Old 04-06-2016, 07:31 AM   #1
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
RB Rb25 connecting rod oil hole.... which way?
Which way should the oil hole be facing when doing install?
ANVIL is offline   Reply With Quote
Old 04-06-2016, 08:38 AM   #2
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
If it's the stock rod I believe the side with the text faces forward, but don't quote me on that. The direction is only important if the oil feeds on the crank and rod are directionally chauffeured to the roation of the chankshaft though. That's why aftermarket rods can be installed forward or backward.
[email protected]
hanzbrady is offline   Reply With Quote
Old 04-06-2016, 08:47 AM   #3
ANVIL
ANVIL's Avatar
So either way on manley rods?
Old 04-06-2016, 09:06 AM   #4
hanzbrady
hanzbrady's Avatar
Yes, unless otherwise specified in your provided instructions. I personally put the Manley logo forward on my build for extra style points.
[email protected]
Old 04-14-2016, 07:33 AM   #5
jedi03
Gotta make sure everyone can see it especially while the engine is running!
Old 04-06-2016, 03:42 PM   #6
ANVIL
ANVIL's Avatar
Doesnt matter even if the acl bearing has the hole?
Old 04-06-2016, 06:50 PM   #7
hanzbrady
hanzbrady's Avatar
Line the hole in the bearing up with the hole in the rod if you have one.
[email protected]
Old 04-14-2016, 12:12 AM   #8
MR_GUTTI
MR_GUTTI's Avatar
MR_GUTTI is an unknown quantity at this point
I hace a rb25 Neo stock and the oil hole in the rod is on the same side where the piston has a notch for the oil squirter. And the piston has one position. I hope this help.
MR_GUTTI is offline   Reply With Quote
connecting rod, conrod, oil hole, rb25det
