Old 09-06-2017, 08:10 PM   #1
Jdm_enthusiast_23
Jdm_enthusiast_23's Avatar
Jdm_enthusiast_23 is an unknown quantity at this point
1989 Mazda RX-7 fc3s s5 turbo ii! Jdm! Rhd!
1989 Mazda rx7 turbo ii fc3s s5 true jdm import and has matching and clean jdm VIN numbers and 100 percent street legal. Chassis has 132,000km (80,000 miles) and the motor has 5,000 miles on the freshly rebuilt street ported motor.
CAR WILL NOT COME WITH REGAS OR THE NARDI! Read the detailed spec list before asking any questions that may already be answered!!!
Maintenance: always changed the oil every 2000 miles and premixed using idemitsu 2 stroke oil. Fresh oil change, spark plugs and wires, trans oil, diff oil, new rotors and pads, new slave & master cylinders, little lines and vacuum hoses here and there etc etc..
Everything works, Ac blows cold. Heat works, wipers work, radio, etc etc.. I daily drove the car and will continue too on nice days so mileage will slowly go up.
Power: Car dyno'd 250whp &300wtq @7 psi on a conservative tune. Maxed out the stock injectors, with upgraded injectors and a retune the car will make 330-350whp and similar wtq @14-15psi approx. the motor although is built for 500 which is about the time where they need to be studded.
Engine: freshly rebuilt 13b, rotors were sent out to a machine shop and got side clearanced, face clearanced and balanced the entire rotating assembly. Intake and exhaust ports have been streetported. Oem everything except apex seals by e&j and new bearings were pressed.
-Medium lightweight flywheel
-3 puk carbon Kevlar aftermarket clutch
-Knight-sports/turbonetics hybrid s320 turbo ported wastgate
-Full kakimoto exhaust
-Sard blow off valve
-Knightsports ebc iii digital electronic boost controller
-Apexi boost gauge
-Innovative wideband
-Greddy oil filter relocation
-Greddy oil cap
-mishimoto oil catch can (not hooked up but lines are there)
-Hks front mount intercooler and pipping ($1000)
-Brand new koyo rad
-Bosch 450 internal fuel pump
-Apexi power fc ecu and datalogitech tuner ($1200)
Brakes: Nissan r32/z32 4 pot piston brakes with fresh rotors and pads with a Nissan r32/z32 reservoir.
Exterior/Chassis/Aero: rust free and accident free. Car has been resprayed in the past and holding up fine, cleans up real nice with a basic detail. Small chips here and there that are typical on a 30 year old "racecar" but no major defects in the paint.
-Authentic BN sports kit ($1900)
-Authentic Re-Amemiya carbon fiber gt wing chassis mounts ($1300)
-Custom hood scoop
-Headlight duct
-Bomex aero Mirrors
-Work emotion 11r 18x9.5 +20 square, hyper black ($1600)
Interior:
-Authentic Bride Digo ii ($1000) with bride lowmount rails.
-Takata harness 4 point (driver seat only). Driver and passenger still have oem seats belts installed and in working order.
-Aftermarket head unit with usb and aux ports, speakers work fine but I rarely use them.
-Nrg Wood grain steering wheel mounted with a aftermarket hub adapter.
-Razo pedals
-Brand new battery relocated to behind the passenger seat for better weight distribution.
-Short shifter with new bushings.
Suspension:
-Apexi N1 coilovers ($2100 new)
-Cusco front and rear strut bars ($300 new)
-Cusco safety 21 roll cage 7 point ($900 new)
-Cusco under chassis brace
-Front and rear sway bars
-2 way Kaaz diff ($1300 new)
Cons: power steering pump went bad last week but I'll either have another one on the car or at least thrown in with the car. And it's terrible on gas lol
16,000 OBO as you can clearly see the has car top notch quality parts and more than 25k in parts alone not including the rhd value of it.
Link to some glamour shots:
https://www.flickr.com/photos/156196.../shares/12731M
******* NO TRADES! *********
Jdm_enthusiast_23 is offline   Reply With Quote
Old 09-06-2017, 08:30 PM   #2
na6miata
na6miata is an unknown quantity at this point
Does it come with an LS engine to put into it to replace the rotary?
na6miata is offline   Reply With Quote
Old 09-07-2017, 02:22 PM   #3
Jdm_enthusiast_23
Lmao no sir it does not. Wyd Sunday ? Hmu on messenger bro
Old 09-07-2017, 10:18 PM   #4
na6miata
Well shit, I was only interested if it came with an El Es Juan
Old 09-06-2017, 08:59 PM   #5
ReallyWantsA240SX
ReallyWantsA240SX is an unknown quantity at this point
Cracked bumper is buggin' me.
ReallyWantsA240SX is offline   Reply With Quote
Old 09-07-2017, 02:24 PM   #6
Jdm_enthusiast_23
Thankfully it's not a show car so I'm not too bothered by it. Plus it's only frp which is the easiest material to be touched up on.
Old 09-06-2017, 09:07 PM   #7
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
Idk what that fool is talking about swapping in an ls? Glws
smoked240 is offline   Reply With Quote
Old 09-07-2017, 02:25 PM   #8
Jdm_enthusiast_23
Hahaha that's my homie just trolling! Thanks mate!
Old 09-07-2017, 01:08 AM   #9
Good_Carma
Good_Carma is an unknown quantity at this point
can i get it with out the rotary???
Good_Carma is offline   Reply With Quote
Old 09-07-2017, 02:27 PM   #10
Jdm_enthusiast_23
No you can't. It's a rx7; r stands for the rotary, take the rotary out its not a rx7 anymore. Thanks for the bump!
Old 09-07-2017, 07:04 AM   #11
Avayo
Avayo is an unknown quantity at this point
This thing is gorgeous, glws!
Avayo is offline   Reply With Quote
Old 09-07-2017, 09:42 AM   #12
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
the cars that pop up in this FS section never cease to amaze me.
one of my favorite Japanese sports car ever produced. this car is beautiful. GLWS
jumpman2334 is offline   Reply With Quote
Old 09-07-2017, 02:28 PM   #13
Jdm_enthusiast_23
@avayo
Thank you both! I appreciate the kind words!
Old 09-07-2017, 02:28 PM   #14
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
its like an immaculate version of Hert's car lol
HellaSexyS13 is offline   Reply With Quote
Old 09-08-2017, 09:28 AM   #15
Jdm_enthusiast_23
Hahaha not anymore! His new setup is gorgeous! But won't last long !
Old 09-08-2017, 01:30 PM   #16
Jdm_enthusiast_23
bumpppppppppp
Old 09-11-2017, 07:48 PM   #17
Jdm_enthusiast_23
Still available!
Old 09-12-2017, 01:04 PM   #18
Sirdriftsalot
Sirdriftsalot's Avatar
Sirdriftsalot is an unknown quantity at this point
Someone buuy this car its dope af and sounds like hell
Sirdriftsalot is offline   Reply With Quote
Old 09-13-2017, 08:17 PM   #19
subiesean
subiesean's Avatar
subiesean is an unknown quantity at this point
super freaking awesome car. Love it.
I change cars too often...
Ho.Mo.Co.
subiesean is offline   Reply With Quote
Old 09-15-2017, 01:50 PM   #20
Jdm_enthusiast_23
Thanks for the kind words mate !
Old 09-15-2017, 02:17 PM   #21
TheRealSy90
TheRealSy90's Avatar
Oh wow, this RX7 is gorgeous.
Such a good signature.
Old 09-17-2017, 06:43 PM   #22
Jdm_enthusiast_23
Thank you!
Old 09-19-2017, 01:53 PM   #23
Jdm_enthusiast_23
PRICE DROP! 16k OBO
Old 09-20-2017, 08:04 AM   #24
DrKarrot
DrKarrot is an unknown quantity at this point
Bump for an FC worth the (ragged out) FD price.
How well do those 18x9.5 +20 emotions fit in the back?
DrKarrot is offline   Reply With Quote
Old 09-21-2017, 04:42 PM   #25
Jdm_enthusiast_23
Flush/slight poke if any with a meaty tire
Old 09-21-2017, 07:29 AM   #26
SilverStiyle
SilverStiyle is an unknown quantity at this point
BUMP for an awesome car from a great guy! GLWS and get your hatch done already bruh, my sileighty will look better than it but thats okay.
It was rubbish when it was new,it was built by idiots,and it's rubbish now
SilverStiyle is offline   Reply With Quote
Old 09-21-2017, 04:41 PM   #27
Jdm_enthusiast_23
Hahaha thanks homie! I really appreciate it.. we will see about that
Old 10-02-2017, 10:15 PM   #28
Jdm_enthusiast_23
Bump! Looking into trades! Must be either a rwd Manual jap car aka is300,altezza, r32, laurel, jzx90, soarer etccc..
Old 10-03-2017, 01:26 AM   #29
MrMarinakos
MrMarinakos is an unknown quantity at this point
1j it puss
MrMarinakos is offline   Reply With Quote
Old 10-03-2017, 08:45 AM   #30
LongGrain
LongGrain's Avatar
I would consider trading for this. let me know if you might be interested and I can give you further details.
Apparently I’ve been off of forums for so long I can’t figure out how to post photos anymore. Hopefully this link works.
https://flic.kr/p/YhbTTS
LongGrain is offline   Reply With Quote
jdm, mazda, rhd, rwd, rx7
