Old 04-04-2005, 09:29 PM   #1
bobafett
bobafett is an unknown quantity at this point
downpipe size question (searched)
ok i have a t3/t04e turbo with a 2.25" 4 bolt turbine dicharge flange....
the downpipe i had made ended up coming with a 2.25 5 bolt flange
i have access to a 4 bolt 2.5" flange, but im wondering since they arent really close to the same size if it will be a problem..
im thinking it might be ok, but i dont see what other options i have, since after searching a ton of stores i cant find anyone who sells a 2.25" 4 bolt flange. just the 2.5"
what is the easiest solution for this problem? im sure there is something simple, but this is my first turbo project, so im a bit overwhelmed...
bobafett is offline   Reply With Quote
Old 04-05-2005, 08:18 AM   #2
orion::S14
orion::S14's Avatar
As long as it will bolt up and seal...BIGGER is BETTER.
So use the 2.5" 4-bolt flange...and use 2.5" piping (maybe 10-12" of it), until a point in your DP where there's room to pump it up to 3".
- Brian
www.KA24DEvelopment.com
Old 04-05-2005, 08:55 AM   #3
bobafett
my dp is already set up 2.25 > 3 after less than 6" of smaller pipe.
is there an easy way to weld a 2.25" circle into a 2.5" hole that i am not aware of? or will they just have to use a shitload of welding? just seems like an ugly gap. oh well, maybe they can hog out the pipe to make it fit...
thanks for your reply though, at least i know the idea will work if i can get the flange on there!
Old 04-05-2005, 01:02 PM   #4
WeldingHank
WeldingHank is an unknown quantity at this point
your exhaust is only as good as its smallest part. the shorter the amount of 2.5" or whatever piping the better.
1989 240sx:CA18DET
My Cardomain
WeldingHank is offline   Reply With Quote
