Old 08-02-2011, 03:51 PM   #31
Coolwhip
Coolwhip's Avatar
Coolwhip is an unknown quantity at this point
Send a message via AIM to Coolwhip
Originally Posted by champwhiteej8 View Post
If you dont mind sharing what were the specs on the ccw classics? size, offset etc. In for more updates! This thread is an inspiration
Rear - 7" back spacing
Front - 5.25" back spacing
Coolwhip is offline   Reply With Quote
Old 08-02-2011, 03:53 PM   #32
JDM king240
JDM king240's Avatar
JDM king240 is an unknown quantity at this point
if i buy a bunch of parts from u do i get giant discount
JDM king240 is offline   Reply With Quote
Old 08-02-2011, 04:10 PM   #33
Coolwhip
Coolwhip's Avatar
Setting up the fuel system...
Deatschwerks in-tank
-6AN braided line out of the tank
Anti-surge tank
Bosch 044
XRP Inline fuel filter
-10AN fuel feed line
Twin -6AN into the fuel rail
1000cc Injector Dynamic Injectors
-6AN fuel return line
Aeromotive FPR
-8AN fuel return to the anti-surge tank
Mock up of the anti-surge tank in the trunk...
Old 08-02-2011, 04:14 PM   #34
Coolwhip
Coolwhip's Avatar
Of course... "giant" is in the eye of the beholder though...
<<again... insert Burger King small hands commerical>>
Email me what you're looking for... [email protected]
Old 08-02-2011, 04:24 PM   #35
JDM king240
sent u a PM
Old 08-02-2011, 05:16 PM   #36
JDM king240
sent u a PM of my list
Old 08-02-2011, 05:20 PM   #37
Coolwhip
Coolwhip's Avatar
Got it. Thx.
Old 08-02-2011, 08:17 PM   #38
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
great start so far, cant wait till its done!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 08-08-2011, 02:27 PM   #39
Coolwhip
Coolwhip's Avatar
Was out of commission for almost for a whole week due to wisdom teeth being removed… slow progress on the car but still chipping away:
Motor is all bolted in on McKinney Mounts for test fitting and fab work to be done…
Drivetrain all buckled up with a one piece steel Raw Brokerage driveshaft…
Notice the use the modified RB26 AWD oil pan causes interference with the cross member and steering rack…
my solution: going to shim the engine up slightly and shave the pan down in areas of interference)
Old 08-09-2011, 07:12 PM   #40
Coolwhip
Coolwhip's Avatar
Test fitting GT35R and Raw Brokerage front mount intercooler...
Keeping the bumper beam... just making some modifications to clear the FMIC. Measure, cut, grind, weld, grind, fitted!
Ran the fuel lines to the engine bay... -10 AN feed, custom bracket to a -6 AN split for dual feeding the fuel rail and -8 AN return from the soon to be mounted Aeromotive Fuel Pressure regulator
Interior tear down begins... along with the auto to manual conversion
Old 08-09-2011, 07:26 PM   #41
skyline331
Trader Rating: (25)
skyline331 is an unknown quantity at this point
Feedback Score: 25 reviews
Great stuff Ricky!
skyline331 is offline   Reply With Quote
Old 08-09-2011, 07:55 PM   #42
tricky_ab
tricky_ab's Avatar
Looking good my man! Thanks for keeping us posted
Old 08-09-2011, 09:22 PM   #43
tinys s14
tinys s14's Avatar
tinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-known
really diggin the fuel set up
tinys s14 is offline   Reply With Quote
Old 08-10-2011, 06:04 AM   #44
Skilz10179
Skilz10179 is an unknown quantity at this point
Potentially my dream S14....
Not to jack this thread but you need another set of Classics so we canbe twins again!
Skilz10179 is offline   Reply With Quote
Old 08-10-2011, 07:51 AM   #45
Coolwhip
Coolwhip's Avatar
I kno, I kno... but I couldn't spend the coin on another set only to get back to where I was originally... even though there are a very few wheels I would go to after a set of Classics.
No worries though, this will be addressed.
Old 08-12-2011, 04:48 PM   #46
Coolwhip
Coolwhip's Avatar
Interior is coming along, dash is pulled out along with some other interior trim to do the 5 speed conversion and the other interior wiring...
Ace test fitting the ISIS radiator and electric fans...
Radiator, intercooler, and bumper beam all installed...
Started to work on the custom power steering setup. Deceided to keep the AN fittings going and since I had to relocate the resisivor... mounted next to the radiator for a clean install...
Had to make some brackets... mounted to some factory threaded holes on the radiator support...
Old 08-12-2011, 04:51 PM   #47
JDM king240
hey did u ever finish my list
Old 08-12-2011, 05:06 PM   #48
Coolwhip
Coolwhip's Avatar
got you covered!
Old 08-12-2011, 06:58 PM   #49
EnemyS15
EnemyS15 is an unknown quantity at this point
Ricky,
How is the clearance between the front of the motor and the Rad/fans, using the Syko mounts? (will be adding this to my list once the other stuff gets purchased).
EnemyS15 is offline   Reply With Quote
Old 08-14-2011, 06:47 AM   #50
Coolwhip
Coolwhip's Avatar
Originally Posted by EnemyS15 View Post
Ricky,
Using McKinney mounts. The clearance is minimal (re: as most RB swaps, no room for puller fans). But I have a solution for that
Old 08-14-2011, 06:53 AM   #51
Coolwhip
Coolwhip's Avatar
A little Birthday present to myself...
Haltech Platinum Pro Plug n' Play Stand alone engine management and Racepak Digital Cluster
Old 08-14-2011, 06:58 AM   #52
Om1kron
Om1kron's Avatar
good present.
Wayne Edwards
https://om1kron.blogspot.com
Old 08-15-2011, 10:32 PM   #53
doyle4281
doyle4281's Avatar
doyle4281 is on a distinguished road
Hey Ricky, did Haltech recommend the use of an aftermarket oil pressure sensor? They told me that the accuracy of the OEM pressure sensor is limited, and recommended theirs or a Honeywell or Bosch unit. Their tech support is top notch, but I want to be sure it is not a sales pitch. That Haltech system combined with the Racepak is awesome, and can be more cost effective then purchasing a bunch of gauges. Nice work man!
doyle4281 is offline   Reply With Quote
Old 08-16-2011, 07:55 AM   #54
Coolwhip
Coolwhip's Avatar
No they're right. I'm using a spare bosch unit that I had for my previous oil pressure gauge on my RB25, so that will be used with this setup.
We run this combo on all the cars here. I wanted to be cool too.
Old 08-16-2011, 06:28 PM   #55
Coolwhip
Coolwhip's Avatar
heater hoses ran...
the downpipe and rear dump tube now reaches under the car...
Trunk bulkhead fittings installed for the anti-surge tank...
Pretty much all the fabrication, cut, weld, bang, test fit, etc. is finished... time to tear everything back out...
Old 08-16-2011, 06:56 PM   #56
rb20240sx
rb20240sx's Avatar
rb20240sx is an unknown quantity at this point
looking good. Can't wait to see more.
95 SE Serengeti sand- RB25 Neo
rb20240sx is offline   Reply With Quote
Old 08-16-2011, 07:09 PM   #57
tricky_ab
tricky_ab's Avatar
It's looking great! Thanks for the updates...
Old 08-16-2011, 08:24 PM   #58
tinys s14
tinys s14's Avatar
did you trim the inside of the bumper support to fit the cooler?
Old 08-17-2011, 06:35 AM   #59
Coolwhip
Coolwhip's Avatar
Yea. And then boxed it in and welded it back together.
Old 08-17-2011, 07:23 AM   #60
FoBoNtHeRuN
FoBoNtHeRuN is an unknown quantity at this point
Send a message via AIM to FoBoNtHeRuN
Awesome built!!
FoBoNtHeRuN is offline   Reply With Quote
rawbrokerage, rb26, rb26dett, ross tuffbond, s14
