![]() Join Date: Nov 2007
![]() Compatibility thread... There are a lot of spread out threads of parts that will fit on on different chassis so I think this would be a good Idea to put em all on one thread. Its also here to help save money or make some on the forums. I know there will be
Please note any modifications needed if they are light or if there is a conversion and who makes it. This is not Just for 240's its for any S and Z chassis, datsun as well as Infinity OEM compatable parts to and from them all. Im also going to add Links for how too's and precise info. Heres a couple popular ones The best s13/s14 300zx brake upgrade thread ever!! The Definitive 300ZX Brake Swap! VLSD Info for 240s 1. KA24DEvelopment.com :: VLSD Swap Information 2. 300ZX N/A (Z32) 4.083 ratio final drive swap (for a q45 upgrade) 3. Install Guide: Q45 Differential swap into 240SX subframe [Archive] - FreshAlloy.com Forums Q45 Diff info Heres a list of what I know will fit on S13 and S14's, some are for KA turbo. A lot are well known but Id like to get the full spectrum. Heres what I have gathered.... All contributors will have their screen name attached to this updated page... ![]() (Duffman) Z31 Turbo (non SS model) clutch type +4/87: works with open diff output flanges. Use S13 case and cover (Bushido) Z31 Pad carrier for rear s13 calipers 300zx 90-96 N/A to s13/s14/s15/y32/y33 Calipers 26mm Aluminum (90 only) 91 & 92.5 early N/A and TT 30mm Aluminium, late 92.5-96 30mm iron both NA and TT - brake lines needed rotors MAF N62 BMC Brake booster Rear N/A Hubs Rear aluminum uprights Diff N/A has 4.08 gears can be used with pre 1/94 j30 or OEM 180sx axles wheels Ebrake assy coupled with R33 Brake lines (must have z32, or s14 5 lug rear hubs) Transmission with Mazworks adapter plate Z32 90 - 96 tt injectors (370cc) purples Calipers 26mm Aluminum (90 only) 91-96 30mm aluminium - brake lines needed rotors MAF N62 BMC Brake booster Rear Hubs Rear aluminum uprights Diff 3.9 wheels Ebrake assy coupled with R33 Brake lines Transmission with Mazworks adapter plate y32 Q45 to s13/s14/sr20det vvt and non Throttle body 370cc injectors (purples) only on the 94's Ignitor chips calipers rotors Rear hubs Differential 3.54 gears need to change axles or output flanges for 6 bolt for the 5 bolt j30 axles will fit in to the s13 Rear struts y33 q45 97-01 to s13/s14 Calipers Rotors Rear hubs Diff Ignitors Rear struts Y34 q45 01-06 to s13/s14 calipers rotors Diff Rear struts Rear hubs J30 to s13/s14 (Z28ricer) Front J30 5 lug hubs can be drilled out to fit OEM S13 bearings Rear hubs/axles/and diff (need all to work) z33 to s13/s14 Brembo brakes with an adapter rotors z34 to s13/s14 ] (Duffman)R34 torsen, GT-R non V-spec: unknown but I assume its 31mm 30 spline brakes rotors wheels r32 to s13/14/15 (Duffman) R32 and R33 GT-R only, non V-Spec clutch type: uses 31mm 30 spline output shafts. 3 out of 6 bolts line up (sort of) when using skyline output shafts or R230v output shafts (Q45 and turbo Z32). calipers rotors seats Eagle talon turbo 89-98 440cc Injectors (direct bolt in to for KA-T or S20DET) rx7 FD to S13/S14 210 LPH fuel pump Injectors but primary and secondary are different sizes Supra - s13/s14 440 injectors will fit with a resistor pack and top feed rail Sentra /SE-R spec-v to s13/s14 (EEK) Brembo calipers (SWAYRAY) you'll need a 1mm spacer/washer to center the caliper w/ pads onto the rotor.... those spec-v rotors are very similar to the R33 GT-R w/ brembos only painted gold rather than black (Stinky 180)the early 90s sentra ball joints are interchangeable Maxima - s13 (Bushido) Rotors (stinky_180) 90s maxima key ring light -> s13 (2 wires ![]() S13 to s14/15 s14/15 Seats s14/s15 Brakes s14 KA Engine/tranny swaps over with minor mods (EEK)s14/15 can use the s13 coilovers but must drill out the knuckle (Jspec240) must change the tops of the rear coilovers to the s13's S15 SR swap Requires Drive line and diff if you want your speedo working S15 Mirrors s15 Steering wheel S14 to s13 s15 s13 /s15 Seats front and rear s13 Seat belts from both will work as manual belts s13 Lower Control Arms are 15mm longer from s14 s14/s15 5 lug hubs ( need front spindles for s13 ) s15 rear seats S15 to s13/14 s13 The s14 vlsd will fit with a quick change of the cover. s15 SR swaps to both easily as dose the others however requires drive line and differential has the speedo instead of in the tranny. s13/s14 Seats front and rear This is off the top of my head. As posts are made (let me know if Im wrong as well) I will keep the info up to date on this first post so we wont have to search for them. This was a short example so please if you know of any OEM part upgrades from other cars... POST EM UP ![]() More to come
DREW SLIDE TO SIDE WORLD WIDE Feedback!! http://www.zilvia.net/f/showthread.php?t=182673 661 sliders Gymkhana @ buttonwillow http://zilvia.net/f/south-western-st...-sessions.html >> Bakersfield Hook up thread << Last edited by jspec240; 09-16-2010 at 08:53 AM.. |
![]() Join Date: Feb 2004
Trader Rating: (29)
Z33 brakes do NOT need any type of adapter. You need to re-drill the holes to accept the larger 14mm thickness bolts. Other than that, its a bolt on affair. Skyline r33/r32 gtr brembos and non brembos are also DIRECT bolt on.
You might want to add so are the Sentra SE-R spec-v brembos are bolt on esp for 4-lug cars unless you want to re-drill the rotors for 5-lug. S14/S15 suspension is interchangeable. S13/S14 fronts shocks/springs will work on either car, with the exception of the larger bolts needed or re-drilling the shock mounting holes to the front knuckle. All front seats from any s13/s14/s15 are a direct bolt in. S14/S15 rear seats are interchangeable. That's all that pops up in my head, There is way too much to list. Hence the SEARCH feature is VERY useful. |
#5 | ||
Thanks Instead of being sarcastic, why dont you spell it out a little more. Its gettin old when some one is trying to help others out and people want to hate. elaborate....or keep your shannanagans to your lonesome... Quote:
![]() Keep the positive tech info commin it will control inept posts/threads
DREW SLIDE TO SIDE WORLD WIDE Feedback!! http://www.zilvia.net/f/showthread.php?t=182673 661 sliders Gymkhana @ buttonwillow http://zilvia.net/f/south-western-st...-sessions.html >> Bakersfield Hook up thread << Last edited by jspec240; 11-02-2009 at 09:37 PM.. |
![]() Join Date: Jun 2009
Not sure if it was mentioned but J30 hubs can have the wheel bearings pressed out, S13 bearings pressed in, to be correct the groove for the lock retaining ring needs to be re-machined to a different spot due to the S13 bearing being a little wider.
This allows for a hub that bolts right on the S13 spindle, while using OEM parts. |
front/rear or both?? good info tho cause I can get two sets now
DREW SLIDE TO SIDE WORLD WIDE Feedback!! http://www.zilvia.net/f/showthread.php?t=182673 661 sliders Gymkhana @ buttonwillow http://zilvia.net/f/south-western-st...-sessions.html >> Bakersfield Hook up thread << |
^^^ Thank you sir... I think I just collaborated a lot of spread out threads into one for easier searching. last thing we need is haters.
we need more like you bro.....
![]() Join Date: Jan 2009
So i take it these 5 lug hubs will now fit on an s13 Correct. So the j30 bolt pattern is the same as s14 and s15 z32. 114.3?
Precision intercooler rated to 600HP Used **FOR SALE** http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT |
#12 | |
![]() Join Date: Dec 2002
To the OP- There's a lot of this type stuff floating around, no real point in making one big thread since everyone will throw in useless posts or bad info. For example, the Z32 caliper info you have listed is wrong. ALL '90-'92 calipers are aluminum, '93-'96s are iron, NA or TT. Only the 1990 NA models are 26mm though, everything else is 30mm. Case in point, if you're going to bother making the list, you have to make certain it's dead on accurate or some kid next year is going to skim across it and cry about it being misleading.
^^^ You are right about the calipers but I beg to differ about creating this thread, thanks for helping but just like you said there is a lot of this stuff "floating around" hence the creation of this thread. The whole point of creating a thread is so there is "less" searching to do.
If you would have read the whole post I did mention that if any of my info was incorrect to LMK which was done and corrected. so If that was the only thing wrong then I think I did a good thing by doing this.
#15 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
s14 inners are thicker and stronger. i'd just get some aftermarket ones
Slip Gypsies Blog Quote:
#17 |
Supra 440 injectors will fit with a resistor pack and top feed rail
#18 |
Id like to start the thread back up again....
the bosch fogs that come on the older pathfinders and older altimas are sometimes listed as OEM ones for the s13. thats where you can get the switch and harness aswell.
#20 | |
![]() Join Date: Dec 2008
![]() Feedback Score: 35 reviews
well your post wasnt any better sooo.....gtfo..?
-Jorge |
#21 | |
That is correct but you'll need a 1mm spacer/washer to center the caliper w/ pads onto the rotor.... those spec-v rotors are very similar to the R33 GT-R w/ brembos only painted gold rather than black. i'll be having kits of these for under $1200 up soon.... ![]()
http://www.thenismoshop.com |
#23 | |||
Im sure Nico has stuff that is not here so if you see something just copy and paste it here plse ![]()
#24 |
![]() Join Date: Nov 2006
I'm not so sure about that Z32 TT rear hub. I heard that the axles are bigger so the hole for the axle is also bigger. GTR Axles and diff are bigger and stronger and bolt-on(5bolts).
#25 |
Yea they wont work on the 240s thats why everyone gets the N/A hubs which are a direct bolt on
#26 |
I just found an archived post from duffman explaining Diff options
![]() I'm going to fix/expand this: Direct Fit: 91-93 240sx VLSD 89-90 JDM S13 VLSD 96-98 JDM S13 VLSD JDM S14 and S15 VLSD (with S13 diff cover swapped on) R33 Skyline (R34 as well?) VLSD (with S13 diff cover swapped on) 95-98 240sx VLSD (with S13 diff cover swapped on) 1/94+ J30 VLSD (with S13 Diff cover swapped on) Fit with pre-1/94 J30 axles OR JDM S13 axles OR R32 Skyline axles OR 6 bolt vlsd output flanges OR shaved open diff output flanges: 90-96 NA Z32 VLSD Pre 1/94 J30 VLSD 91 - 95 JDM S13 VLSD JDM R32, A31 and others Non VLSD oem options: Z31 Turbo (non SS model) clutch type +4/87: works with open diff output flanges. Use S13 case and cover R32 and R33 GT-R only, non V-Spec clutch type: uses 31mm 30 spline output shafts. 3 out of 6 bolts line up (sort of) when using skyline output shafts or R230v output shafts (Q45 and turbo Z32) S15 torsen, 6spd turbo only: use S15 output shafts, late S14 VLSD might work, R230v might work with 3 out of 6 bolts lining up. R34 torsen, GT-R non V-spec: unknown but I assume its 31mm 30 spline 350Z/G35 torsen: supposedly R205 according to NISMO japan website. Unknown fitment in a 240sx.
#27 |
All you ever wanted to know about differentials – NICO Club
Differential swaps for the 240sx – NICO Club Aftermarket Differential Install – NICO Club
-Jorge |
