#33 | |
![]() Join Date: Sep 2005
Building a Roll Cage
![]() 1989 S13 ![]() ![]() |
#34 | |
Now is this just another one of YOUR IDEAS or is this some factual info that you can provide evidence of? I've spoken with fairly hardcore cage builders who are more than happy to cut a hole in the floor to get a PROPER FITTING cage. So seriously, do you have any evidence of this other than your opinion... Like quotes from REAL cage builders saying this? Untill then, i call bullshit. |
#35 |
![]() Join Date: Dec 2002
Now now.
If you were retarded and were planning to just weld the hoop to the floor, then yes it might be a bad idea to cut a hole there. If you are like any sensible fabricator you would know that the floor has about the same strength as a lunch box. It is fine to cut a hole in the floor in order to lower the cage and get to the joints up top for proper welding. Assuming you are going to be plating and boxing the hoops mounting area in properly with 1/8" plate after the cage has been lifted back up.
#38 |
![]() Join Date: Aug 2003
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
OK, heres my geuss on cages, i havent read anything outside this thread, nor do i know much about making one. I would say making a cage indepently boxed in, welded into the car is one way to do it. The floor keeps it in place, not so much for strenth. Or cant you weld it into the frame? The places that i see where the welds are on the floor, are directly in contact with the frame, is that right?I see jeep guys cut the floor to get to the frame.- Either way thats my 2cents i dunno shit. They all look great.I just love seeing ppl cut the roof off, seems to makes since if your wanting really good welds and easy to paint.
89 240sx hatch #933-the hot rod 91 240sx coupe #131,603-the daily |
#39 |
![]() Join Date: Jul 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
so we got the cages in whats the weight factor anyone weigh their cars after they got it done? just wanna see numbers if neone has any. very very good work dudes lets see some more!
#41 |
That's how it's done with offroad trucks - minus Cherokees, which are like most cars and the 240 - unibodies. There is no 'frame' in the traditional sense.
#42 |
#44 |
#45 | |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
Relax nancy, nobody is perfect. YOU included! ![]() |
#46 |
Maybe its a southern thing but all the 8-9 second domestic guys around my place cut a hole in the floor, drop it through to weld the top of the cage, then lift it back up. They then weld the floor plate over small hole and weld the cage to the plates. Then they get underneath, patch the metal so it wont gather moisture and voila!
Scott |
#48 | |
#50 |
So for Justin's cage, it doesn't fit perfectly, it could definitely be better. The part of the main hoop that is above the harness bar and goes into the horizontal part at the roof isn't that far away, but it could be closer. But it's a compromise, you could have a cage that fits up against all the body panels, but then you spend as much time cutting parts out and welding them back in so you can weld all around the tubes that it ends up being not worth it. I also think that I was making the distance between the center of the two top bends on the main hoop a little closer to each other than I do now when I did that cage.
But it's strong, it fits pretty well and there's a ton of room for the driver, which I think it more important than having a tube 1/2" closer to the body. But also, my cages are always evolving, I am always finding different and better ways to do things, to make things fit better, to make them easier to weld, etc. I'm still very happy with how Justin's cage came out, the main hoop could be a little tighter and I could've done something a little different with the bends in the halo, but that's just nitpicking. You hardly even notice the cage when you're driving the car or even getting in and out. It's not intrusive or in the way, but you know it's there and strong. I tend to leave a little room around points that are going to be in tight corners if possible. If you can't get a good weld all the way around the tube, then there is no point of even putting it there. On my cages, it's mostly the lower points that are tucked a little in. So the bottom of the main hoop and bottom of the a-pillar bars are pushed a little away from the wall so that I can get in there and make sure everything is strong. But I have been pushing the middle bend closer to the body than before. So now I put the location where the harness bar bolts up and where the dash bar goes across against the walls of the chassis. With some of the cages I've seen that have bars with "perfect" fitment, I've noticed some that aren't even welded all the way around. Or there is some half-assed, make it look like it's welded crap going on. I just don't trust stuff like that. It's definitely possible to get perfect fitment, but it depends on your process and how much time you really want to put into it. Cutting the roof off is one of the things that I would love to start doing, but people won't want to pay for it. There are also some other tricks that could be done to get bars in tighter spots, but again, it would get expensive labor wise. I wish I could have someone walk in and give me a blank check and tell me to hide the cage in the unibody. It would be awesome, but it's not going to happen. As for the holes in the floor. I don't like them. It's not that it isn't a way to do it, but I just have some problems with it. It goes back to the way I design my cages. I'm real anal about everything being where I want it to and being symmetric, so I do things a little differently. But if you cut holes, it's fine, just make sure to seal underneath the car after you weld the base plates on. And put a little thought into the base plates, but that goes for all cages. Just one flat pieces of metal welded to the thin metal of the floor isn't going to help spread the load as well as a single piece of metal with bends and welded to both horizontal and vertical parts of the chassis. You don't have to go crazy with it, but at least a little something more in good in most spots. But I have a ton of pics in my gallery of the cages that I've done. TIP Roll Cages I haven't posted up some of the more recent work, but hopefully I'll make some more progress on my brother's supra soon and then I'll put pics of that up. |
#51 |
Great reply. Very informative.
Thanks! Edit. Since you know your shit.... I will be buying ONE die for the trikes "build it yourself" bender. What die to you recommend? 90, 180? 6 inch bend or 7 inch bend? Last edited by gotta240; 09-03-2008 at 10:29 PM.. |
#52 |
180 dies are always nice. You can def get by with just a 90, but its always nice to know you can go all the way.
I use 5.5 and 6 " CLR dies. keep in mind the tighter the radius, the harder it is to bend. Also you run into material thickness limitations if you go too tight. I would stick with 6" or 5.5" CLR. Anything tighter seems to be unnecessary. Just my 2 cents. Luke
#53 |
Great. Will deff. go with the 6" 180degree then. I was planning on using 1 3/4 90 wall DOM. Any reason to use something different for a stock weight s14?
Also, any advice/opinions on dimple dies? IE: most common size used and do i need to go top of the line or can i just get the cheaper ones since i'm only doing a few cages a year? Thanks for your reply/expertise |
#54 |
I like to use 1.5 x .120 or .125 dom in my cars 240s/rx-7s.
Reason being is that it smaller, takes up less room, and is easier to get the tubing out of the drivers way (head), which if your tall 6ft+ really makes a difference with head room. 1 3/4" is cool, but I think it just looks too big in our cars, and looks like it belongs on a off road truck, or rock crawlers.
