![]() Got stock sr20det, greddy fmic, apexi n1 ehxuast, downpipe, few other things. What psi should i use at the track that would be totally safe? Ive heard 14 is totally safe so let me know waht u think.
#2 | |
![]() Quote:
![]() -Alex B. ![]() |
15
an sr20det comes stock with 7psi as you already probably know, and the stock turbo is safe up until 15 psi, but that is max until power falls off, with much pressure, you would need better injectors and a better blowoff probably
![]() Join Date: Mar 2003
i have walboro fuel pump, nismo regulator, fmic,exhuast, blow off and i run 14 psi well actuall 14.5 everysingle day, no problems at all
ANTI-STRETCH NAZI Vortech Supercharged Vh45de S14 V8nissans.com |
#6 | |
![]() Join Date: Dec 2004
ZEROYON WEBSITE IS HOMO NEW SITE: blacklinux.com/innersanctum/index.php |
#7 | |
![]() Join Date: Nov 2004
#9 | |
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
whats the advatnage of an adjustable FPR?
HouseBuyers365.com Quote:
#10 | |
late daryl
![]() Join Date: Feb 2004
Daryl...you're a bit wrong. You will have no need to pump up the base fuel pressure with larger injectors and/or more boost.
I ran the stock FPR with my stock setup, and I also ran the stock FPR with a walbro, 740cc injectors, and a GT2871 @ 21psi. An adjustable FPR is used on some cars with upgraded fuel pumps (such as DSM's) since the stock FPR can't bypass enough fuel back to the tank, therefore the fuel will build up excess pressure in the rail, and cause you to run rich regardless. In these cases the aftermarket FPR is being used more for the excess flow out the return port than to adjust base FPR. On most other cars there really is no need to increase base fuel pressure unless you're using it to artificially increase injector size (real sketchy) or for other reasons, which are rare enough that you probably have your own idea (right or not) as to why you're doing it. ~matt
it's not turbo lag...it's foreplay ![]() '01 Ford Excursion Limited. Powerstroke Diesel Coming in spring: ??? |
#12 | |
Thanks Oh and I am from albany ![]()
100% correct. You'll be good with just an S-AFC and 550's. Sell the FPR
![]() Where in albany? I'm in Troy for school (go to RPI). I'm actually back in las vegas (home) for the time being, but go back east in january. I take it you're overseas military? ~matt
#14 | |
I am from Downtown Albany, down by the Pepsi Arena, went to Bishop Maginn H.S., I know RPI, you must be a smart one eh? Engineer? Yeah 13 years Marines...will retire in 7, staying in Japan for evar.. late Daryl
