![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
Borg Warner EFR Turbo, HKS, WedsSport, Wilwood, RacePak, Votion, TONS MORE!!!!!!!!!
Okay, So I have been building my SR22VE-T for the past few years and counting , with the help of Touge Factory. These are all the parts that so far are not going on the car and/or didn't end up being needed for the build. A lot are new and some are used. I will add to the pictures/parts as I get time to take some pictures and list more. IF IT'S NOT LISTED, I'M NOT SELLING IT! I will except money...no trades.
PRICE DROP - 5% OFF EVERYTHING!!!!! BorgWarner EFR 8374 turbo - 1.05 A/R Turbine Housing (Externally Wastegated) - Turbine Silver Ceramic Coating - Full-Race Metal EFR BOV Cover - BRAND NEW IN BOX! - $2,000 (Cost over $2,500+shipping from Full-Race) ![]() ![]() ![]() ![]() WedsSport SA-55M 18x9 + 20 and 18x10 +18 (5x114.3) with Center Caps - BRAND NEW IN BOX! - $1,700 ![]() ![]() ![]() Hydraulic E-Brake with Wilwood Master (needs Res.) - BRAND NEW IN BOX! $125 ![]() HKS EVC VI Boost Controller - BRAND NEW IN BOX! - $550 (Retail: ~$700) ![]() ![]() ![]() RacePak Vnet EFI Interface Module for AEM - This allows you to hook up an AEM ecu to a RacePak cluster - BRAND NEW IN BOX! - $325 (Retail: ~$375) ![]() Votion Liquid to Air Intercooler Kit (Custom order...not sold as a kit) - Capable of supporting up to 1000+hp - BRAND NEW IN BOX! - Kit includes: 26X7X3.5 Heat Exchanger, Fill Cap, Ice Box, Bosch pump, Dual 7" fans, 15X6.5X6 Long Flow Intercooler - $650 (RETAIL = $850+) ![]() SR Timing Chain Tensioner - ~3k miles - Perfect Shape - $50 ![]() ISIS Oil Pan - Mounted Only/Never Used - $100 ![]() SR20 Extended Oil Pickup - NEVER USED! - $50 ![]() SR20 Oil Pump Gear and Rear Pump Cover - NEVER USED! - $50 ![]() Cam Angle Sensor Gasket and O-ring - Perfect Shape - $5 ![]() Intake and Exhaust Cam Gear Bolts - PERFECT SHAPE! - $3 each ![]() SR Upper Oil Pan - SOLD! SR Oil Pump - SOLD! SR Oil Screens - 2 sets SR Rear Crank Case Cover - 4 SR Oil Block Galley w/ Sensor (2) ![]() SR Main Cap Girdle - PERFECT SHAPE - $20 ![]() SR Coolant Tubes - $20 SR Short Tubes - $5 SR Temp. Sensor Housing - $10 SR Thermostat Housing - $10 SR Coolant Inlet - $10 SR Coolant Complete Setup w/ Sensors - $45 ![]() OEM SR20VE P11 Valvetrain (IN+EX Valves, Springs, Cams, Gears) - 15,000 Miles - PERFECT! - Valves - SOLD! Springs - $25 Retainers - $15 Camshafts - $50 Gears - SOLD! ![]() SR20DET AAC Valve - PERFECT SHAPE - $50 ![]() stock KA24de airbox intake system and Filter is still clean (came from a 98' kouki) - PERFECT SHAPE - $75 ![]() S13 Non-ABS Driveshaft - Pick up only - Used - $90 ![]() S13 SR Bell Housing - No cracks - $50 ![]() S13 SR Valve Cover Baffeling - Great Shape - $10 ![]() SR20 Coilpack Gaskets - NEW - $2 each ![]() S13 SR20 Intake Gasket - PERFECT SHAPE - $5 ![]() S13 SR20 Valve Cover Gasket - Perfect Shape - $15 ![]() Injector Gasket O-rings - Perfect Shape - $2 each ![]() SR20 Rear Main Seal - New In Box - $18 ![]() (8) SR20 Hydraulic Lifters - Perfect Shape - $5 each ![]() SR OEM Exhaust Manifold - Perfect Shape - $60 ![]() SR20det Exhaust Gaskets (t3, T4, Exhaust mani) (Copper one SOLD) - Perfect Shape - $15 ![]() Crank Pulley Bolts (2) -Perfect Shape -$3 ![]() Transmission Mount Brackets - Perfect Shape - $10 each ![]() Alternator Brackets - Perfect Shape - $15 each ![]() SR Clutch Fork - Perfect Shape - $10 ![]() Timing Chain Guide - Perfect Shape - $5 ![]() Knock Sensor (4)...one doesn't have a sub-harness - Perfect Shape -$20 each (15 for the one without the sub-harness) ![]() Godspeed Arm - SOLD S13 Rear Links - $10 each S13 Front Lower Control Arm - $20 ![]() (2) o2 Sensor Simulator - one was touched with dirty hands, then I put on gloves - NEW IN BOX - $30 (each) ![]()
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 02-02-2015 at 11:41 PM.. |
Trader Rating: (18)
Puts the pickup lower in the pan to help keep the engine only pumping oil and no air on turns, hard braking, accelerating.
https://instagram.com/eck_matthew/ |
Hey, i need the water neck / lines, and thermo parts ; i need cas ; and starter if u have. I am on a DOD network and pics dont work can u text me pic ? I am in NJ btw pretty close.
