05-14-2013, 09:48 PM | #1 |
magnet speedo sensor? does any one have experience with this?
i have done the z33 trans conversion, and was debating about going with a sensor that measures the speed of your driveshaft for a speedo....
one of them im looking at is on this page.... STACK Electric Speedometer has any one use one of these? how accurate is it? how easy is it to install/calibrate? i really dont want to have to change out my diff, and get the dakota speed sensor crap.... thought this would save me some time...(dont really need a speedo, but thought it would be nice to have... |
05-14-2013, 10:18 PM | #2 |
I can not comment on the above item you are looking at. But Autometer have a speedo that hooks up to any speedo sensor or even an unused ABS sensor in the rear diff. To set it up after every thing is wired in is drive 2 miles exactly, any speed. Then hit a stop button, it counts the number of pluses generated during that 2 miles to give you an accurate rate of speed. so if you change wheel and tire sizes to what ever just drive the 2 miles again and reset. If I were to remove the factory cluster and make my own, or make a rat rod, I will be using that Autometer product.
Do you need; Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill S13 Silvia J's, Q's, K's, A's Bumper grill inserts. Male Plugs for S15 headlights PM me if you need them. |
05-14-2013, 10:26 PM | #3 |
^^ ok maybe i wasnt clear, i think you mis understood my question..... this is a track car..... i have a stack 8100 cluster, its a non abs diff, i dont want to switch it out to an abs diff. i was wanting to know if anyone has used a speed senor that gets its signal from the driveshaft as a seperate source...
another version of the sensor im talking about is this one.... the ring attatches around the drive shaft (near the yoke) and that s how it gets its signal..... ive never seen any one use one, and wanted to know if they are worth a damn, or just a waste of time and money.... |
05-15-2013, 08:55 PM | #4 |
this looks interesting..... has anyone used this? is it accurate?
http://www.speedhut.com/gauge/GR4-GP...-and-high-beam) |
