Getting Horrible MPG's
Recently picked up this pretty beat S14 and i am in the process of restoring it to sound mechanical performance.
It has a SR20DET all stock as far as i know except the GReddy intake manifold. I've been getting only the worst mpg, i can smell fuel in the cabin when i have the windows down only, I read a similar thread on here but there are so many different possiblilties but never had a solution posted. I drive about 2k miles a month so i drive between 55 and 65mph 90% of the time so save on fuel, but i still get just horrible results. This morning for example i put in $40 91 octane Cheveron an it put me at a hair above half a tank, drove 32 miles to work and now its just a hair above quarter of a tank. I havent noticed an fuel leaking but it could be evaporating quickly. The tires are huge (F235 R275) but i know that cannot make it that bad. I'm going to try and get a oil change and replace spark plugs done asap but money has been very tight, so hopefully next week. Going with NGK Iridium IX spark plugs and 5w30 full synthetic motor oil I have read it can be a dirty fuel filter but it only smells like fuel inside the car when windows are down, unless that has nothing to do with it. Ive also read might be an injector not sitting right. and also a fuel leak some where. I want to take it to a dealership and just have them look at it not have them repair it cuz i know it would be damn pricey. Any other opinions you can share i'd greatly appreciate it |
![]() Join Date: Jun 2007
Could be your head gasket if the oil smells of fuel. You may go ahead & give it a tune-up, make sure the timing (15-17BTDC @idle) is good & change the oil- couldn't hurt. Also, are the injectors a purplish color? That's what color the stock ones should be.
Check for vac/boost leaks
#5 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
Fix all vacuum leaks. Injectors not install correctly = big vacuum leak = poor MPG
Reset the timing check CTS Run copper plugs, BKR7E-11, gapped to .025 for now, until you're sorting the issue out. No use ruining iridium plugs if you're running that rich. Cliffs: If money is too tight to attack the issue asap, I'd sell the car and get a nice Altima or Sentra that gets 35 mpg and just drive it.
#7 | |
where is thee 02 located? [/quote] the o2 sensor is on the top end of the downpipe, above the flex point. I got the same problem, researching as we speak. if I find out where the problem lies in, I'll let y'all know" just checkout my dip stick and f u h " my oil does smell like gas . . .
the o2 sensor is on the top end of the downpipe, above the flex point. I got the same problem, researching as we speak. if I find out where the problem lies in, I'll let y'all know" just checkout my dip stick and f u h " my oil does smell like gas . . .[/QUOTE]
please do let me know thanks! |
#15 |
![]() Join Date: Aug 2011
Dont put iridium plugs, they cost an arm and a leg and are known to fail earlier than coppers when used with rich mixtures. I cant see why people want to run 60$ plugs when a 10$ one does the job ...
From what you said, i'd say you bought a riced out S14 that needs to be fully rebuilt, which is going to cost money. I have also read on this forum that removing the EGR valve or using the wrong O2 sensor usually results in running very rich, so that may help you. But seriously, if you can smell fuel from the catch can, it does not look well ... do a compression check before throwing money at it. Dry, then wet. |
#17 | |
What do you mean riced out. if it needs to be rebuilt im just gonna buy another motor. |
#18 |
![]() Join Date: Dec 2010
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
Forgot the simple fact that your gauge can be wrong also. Fill to the tip top, not a dollar amount. Stop when the pump stops. Then drive till its empty, do the math from there
#19 | |
I did that when i first got the car a little over a month ago and i got about 230 miles on the tank but im sure i could have pulled off 250 miles because i wasn't sure if the fuel light was working. But its been getting worse since then. I'm hoping oil change, spark plugs, fuel filter, and some lucus fuel injector cleaner might help. I really hope this isnt too serious |
#20 | |
If results are low, do the test again but add a spoon of oil in each cylinder (by the plug hole) before testing. That is a wet test. If results are now good, your rings are not sealing anymore (means dead rings, or worn pistons/ bores). A compression tester is worth maybe 20$, get one. Another cheap thing to get is a product you add to a sample of your coolant. If it changes color, exhaust gases pass through your coolant (which is bad). riced => ask google, he will tell. You wont find a decend SR20 that does not need a rebuild, really. |
#22 |
Something along that line yeah. 275 tires on a beaten up S14 is a good clue, but it may also be a former track car that got sold after getting too many troubles.
Yet a greddy intake manifold is more the sign of a riced car than a tracked car. Compressions should be around 150psi (10bars). Remember, remove fuel pump fuse, fully charged battery, full throttle, otherwise the reading wont be good. |
#23 | |
i have an external switch that turns on and off the fuel pump. Thanks for the info im gonna do this as soon as i can open the hood... |
#24 |
![]() Join Date: Apr 2012
Trader Rating: (63)
![]() Feedback Score: 63 reviews
My SR is doing the same thing
:/ & I can't figure it out I sold my 97 SE Kouki. To get a 97 SE Kouki w/ A SR Needed the turbo to be replaced Car was running fine when I bought it Drove it home 75 miles as soon as I got home. Turbo gasket went out Got A S15 BB Turbo Replaced all turbo Gaskets put the 3inch Exhaust & Fresh spark plugs fresh oil change & still same Doing the same thing I did a compression test before I replaced the turbo & gaskets it read 160-160-142-160 Still not running right burns gas like crazy & bogs when trying to accelerate All vacuum are fine no leaks Car turns off when it reaches a quarter gas tank no fuel light turns on or nothing Then I add a gallon of gas & turns right up Still trying to find the problem |
#25 |
Well spartan, Rb26kouki seems like we got the same problem, s h y t! Haha. None the less we must find out what is causing this in our S-chassis, whatever we do Find Out, Experiment or Fail please report back here to the Thread so we can help better understand our Savages Haha" To be Continued....
![]() If we accomplish awesomeness we should meet for some Garbage Burritos lol |
#26 | |
#27 | |
getting oil changed hopefully this week. then spark plugs or brakes need to be done as well. ps i love breakfast burritos. |
#29 | |
