11-16-2017, 03:18 PM | #1 |
My JDM wet dream. Spotless s14.5.
Tis' a sad day but I'm actually excited to sell this and hit the road. Life changes and i think I'm ready. Only interested in trades for small (decent) RV's. I picked this up from a Zilvia member in 2011 and it has been my obsession since. I love it, i love to look at it, and i love making sure she is spotless and in perfect working order.
It's been in Cali for its entire life so no rust, and has never even seen rain since the exterior restoration. Pinch welds are great. Car runs, drives, and sounds completely amazing! Asking $12,500 OBO. I'm Really looking for a class b camper or small RV, this sale will fund that. I know what she is worth and this is an EXTREMELY reasonable starting price. Contact: Addy at 719-966-2324 Mods are as follows: CHASSIS: 1995 S14 SE Fully Loaded from the factory, Leather Interior, ABS, Sunroof, 5lug, Se gauges. currently sitting around 217,500 EXTERIOR: Custom color based on a factory Mercedes CLK Purple. The entire exterior was redone late in 2011 (kept the same color) all fenders rolled and fronts custom shaped for s15 front prior to paint (not cheep aftermarket fiber fenders). Also has an entire extra coat of clear sprayed (shop said over a gallon of clear on the car). *935/5935 Quartz Blue Metallic I believe was the original color JDM Nissan OEM Window Visor JDM OEM Naven rear valences OEM Usdm kouki side skirts OEM USDM SE wing S14.5 Front End Conversion (all parts imported by west covina nissan with receipts) S15 Nissan OEM Metal Hood S15 Nissan OEM Headlights S15 Nissan OEM Radiator Support S15 Nissan OEM front bumper S15 oem bumper support Custom S14.5 Fenders (80% metal / 20% Fiberglass, shaped perfectly) INTERIOR: S15 power Fc with commander (MAFS version) Blitz Dual SBC Boost Controller Greddy 60mm Boost Gauge (Warning/Peak Hold) Greddy 60mm Fuel Pressure Gauge (Warning/Peak Hold) Greddy 52mm oil pressure gauge AEM UEGO wideband Nice Alarm with two way pager and extra sensors S15 steering wheel Momo weighted shift knob R32 skyline seats with modified rails so fits like stock Alpine head unit MB quartz component front speakers Infinity component rear speakers Memphis st1000D mono subwoofer amp 10" infinity subwoofer in a truck box centered under the rear deck WHEELS/BRAKES: -18"x8"frt, 18"x10" rear Blitz Technospeed Z1 wheels (refinished faces, gold hardware perfect offset with no spacers) -BFgoodrich sport comp 2 tires, 225/40/18 front. 265/35/18 rear -350z track rotors with 30mm cast z32 calipers with spacer for the Front Brakes -z32 full rear brake conversion with r33 cables (works perfect) -Earl Steel Braided Front Brake Lines -unknown steel braided rear lines -1" brake master cylinder ENGINE: HKS Gt2835r pro-s Hks adjustable internal waist gate actuator Wisesquare (Berman) equal length bottom mount manifold Blitz LM Intake (for z32 mafs) Blitz 1.3bar Radiator Cap Greddy type s BOV recirculated (custom intake tube) Greddy type-R fmic Greddy upper intake manifold plenum KOYO Aluminum Radiator Nismo Motor and trans Mounts Power Enterprise Upper/Lower Radiator Hoses Tomei Fuel Pump Upgrade Tomei fuel pressure regulator Tomei rocker arm stoppers Denso 850cc side feed injectors Z32 n62 mafs Taka Steel Braided Turbo Lines S14 ka ac compressor on Codyace bracket (AC is ice cold) Mr gasket copper Exhaust Gasket Full three inch exhaust with stock looking straight through muffler that passes for stock looks wise Megan 70mm Downpipe w/ custom Flex section welded in and angle changed so its away from the floor Custom 3" Test Pipe BLOCK: ACL main bearings ACL rod bearings ACL thrust washers ARP headstuds Apex headgasket OEM rings Balanced crank Block and head both hot tanked BC springs BC retainers Greddy 256 264 11.6 lift cams Custom modified vtc sprocket by Brett Dempsey engineering- retained vtc even with cams and springs. Custom product. OEM oil pump EVERY gasket and seal NEW Peak Perfomance thermal intake gasket OEM Valve seals Mild port and polish Must casting marks in head are ground down Peak preformance magnetic oil drain plug Arc large oil pan upgrade Motor had 6,000 miles when I installed at 198,000. Car currently sits at 217,500 so just under 20K on motor rebuild. TRANSMISSION: OS Giken s13/14 sr20det steel super single clutch kit installed @ 206,571 Nismo slave cylinder Nismo pivot ball Nismo trans mount Circuit sports stainless slave cylinder line New trans front cover installed with clutch Rebuilt stock clutch pedal assembly Pilot short shifter kit Red Line Transmission Fluid S13 ka transmission in s13 sr bell housing SUSPENSION: Apexi N1 Pro Coilovers East Bear Pillowball Tension Rod Cusco ruca's Cusco front upper strut tower bar Nismo power brace S15 differential Hlsd (perfect for grip) Large red front sway bar, not certain on the brand Other random bushings replaced with energy suspension kit Corner balanced and aligned buy west end. The best of the best So there you have it. 217,500 on the chassis, about 20k on motor, nearly flawless paint, ice cold ac, perfect handling, and built with all the love in the world. When i built her it was with the intention to daily, so everything is there to drive (and get looks) everyday. She just came out too nice for me to leave on the street anywhere so shes been garaged ever since body was done. She comes out for canyon runs and that's about it. All mods have been for grip, longevity, and comfort. She only gets Valvoline vr1 racing oil (20w50) and oil has been changed every 1000 miles or so since installing. Car will come with a folder of receipts, a bunch of spear or leftover parts from the build, original touch up paint and WAY too many pics of the build if you want them. I reserve the right to refuse sale to anyone i do not believe will take care of my baby and i might cry as she drives out of my life. Located in San Fernando Valley Addy- 719-966-2324 Last edited by Socalgal; 11-20-2017 at 11:37 AM.. |
11-16-2017, 05:52 PM | #7 |
Pretty much. They keep quiet on the local ads haha
Tuners are big bullies |
11-17-2017, 08:33 AM | #11 |
Thank you everyone for the comments, the positivity is extremely motivating. It is Ma'am by the way, good catch whitey13 .
Shipping may be an option, if you are a serous buyer contact me. I have a lot more media to share. I realize zilvia made my pics super small but not sure what to do about that. In the meantime I will try to upload random ones here and there, little teasing is better then nothing. |
Tags |
s14.5, s15, skyline, sr20det, turbo |
