12-11-2006, 05:04 PM | #1 |
Bumpsteer
Who has this problem? What have you done to remedy it? Does the S14/15 have this problem or is it just more common on the 13s? I know that 13s don't run a upper A-arm in the front. Does the 14/15?
I will be replacing my tires soon. This week maybe w/ Bridgestones. My setup is Cusco Zero2 coilovers w/ Swift springs 6/4kg. Shocks are on 2-fr/ 1-rear. I have a 2.2 finger gap in the front and about a 3 in the rear. 1.5 neg camber front/ 1.6 neg rear Running stock tie rods. Replaced the outer with OEM. Running S14Se wheels w/ 20mm KICS spacer adapters.
I'm driving fast -drew |
12-11-2006, 07:05 PM | #2 |
Trader Rating: (40)
Feedback Score: 40 reviews
What are your toe settings?
Band-aids: - if you have toe out, less aggressive toe (toe-in or neutral toe) - run non-directional tires - seems directional tires tend to follow the grooves of the road and make bumpsteer worse, just observation - I may be wrong - raise the car - soften the suspension dampening - increasing positive caster may help The only "true" way to fix bump steer issues is to get an aftermarket outer tie rod, such as the kazama one. Let's you adjust the tie rod to be relative to the steering rack so that it moves correctly when you hit a dip/bump.
bew bews! |
12-11-2006, 09:03 PM | #4 |
I ran Kazama outers on my car for about a year including several events (running over cones at full lock, bouncing over curbing, dealing with the horrendous surface on the Streets before they repaved it) and never had a problem. However, there are much better ends out there for similar money. SPL is great, Ikeya looks good as well, Peak's also good if they ever get around to remembering us Nissan guys. The shites stopped making Pro 5-lug hubs, leaving me with the ordinary hubs. Grumble.
I run adjustable lower control arms front and rear in addition to adjustable tie rod ends to reduce bumpsteer. I'm still messing around with the geometry but the car is infinitely better than it used to be. The rear is absolutely planted but I still have a little bumpsteer up front. |
12-12-2006, 12:17 AM | #5 |
my car feels fine pretty low stock tie rod ends, with a spacer on the inner(suppost to make "bump steer" worse
i think bump steer is a scam, shit most of the people on this forum (not this thread suprisingly) dont even drive their car past work. i dont really notice bumpsteer, maybe its becuase im dookie though. |
12-12-2006, 01:27 AM | #8 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
Get aligned, then feel out bumpsteer. If it's REALLY bad then get the adj. ends.
I definately have no issues now, after I got an alignment. I'm running Peak Performance PRO inners. Kazama Outers (because at the time I didn't know any better.)
Best way to do business with me? Make your best offer FIRST. |
12-12-2006, 12:27 PM | #9 | |
Bump steer isn't quite as it's name emplys. Bump Steer is when your wheels steer themselves without input from the steering wheel. The undesirable steering is caused by bumps in the track interacting with improper length or angle of your suspension and steering linkages. In order to accomplish zero bump steer, the tie rod must fall between an imaginary line that runs from the upper ball joint through the lower ball joint and an imaginary line that runs through the upper a-arm pivot and the lower control arm pivot. In addition, the centerline of the tie rod must intersect with the instant center created by the upper a-arm and the lower control arm. The instant center is an imaginary point that is created by drawing a line from the upper a-arm ball joint through the a-arm pivot where it is intersected by an imaginary line that extends from the lower ball joint through the inner control arm pivot. Where the two imaginary lines intersect is the instant center. S14/S15's have similar suspension geometry as the s13. There is no real front upper control arm. Purchase angle adjustable tie rod ends. They will allow you to run the tie rod parallel to the ball joint. By the sounds of it, you also need alignment. Pm me if you have anymore questions.
12-12-2006, 12:45 PM | #10 |
I had the bumpsteer after I changed the springs which made it lower due to a softer spring and that was after an alignment as well. That is when I started to get bumpsteer. It looks like the outer ties are what I need. I'll just get SPLs.
So I'm looking at getting an alignment when I get the tires as well. But maybe I'll get the ties first
12-13-2006, 01:27 AM | #11 | |
Bump steer is dynamic toe change. The toe "steers" the car. |
12-13-2006, 01:57 AM | #12 | |
02-13-2007, 05:09 PM | #14 |
ok, to follow-up with my orginal post;
I have replaced the inner and outer tie rods from SPL and have replaced the bushings with ES bushings all around and had the alignment done. I am not satisfied with any of the the parts. It turns very well and tracks good enough but the steering still has a bit of bumpsteer. I have it aligned to -1.2 front/ -1.5 rear camber. Tie rods are parallel to the ground. I actually raised the car to about 3finger gap all around. I even took off my spacers on the front to see if there is a difference. What I am thinking is that maybe it's the wheels? When I had the stock 7 spokes on there, it was fine. But I was running an 10k spring in the front. Now with the s14se wheels, I'm running a 6k spring. Gees, I might just get rid of the coilovers and go shocks and springs...who knows. I'm not complaining about the situation, but am still looking for a fix for it.
02-13-2007, 05:22 PM | #16 | |
Now do you have those installed on your car?
02-13-2007, 07:28 PM | #18 |
Do some research. Bumpsteer is generally used to refer to a condition when one wheel hits a bump and the steering wheel is jerked out of your hand. This is caused by a positive scrub radius, as described above. Use google and search.
What you're experiencing may or may not be bumpsteer. I don't know. Generally try to keep your suspension arms parallel to the ground so you zero out the scrub angle. Alignment is aso key. |
02-13-2007, 07:45 PM | #19 | ||
you're feeling the SEs, smaller sidewalls track the road more. run monster truck tires if your gonna be a bitch about it. Furthermore Tie rods are supposed to be parralel with the LCA not the ground. |
02-13-2007, 09:22 PM | #20 |
I forgot that about the LCA and tie rods parallel deal.
Btw, I do know bumpsteer is as I went to school learning to work on cars so stop defining it. Also no ones bitching. Just looking for a fix...as this is the tech section.
02-14-2007, 08:53 PM | #21 | |
