09-13-2019, 01:37 AM | #1 |
For Trade: 1997 bmw m3
trying to feel out to see what trades id get for my m3. interested in kouki s14's, ae86's, FC t2's(idk what the price range of these are nowadays)
throw me offers i guess? car's just sitting in the garage. was being built as a street-legal track car. Everything that has been done to "bulletproof" this car and make it as reliable as possible apart from the minor issues, its' ready to throw on track. pm me 1997 BMW M3 238k miles Motor replaced by BMW under warranty at 70k(claimed by the previous owner. I have no proof of this other than the motor feeling great) Clean title Clean carfax - shows one fender bender reported to PD/insurance. Front Left fender was replaced with an OEM fender. This is the only non-matching VIN. car shows no chassis/frame damage. Suspension: Dinan sway bars front and rear Oem X brace Bc coilovers with swift springs(unsure of the rates) AKG poly subframe bushings(225k) AKG poly trailing arm bushings(225k) AKG diff mount bushings(225k) New OEM Front Control arms+bushings(225k) SLR Adjustable Lollipops (not installed) Reinforced Rear Swaybar Mounts (210k) Reinforced Rear Shock Towers(210k) Engine: Dinan Tune Achilles Motorsport Rebuilt Vanos(220k) Stewart water pump(220k) OEM Z3m radiator (220k) New OEM expansion tank and hoses(230k) New Oil pan, rear main, filter housing, valve cover, intake, exhaust gaskets(220k) New oil pump with welded oil pump nut(220k) AKG 75A engine/trans mounts(237k) Drivetrain: UUC M5 Clutch(220k) UUC Single Mass flywheel (220k) AKG Short Shifter(237k) AKG Selector Rod(237k) New OEM Selector Rod bushing(237k) Rally Road Transmission Brace (237k) 3.38 LSD(210k) Bimmerworld Stud Conversion Interior: Headliner Redone Delrin Clutch and Brake Pedal Bushings(237k) BimmerWorld Clutch Stop (237k) Momo Hub (237k) Works Bell Quick Tilt Momo V35 (not included in trade. will come with stock steering wheel installed) BK Seat Brackets (237k) Sparco Pro2000-II (possibly included in trade) Schroth DOT-approved 4-point harness Exterior: BBS CH007 17x8.5 +38 245/40 Federal 595SS Depo Glass Headlights Euro Tail Lights Fog Light Delete Issues: Power steering sweats fluid(top off about every 3k or so) Brakes could use a refresh with some better pads(running on OE equivalent pads right now) Passenger wheel rubs the inner body on full lock turning left due to positive caster. the SLR adjustable lollipops that are included(not installed) will solve this by allowing you to adjust caster. typical "check brake light circuit" pops up randomly on the OBC. Brake lights still work fine. can be resolved with new light bulb sockets. "license plate light out" pops up on the OBC when you turn on the lights due to LEDs. Once cleared it doesnt come back unless you turn the car off and back on ABS light on due to faulty wheel speed sensors on both front wheels. never changed them since i planned to do so when i refreshed the brakes. ACS light on due to traction control delete Airbag light on due to the steering wheel and bucket seat(can be cleared with some resistors etc) Fenders are rolled to fit wider/more aggressive wheels. Paint is good but has paint chips around the vehicle due to age. rolled area of the rear fenders have paint chipping. I clear coated the raw areas with a touch up pen to avoid rust building. Outer window trim could use a refinish/respray for some reason i cannot find any interior pics but will take some in the morning and post them up here ASAP. PMs are fastest. |
