![]() So I just replaced my engine harness with an engine harness from wiring specialties (ka24de). The car cranks but won't turn over. The car was running before I changed the harness, my 240 is a 1998 kouki with an engine out of a 1996 zenki, any help is appreciated!
Remove your glove box. 2 8mm interior screws on the bottom and there’s a brown plug on the right make sure that’s plugged in or else nothing will work.
If it is plugged in, make sure your starter and alternator are hooked up. There should be a black w/ yellow stripe wire going to the starter as a start signal. Make sure that’s hooked up. It’s really common that those come disconnected. Sent from my iPhone using Tapatalk |
Tags |
240sx, harness, kouki, nissan, s14 |
