifters -Greddy RAS -Greddy Metal Head Gasket -ARP Head Studs -Stock Intake Manifold -720cc injectors -Megan turbo manifold -GT 2871r 86trim w/taka lines -3in turbo dump and cat back exhaust Built bottom end Block with CP pistons and rods. crank is balance and clean. right now i have a exedy stage 2 but dont think it'll last long. want to get the ACT 6 puck exem pressure plate. Z32 maf and Power FC..... i want to run atleast 15-18 psi daily...what you guys think?
In the Zone... |
11-28-2008, 11:49 AM | #706 |
wow, this thread is old.. haha
180sx tomei cams 264, springs and retainers. stock bottom end 850cc stock rail walboro 255 stock manifold intake/exhaust z32 maf power fc gt2871 .63 22lbs race gas 396 whp 370 tq
www.sexypants.org |
11-28-2008, 02:58 PM | #710 | |
11-28-2008, 09:59 PM | #711 | |
Trader Rating: (41)
just on 93 pump gas. dont know what dyno but onces the snow clears up im sure ill post the dyno sheets up. i have a friend that tune mines.
In the Zone... |
11-28-2008, 10:25 PM | #712 | |
with a legit reputable tuner (steve shadows comes to mind) no doubt you can hit 400 on 93 oct. im not sure on what credentials your buddy has but if he's comparibly than you should be fine. |
11-28-2008, 11:29 PM | #713 |
This thread isn't what it was a couple months ago anymore...
werid posts, random dumbness and stupid questions started again.. lets get back to tech talk and posting Dyno's and talking setups.. no more how much power do you think "style questions"...and little dumb arguments...
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
11-28-2008, 11:36 PM | #714 | ||
have you ever dyno'ed it on pump to see how much of a difference it makes? I have always been curious, I am assuming about 20 hp or so?
11-29-2008, 09:10 AM | #716 | |||
however if you notice the peak and the plateau, thats the power band i am looking for this particular setup. this car is put together as a budget race car and i m still beating the living crap out of the car for over a 3 years. car has competed in D1GP and Nopi, and constant grass root drifting at least once a month for the past years, with the same engine and setup. never gave any problems. the A/F can be improved and simple mods can be made so it wont fall too bad and there are other tricks to keep it going, but for the purpose of this ride and deseired power band is reached, plus i will be banging red line constantly, since traction is already loss, therefore i do not need more power, but i need it to be safe. - keyword. thats a big reason the car is tuned that way and we havent had problems for many of our similarly build setups. for my higway cars, thats a different ball game. but yes, i believe there are some restrictions up top. Quote:
if i wanted to make more power, i can with a different setup. this setup was done with very low budget and still pounding on it. stock bottom, intake, exhaust. with aftermarket cams, turbo, ecu, injectors, and a very expensive tune session.. haha. car gets tuned 3 times a year. Quote:
u have to understand, once you start putting mods on your car, and running it like i do, the car isnt oem any more or "safe" all your mods (lifetime of product) are counted in race hours, before replacing it to prevent catastrophe in competition.
www.sexypants.org |
11-29-2008, 07:31 PM | #717 | |
yea its a very effective setup and i would prefer my power band hittign max sooner than later in the rpms too..
11-30-2008, 12:34 AM | #719 | |
safe for the turbo i mean. |
