Old 07-10-2014, 01:00 PM   #1
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Arrow ☆UPDATED S-Chassis Garage Sale! JIC WILWOOD AEM PBM HKS BLITZ CUSCO NRG
SHIPPING: At buyers expense
CONTACT INFORMATION - [email protected] or via PM.
PAYMENT OPTIONS: Cash, Paypal
S13 Parts List
S13 Exterior
RH Quarter Panel Replacement
RH Lower Rocker Panel
Non-Sunroof / Slicktop Replacement Roof for S13 Hatchback
Front Bumper Upper Retainer
Zenki S13 Front Bumper Support
Front Fender Brackets
Headlight Metal Lid
Headlight Splash Guards (plastic, sit on radiator core support)
Hood Prop
Hood Hinges
Hood Latch
Cowl Trim Covers
Wiper Arms
Wiper Motor
LH Door Glass Window
Exterior Door Handle
Rear Bumper Cover
Rear Bumper Support
Rear Bumper Brackets
Rear Bumper Foam
S13 Hatchback Taillight Set
S13 Hatchback Taillight Metal Garnish
S13 Hatchback Trunk 3rd Brake Light
Fuel Filler Door
LH or RH S13 Hatchback Exterior A-pillar Trim
B-Pillar Plastic Exterior Trim
Front Amber Fender Sidemarkers
Rear Red Sidemarkers
S13 Hatchback LH or RH Quarter Windows (no trim)
S13 Interior
S13 Hatchback Ignition/Doors/Trunk/Glove Box Lock Set with Key
Steering Column
Lower Steering Column Cover
Dash Plastic Vents / Tubing (behind dash)
RH Dash Vent
Blower Motor
Heater Core Box
AC Core Box
Antenna Wiring Harness
LH or RH Door Frame Trim Finisher
LH or RH Interior Door Handles
LH or RH Interior Door Handle Bezel
LH or RH Interior Door Handle Pull Plastic Trim
RH Door Grab Handle
LH Manual Window Regulator
Window Crank Handle w/bezel
LH or RH Triangle Mirror Covers
LH or RH Door Latch Door Assembly
LH or RH Door Lock Rods
LH or RH Door Misc Brackets
LH or RH Speaker Brackets
Radio Brackets
Din Pocket
Glovebox (no handle)
S13 Factory Non-AC Climate Control Set
LH Seat Plastic Trim
RH Auto Seat Belt Track
LH or RH Lap Belt
LH or RH Shoulder Belt
Rear Seat Belt Buckles
S13 Hatchback Rear Seat Belts
LH or RH Kick Panels (Black)
S13 Hatchback Rear Large Plastic Trim set
S13 Hatchback Rear Speaker Metal Brackets
S13 Hatchback Non-Sunroof Headliner
Dome Light
Trunk Light
Fuel Pump Metal Cover
Misc Interior Brackets
Misc Interior Buttons (Headlight, Hazard, Defroster, Dimmer, etc)
S13 Suspension / Brakes
Front Knuckles
Front Lower Control Arm Set
Steering Rack
Steering Rack U-Joint
Front Brake Caliper Set
Rear Brake Caliper Set
Emergency Brake Cable Set
Rear Lower Control Arm Set
Rear Upper Control Arm Set
Rear Traction Rod Set
Rear Toe Arm Set
Rear Subframe Brace
Rear Subframe Stud Set
Diff Cover
Welded Diff (Non-ABS, 4.08 ring gear, 6-bolt shafts)
OEM Axle Set
Rear 4-lug Hubs
Front/Rear OEM Shock and Spring Set (newer KYB)
Front or Rear OEM Sway Bar
Brake Master Cylinder
Brake / Fuel Hard Lines
S13 Engine Bay
KA24E Complete Air Intake Set (Tubing, filter box, etc)
KA24E Engine Block
KA24E Cylinder Head
KA24E Valve Cover
KA24E Intake Manifold Bare
KA24E Throttle Body
KA24E Fuel Rail
KA24E Distributor
KA24E Alternator
KA24E Power Steering Pump
KA24E Power Steering Reservoir
KA24E MAF Sensor
KA24E Ignition Coil
KA24E Misc Pulleys
KA24E / KA24DE Emissions Components
Misc KA24E Engine/Block Brackets / Parts
Charcoal Canister
OEM Radiator w/hoses
Windshield Wiper Tank w/filler neck
Fuel Filter Bracket
S14 Parts List
S14 Exterior
OEM S14 Kouki USDM Sideskirt Set
OEM S14 Zenki Leather Nose Mask
LH or RH Quarter Panel Replacement (complete cut out)
LH or RH Rocker Panel Replacement
LH or RH Strut Tower
Radiator Core Support
LH or RH Frame Rails
LH or RH Door Shell
LH or RH Exterior Door Handle
LH or RH Door Check / Stop
LH or RH Door Belt Trim
LH or RH S14 Zenki Fender
S14 Zenki Hood
Hood Hinges
Hood Latch
S14 Zenki Hood Prop
S14 Zenki Front Bumper
S14 Zenki Fog Light Delete Trim
S14 Zenki Headlight Set
S14 Zenki Corner Lights
S14 Zenki Turn Signals
S14 Zenki Front Bumper Support w/ Retainer
S14 Zenki Front Bumper to Fender Brackets
Windshield Wiper Cowl Trim
Windshield Wiper Set
Wiper Rotating Arm Assembly
S14 Zenki Wiper Motor
Rain Gutter / A-Pillar Exterior Trim
Wingless Trunk
Trunk Support Arms
3rd Brake Light
S14 Zenki Taillight Set
Rear Bumper Cover
Rear Bumper Support
License Plate Light
Front Windshield
LH or RH Door Glass
LH or RH Door Mirror
Rear Windshield / Glass
Rear Glass Lower Trim Finisher
Rear Tow Hook
Fuel Filler Door
S14 Interior
S14 Zenki Black Cluster
Cluster Bezel
Dash Metal Brace
LH or RH Dash Vents (lead to door panels)
Steering Column Trim (2pc with ignition trim)
Lower Steering Column Trim
Steering Column
Throttle Pedal with Cable
Throttle Pedal Stopper
Dead Pedal
Wiper Switch
Turn Signal Switch
Wiper/Signal Holder Bracket
Steering Wheel Clock Spring
Glovebox (no latch)
Glovebox Bracket
Center Console
Side view mirror switch
Ash tray
Radio Brackets
Climate Control Panel
Blower Motor
Heater Core Box
AC Core Box
Dash Vent Piping / Ducts
Emergency Brake Handle
LH or RH Door Panel
LH or RH Window Regulator
LH or RH Door Handle Bezel
LH or RH Door Lock Latch Assembly
Cigarette Lighter
Sun Visor Set
A-Pillar Set
B/C Pillar Set
Front and Rear Seat Set (OEM Gray)
Rear Seat Swivel Brackets
Rear Seat Striker Bracket
Front Seat Belt Set
Front Seat Belt Buckles
Rear Seat Belt Set
Rear Seat Large Interior Plastics
Rear Seat Trim Finisher (behind seats)
Rear Speaker Deck Lid
Light Dimmer Switch
Hazard Light Switch
Defroster Switch
Cruise Control Switch
LH or RH Kick Panel
Door Sill Set
LH or RH Door Frame Seal / Finisher Trim
LH or RH A-Pillar Window Frame Seal
Trunk Carpet Panels Set
Trunk Rubber Seal
Trunk Latch
Trunk Striker
Trunk Edge Plastic Trim Cover
Fuel Pump Cover
Trunk Light
Jack with Mounting Bracket
Misc Interior Brackets (Dash, doors, interior panels, trunk, etc)
S14 Suspension / Brakes
OEM 5-lug Front and Rear Hub Set
OEM 4-lug Front and Rear Hub Set
Front Knuckles Set
Front Crossmember
Steering Rack
Rear Upright / Knuckle Set
Rear Lower Toe Arm Set
Rear Upper Traction Rod Set
Rear Subframe Brace
Rear Subframe Tunnel Bracket / Brace
Brake / Fuel Hard Lines Set
Fuel Tank Straps
Fuel Tank Heat Shield
Fuel Filler Neck
S14 Engine Bay
Zenki AC System Complete Set (Compressor, Condenser, all lines, brackets, etc)
Zenki MAF Sensor
Charcoal Canister
Complete Air Intake System (intake pipe, air filter box, all ducting)
Cruise Control Assembly
Heater Core Hoses
Power Steering Cooling Hard Lines
Fuel Filter Mounting Bracket
Radiator
Radiator Mounting Brackets
Old 07-10-2014, 01:01 PM   #2
CrimsonRockett
The Architect.
$30 - S14 Passenger door handle
$10 - S14 passenger side kouki bulb holder
Brakes
Wheels
Electronics
$45 - Autometer Fuel Gauge (new)
$100 - HKS PFC
DESCRIPTION: I received this with a car I just bought and I don't have any use for it so someone else here can put it to use. Here's the product description from HKS. It's for 1989-1994 S13 SR20DET's.
The HKS PFC F-CON is a plug-in fuel management system designed to supplement and refine the OEM fuel curve to maintain a proper air/fuel mixture when increasing boost pressure in turbocharged applications. The PFC F-CON optimizes the factory injector pulse width signal by recalibrating information obtained by both the PFC F-CON absolute pressure sensor and the OEM engine control unit (ECU). Each unit is application specific and includes a preprogrammed ROM for a particular performance stage. —- A Fuel Cut Defencer (FCD) is also included in certain PFC F-CON kits to override the factory fuel cutoff. The PFC F-CON offers easy integration via a plug-in vehicle specific wiring harness and a compact pressure sensor. If additional adjustment of the PFC F-CON is needed, fine-tuning can be performed via the plug-in HKS Graphic Control Computer (GCC).
$40 - Flex-a-lite Fan Controller
Engine
$15 - KA/SR MAF Intake Filter adapter
$10 - ID Coolant Overflow tank
Drivetrain
$125 - S15 HLSD Half Shafts 38220-4P061 (two available)
-Jspec-
Instagram/CrimsonRockett
Old 07-10-2014, 01:01 PM   #3
CrimsonRockett
The Architect.
Updating posts.
-Jspec-
Old 07-10-2014, 01:01 PM   #4
CrimsonRockett
The Architect.
JDM S14 DEPO Clear Fender marker lights
- Good shape overall. Can be made to fit just about any other car.
Price - $30
-Jspec-
Old 07-14-2014, 10:39 AM   #5
CookiesNCream
CookiesNCream's Avatar
CookiesNCream is an unknown quantity at this point
How much for the carpet shipped to 30252?
CookiesNCream is offline   Reply With Quote
Old 07-14-2014, 11:42 PM   #6
goldens14
goldens14's Avatar
goldens14 is an unknown quantity at this point
Where are you located im interested in buying the steering wheel. I am in San Diego.
goldens14 is offline   Reply With Quote
Old 07-22-2014, 10:28 AM   #7
nissanrunner
nissanrunner is an unknown quantity at this point
s13 triple projectors wtb!!
would you take 200 shipped to 73701? i need these bad. roomate backed into my silvia now i need a whole front end.
nissanrunner is offline   Reply With Quote
Old 07-23-2014, 03:43 PM   #8
LuxExperience
LuxExperience is an unknown quantity at this point
Pmed
Sent from my GT-I9300 using Tapatalk
LuxExperience is offline   Reply With Quote
Old 07-23-2014, 11:35 PM   #9
Rgsherod
Rgsherod is an unknown quantity at this point
power fc still up for sale?
Rgsherod is offline   Reply With Quote
Old 07-30-2014, 11:19 AM   #10
J_fugginBird
J_fugginBird is an unknown quantity at this point
pignose lip shipped to 68521?
J_fugginBird is offline   Reply With Quote
Old 07-30-2014, 02:52 PM   #11
CrimsonRockett
The Architect.
Not looking to ship the carpet. Sorry about that.
Los Angeles, CA.
Sorry, price is plus shipping.
Sold. Sorry about that.
Not looking to ship the pignose lip.
-Jspec-
Old 08-12-2014, 02:27 PM   #12
4rced-air
4rced-air is an unknown quantity at this point
Hello Hello... I sent you a pm and would like to get the S13 Coolant Overflow. Let me know if still available... Thanks
4rced-air is offline   Reply With Quote
Old 08-13-2014, 08:26 AM   #13
YOSHIKOUKI
YOSHIKOUKI's Avatar
YOSHIKOUKI is an unknown quantity at this point
Send a message via Yahoo to YOSHIKOUKI
Is that greddy Intake manifold set in stone
YOSHIKOUKI is offline   Reply With Quote
Old 09-04-2014, 09:53 AM   #14
hardcorps135
hardcorps135 is an unknown quantity at this point
Send a message via AIM to hardcorps135 Send a message via MSN to hardcorps135 Send a message via Yahoo to hardcorps135
So you still have the CS coolant overflow tank?
1990 Nissan 240SX (RPS13.5) *WIP*
hardcorps135 is offline   Reply With Quote
Old 09-04-2014, 10:11 AM   #15
CrimsonRockett
The Architect.
Holding onto it for now. I'll let you know if I decide to sell that unit.
-Jspec-
Old 09-13-2014, 10:48 AM   #16
Supaflu225
Supaflu225 is on the path to ruinSupaflu225 is on the path to ruin
Authentic BN Blister Kouki S14 Fenders - 40mm
Text me ready to buy 2252908879.
Supaflu225 is offline   Reply With Quote
Old 09-16-2014, 10:22 AM   #17
ryrybope
ryrybope is an unknown quantity at this point
HKS FMIC still available?
ryrybope is offline   Reply With Quote
Old 09-16-2014, 03:23 PM   #18
MCT_Kouki
MCT_Kouki is an unknown quantity at this point
Is the SR swap still for sale?
PM me if it is.
I'm in norcal but I can make the drive down.
MCT_Kouki is offline   Reply With Quote
Old 09-26-2014, 12:11 AM   #19
mosqkid101
mosqkid101's Avatar
mosqkid101 is an unknown quantity at this point
Do you have front s14 seats for sale?
mosqkid101 is offline   Reply With Quote
Old 09-26-2014, 01:06 AM   #20
mosqkid101
mosqkid101's Avatar
PM you about the seats
Old 10-08-2014, 09:14 PM   #21
shinski
shinski's Avatar
shinski is an unknown quantity at this point
How much for the Silvia Projectors shipped to 30044? Thanks in advance mate.
shinski is offline   Reply With Quote
Old 10-12-2014, 10:16 PM   #22
Xxs13240xX
Xxs13240xX's Avatar
Xxs13240xX is an unknown quantity at this point
Willing to sell just engine harness?
Xxs13240xX is offline   Reply With Quote
Old 10-13-2014, 03:26 PM   #23
sarhd
sarhd is an unknown quantity at this point
RHD Dual Gauge Pod still have? If so how much shipped to san antonio tx 78237
sarhd is offline   Reply With Quote
Old 11-02-2014, 08:56 PM   #24
Jamison182
Jamison182's Avatar
Jamison182 will become famous soon enoughJamison182 will become famous soon enoughJamison182 will become famous soon enoughJamison182 will become famous soon enough
Sent you pm today, not sure if you got it. My Phone's browser has been acting up.
Jamison182 is offline   Reply With Quote
Old 11-04-2014, 09:04 PM   #25
R_Rod_s13
R_Rod_s13's Avatar
R_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really nice
Still have the pig noise lip?
fuck i hate zilvia
R_Rod_s13 is offline   Reply With Quote
Old 11-24-2014, 08:13 PM   #26
Zeph331
Zeph331 is on the path to ruinZeph331 is on the path to ruin
how much to ship the big letter Silvia Grille and the Silvia headlights? 98281
Can send u payment right now if still available
Zeph331 is offline   Reply With Quote
Old 11-26-2014, 02:31 AM   #27
atoczek
atoczek is an unknown quantity at this point
There's a rubber nut that hols the top of the air cleaner box to the inner fender wall. Have you got one in good shape?
atoczek is offline   Reply With Quote
Old 11-26-2014, 11:27 PM   #28
sin0186
sin0186 is an unknown quantity at this point
Have any redtop MAF?
sin0186 is offline   Reply With Quote
Old 12-07-2014, 06:44 AM   #29
em300zx
em300zx is an unknown quantity at this point
Do you still have the power folding mirrors
em300zx is offline   Reply With Quote
Old 02-05-2015, 07:00 AM   #30
CrimsonRockett
The Architect.
Original post updated.
-Jspec-
