03-11-2017, 10:35 AM | #6 |
Trader Rating: (81)
Feedback Score: 81 reviews
I thought all the Nismo diffs use special input shafts. Are u certain the stock shafts will work?
Sent from my SM-G930T using Tapatalk
03-11-2017, 11:04 PM | #8 |
Not all, the earlier versions of the Nismo 2 Way LSDs stateside that were being sold in the early 2000s were direct drop-ins into open diff. pumpkins and stock shafts were also utilized. I currently have one on my car. You would have to know which version of the Nismo 2 Way which is being for sale here.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd |
03-11-2017, 09:51 PM | #10 |
You can't use the stock shafts. I found that out the hard way from when I bought a 2 way and someone said that my shafts would work. Installed the diff and everything, put the car in gear and heard the rear end grinding.
The Nismo 2 ways are 30 spline 31mm. s13, s14, j30 stock shafts are 29 spline 30mm. I had to source s15 6 bolt 3x2 shafts for it to be a direct fit for me since I am running 6 bolt 3x2 axles. Q45 should work too, but then you will have to have the right bolt pattern axles and may have to cut the shafts. |
2way, lsd, nismo, r200 |
