Ka24de oil filter relocation
Hi there, I had some questions about running an oil filter relocation on the ka24de.
So I would like to install an oil filter relocation kit on my ka24de S14. I'd like to put some gauges in for temperature and pressure & avoid having to clean up the mess off my engine mount. There are some that will work but then require you to use a different filter. Any and all help is appreciated. Oil filter relocation kit https://www.phase2motortrend.com/pro...orlsr20-gd.htm https://www.enjukuracing.com/product...n-sr20det.html https://bloxracing.com/products/oil-...relocation-kit https://store.partsshopmax.com/unive...ct-description ----- Ka24de oil filter specs MOUNTING THREAD SPEC 3/4 -16 No bypass relief valve setting ADD SIZE Sr20det oil filter specs MOUNTING THREAD SPEC M20X1.5 Bypass relief valve setting YES ADD SIZE ----- 1. Is there a kit that you guys know of that will literally just relocate the oem filter, and NOT change the thread spec? 2. Is there a kit that I SHOULD use because it is inherently better to change to XYZ filter? Example would be the Circuit sports kit using the Frontier oil filter "PN 15208-65F0E fits the best. $7 oem oil filter for the 2019 frontier" 3. Do you guys know a part that would replace the adapter that the relocated oil filter threads onto? Essentially it would be a circuit sports kit, but just used with a different piece that retains the 3/4-16 thread spec on the filter. Kind of like this piece https://www.summitracing.com/parts/e...YaAh-BEALw_wcB Maybe I could use that and get fittings so it works with the -10 AN lines and keep my regular ka24de oil filter? Thanks again |
#2 | ||
Sup dude
![]() Join Date: May 2002
If you search summit for "10an oil filter mount" a lot of them are 3/4"-16 because that nipple size also fits a common Ford filter (the Motorcraft FL-1A). I found tons of them at various price points.
If you wanted to be really extra you could swap your KA's stock oil filter block for one from an Altima and use VQ/VK spec M20x1.5 filters. |
