Old 11-11-2022, 04:57 PM   #1
240boosted
240boosted has a little shameless behavior in the past
Fully built sr20det keeps overboosting
Hey I have cant figure this out to save the life of me. I have a mazworx setup with a g30-770 kit with a haltech elite 1500 running e85 with dual valve conversion from them and there stage 3 heads and 272 cams with there manifold and a 44 mm tial watergate. I checked all the lines which are push lock lines and I keep getting boost spikes after 6k rpm. If I take out the haltech electronic boost controller it still overboost on just wastegate after 6000 rpm. my tuner cant figure out why it’s keep doing it past 6000 rpm and I running 14.7 psi spring with open dump and 3 inch full exhaust
240boosted is offline   Reply With Quote
Old 11-11-2022, 05:39 PM   #2
slider2828
slider2828's Avatar
I have heard this happening from MotoIQ, where the external wastegate flange when welding on the manifold isn't round causing issues. Also he said the external wastegate could have some sort of build up causing the valve in the wastegate not to open correctly or all the way.... Easiest way, try swapping out the EWS, if that doesn't work, then check the manifold.
MotoIQ had a youtube video on wastegates.
Turn and Burn!
Old 11-11-2022, 05:59 PM   #3
240boosted
Ok yes this is a mazworx manifold there kit came with the tial 44mm I was looking possibly at the turbosmart one brand new build my old build a different turbo and stock manifold setup still had boost creep ugh..
Old 11-11-2022, 06:04 PM   #4
240boosted
I going to test out the wastegate with my friend maybe there something wrong or the diaphragm is pinched. The fire at the bottom i have is a v band.
Old 11-13-2022, 07:15 AM   #5
jr_ss
Before you go changing a bunch of things, what are your controller settings? Is the dump plumbed back into the exhaust stream? How is the tubing ran to the gate? Is it plumbed closed loop or open loop?
Old 11-14-2022, 07:19 PM   #6
240boosted
So I bought the g30-770 kit from mazworx and its open dump pipe with their manifold and tial 44mm wastegate. For controller are you taking about what electronic boost controller I have that is a max valve which I had last setup and was overboosting so idk if that max valve is the issue.
Old 11-15-2022, 05:57 PM   #7
jr_ss
So the last setup over posted and this setup is too. I think you have a component issue, not a manifold/turbo/wastegate issue.
How is the tubing ran to the Mac valve? What are the boost control settings? If you remove the Mac valve, does the car overboost?
Old 11-16-2022, 06:13 PM   #8
240boosted
The Mac valve on the turbosmart I?m almost positive was set up wrong. I am running push lock fittings with plastic airline break hose. I?m gonna try to remove the Mac valve this week and test.
Old 11-15-2022, 06:29 AM   #9
tuzzio
tuzzio's Avatar
Mac* Valve.
Is it a genuine Mac valve, or a knock off?
Old 11-15-2022, 08:51 AM   #10
240boosted
It’s a turbosmart valve but possibly setup wrong
Old 11-15-2022, 08:54 AM   #11
240boosted
I had a 10 pound spring in but I hear a lot people on different forums said they had same issue possibly set it to a 12 pound spring?
Old 11-15-2022, 09:33 AM   #12
inopsey
inopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant future
im confused about your setup. are you running a haltech boost controller and a tubosmart valve at the same time? in the op you say that it still overboosts when you take out the haltech boost controller but if you take out the turbosmart valve does it still overboost on the wastegate psi?
overboosting on wastegate psi would indicate a different set of problems vs anything being used to control/change boost from wastegate psi
inopsey is offline   Reply With Quote
Old 11-16-2022, 06:11 PM   #13
240boosted
I was running the haltech elite 1500 sorry for the confusion I did not mean haltech boost solenoid. I am running the turbosmart solenoid, but I?m pretty sure that I have it set up wrong. I am going to check if I?m overboosting still on wastegate this week
Old 11-17-2022, 09:16 AM   #14
nick_d_240sx
nick_d_240sx's Avatar
nick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymore
Thought you already did that?
Is this how it's hooked up?
Can you share a picture of your setup?
S13
nick_d_240sx is offline   Reply With Quote
Old 11-17-2022, 09:09 PM   #15
240boosted
I am guessing also that one would be good since I have 3 inch down pipe
Old 11-17-2022, 09:00 PM   #16
240boosted
Ya this is how it was setup
https://ibb.co/g4w8hsG
https://ibb.co/Bqhxx2h
But I try this first I was told to try
https://ibb.co/GPfQLHF
Old 11-17-2022, 09:03 PM   #17
240boosted
I had port 3 to turbo housing and top of waste 2 cents middle one the the other one to bottom wastegate but now I going change it and see
Old 11-17-2022, 09:35 PM   #18
240boosted
And have the other plugs blocked for air port and should I use blue locktight on the thread top bolt hold wastegate down
Old 11-18-2022, 08:54 AM   #19
nick_d_240sx
I would take the solenoid out of the equation and run the boost source from the turbo directly to bottom port on WG and leave top open like you had it. This should be minimum spring boost pressure.
Here's a good read.
S13
Old 11-18-2022, 09:09 PM   #20
240boosted
Here's a good read.
Ok I read the em and for for air ports that are not being used do they need to be capped off
Old 11-19-2022, 11:04 AM   #21
jr_ss
The air ports on the solenoid do not need to be capped. The extra port on the gate should be open to atmosphere.
Old 11-19-2022, 09:14 PM   #22
240boosted
Ok so all the air ports at the lower should be open and then I should leave open at the bottom except for the one I using and then the port top leave open dumb questions wouldn?t that mean all them would be open.
https://ibb.co/s2B9mWv
Old 11-19-2022, 09:44 PM   #23
jr_ss
You?re bypassing the solenoid. No tubing should be running from it to the turbo or wastegate. Exactly as below?
Old 01-09-2023, 07:52 PM   #24
240boosted
Sorry I been testing still done every which way still seems to overboost.
Old 01-09-2023, 07:55 PM   #25
240boosted
And a final note do you think bc I have like no back pressure and castles exhaust I need a little back pressure?
Old 01-10-2023, 04:26 PM   #26
240boosted
here are some photo
https://ibb.co/njvDhMv
https://ibb.co/fH9nhWc
https://ibb.co/7QVnpX6
https://ibb.co/zXXdrrV
Old 01-10-2023, 10:18 PM   #27
inopsey
cant see your wastegate in those pics
Old 01-11-2023, 04:04 PM   #28
240boosted
So it’s the tial wastegate hard take a picture of it but I have the lower and upper air port use and the other air port at the top middle should I leave that and the other air ports open?
https://ibb.co/XJQ59WM
Old 01-11-2023, 04:10 PM   #29
jr_ss
So, you have an air ran to a single port on the gate?
What model Tial? MVR?
ONE port on the gate, not two..
Old 01-11-2023, 06:15 PM   #30
240boosted
Yes it’s a 44 mm tial mvr
