Old 09-18-2016, 11:22 PM   #1
Edan200
Edan200 is an unknown quantity at this point
SR Loud bang
hey all,
I'm having a problem with my drift car where if i drop the clutch from revs higher than 4k, there is a loud bang from what i assume is the diff. Obviously i'm not too sure whats causing it, has anyone had this problem before and could help me out?
pretty new to the sport and to cars but i know the basics, so any help would be wonderful.
cheers
1995 s14 sr20det 200sx
Edan200 is offline   Reply With Quote
Old 09-19-2016, 12:22 AM   #2
lunchmeat
lunchmeat's Avatar
lunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond repute
For starters, check your rear subframe and diff bushings.
lunchmeat is offline   Reply With Quote
Old 09-19-2016, 12:44 AM   #3
deolio
deolio's Avatar
get under your car and have a friend drop the clutch to see what it is
rip noob
Old 09-20-2016, 11:31 AM   #4
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
rip noob
Make sure the wheels are on the ground though so it'll be loud enough to hear. I suggest laying in front of the front bumper.
It's your bushings out back - probably diff bushings. Order solids. Bye.
SupaDoopa is offline   Reply With Quote
Old 09-19-2016, 11:07 AM   #5
jedi03
have had diffs separate inside on trucks that sounds like that...but yes rear up in the air and run it...move stuff around...
Old 09-20-2016, 09:29 AM   #6
shawn1331
shawn1331 is an unknown quantity at this point
maybe a cv shaft has some play? or subframe bushings. probably subframe bushing
shawn1331 is offline   Reply With Quote
Old 09-21-2016, 10:12 AM   #7
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
i came in here expecting an nsfw thread
v disappointed
@dangerdamian
STEEZxIT is offline   Reply With Quote
Old 09-21-2016, 10:53 AM   #8
DenkiMan!
DenkiMan!'s Avatar
DenkiMan! is an unknown quantity at this point
yea OP doesn't even need his flame suit on. zilvia this is unlike you
Originally Posted by PSI240SX View Post
Although the 97 Maxima was aesthetical perfection, I thought the factory body lines could use some expert "tweaking" so I ran it into a couple of things at low speed.
Looking for another pair of 17x9 Veilside Andrew Racing V's
DenkiMan! is offline   Reply With Quote
Old 09-22-2016, 08:31 AM   #9
OBEEWON
OBEEWON's Avatar
Do you use these for your butt?
diff, drift, mechanical, problem, s14
