Old 11-12-2020, 10:10 PM   #1
Medinas240
Medinas240 is an unknown quantity at this point
S13 Cluster Lights Flashing on/off
Alright I need all my expert wiring and tech heads to help on this.
S13 240sx - was a dohc manual - analog cluster
So I took my dash out and flocked it and when I went to test everything before putting it back in I noticed my cluster lights were flashing on and off when I turned on the lights. So I pulled the connectors and tested the pins, found a Y/G wire that fluctuated between 0-0.4 volts back and forth. Followed the wire and it goes to the automatic seatbelt control module under the center console, de-pinned the Y/G wire and tested the pin directly from the module.. same thing 0-0.4 volts. I replaced the module and it does the same exact thing only at 0-0.15 volts. At this point I?m lost, hoping you guys can help me out. What could cause the wire to pulsate like that? Any good advice is appreciated.
Medinas240 is offline   Reply With Quote
Old 11-12-2020, 11:43 PM   #2
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
check your grounds
zombiewolf513 is offline   Reply With Quote
Old 11-13-2020, 05:26 AM   #3
OMFGeofffff
OMFGeofffff's Avatar
OMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really nice
Do the lights stop flickering when that wire is de-pinned?
OMFGeofffff is offline   Reply With Quote
Old 11-13-2020, 09:14 AM   #4
Medinas240
Originally Posted by zombiewolf513 View Post
check your grounds
Already checked the grounds, cut the ground wires and grounded them directly to the chassis, still did the same thing.
Old 11-13-2020, 09:19 AM   #5
Medinas240
I'm assuming you mean when the wire is de-pinned from the seat belt module? that's actually a good point, I'll have to try that when I get home. But my guess is if I de-pin the wire from the seat belt module I won't have cluster lights at all.
Old 11-14-2020, 12:18 AM   #6
OMFGeofffff
Technically the cluster lights are tied into the rest of the illumination lights like hvac, parking, tail lights. The wire you are depinning controls the seat belt warning light.
Old 11-15-2020, 12:10 AM   #7
zombiewolf513
did you check the dimmer potentiometer?
Old 11-16-2020, 11:46 AM   #8
DiscountPirate
DiscountPirate is an unknown quantity at this point
If everything was previously unhacked and all you did was remove and replace I would think it is something simple. If anything use a q tip and clean all contacts and ensure all 3 connectors are seated well. Might as well pop off cover of cluster and check out insides while it's out too if still having issues.
DiscountPirate is offline   Reply With Quote
gauge cluster, s13 240sx, wiring problem
