07-24-2014, 04:05 AM | #1 |
GKTech - S13/S14 Roll Center Correction Kits
S13/180sx 40mm Roll Center Correction Kit - PRE BUY
The GKTECH roll center correction kit is CNC machined from 7075-T6 aluminium and provides 40mm of roll center correction, 40mm of bump steer correction and also re-positions the steering arm to increase steering lock. The roll center correction kit bolts up to the bottom of your standard knuckle and can be removed with no ramifications at all. With the use of our steering rack spacers (non offset) you will see 60 degrees of lock. By far the cheapest way of getting both roll center correction and lock. NOTE: These will increase camber as it pushes the bottom of the wheel out 25mm so best to only use with camber tops. Vehicle Compatibility: - Nissan 180sx - Nissan S13 Silvia Price: 249 AUD (approx. 214 USD) Shipping cost: From 77 AUD (approx. 73 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/s13-...te-august.html S14/S15 40mm Roll Center Correction Kit - PRE BUY The GKTECH roll center correction kit is CNC machined from 7075-T6 aluminium and provides 40mm of roll center correction, 40mm of bump steer correction and also re-positions the steering arm to increase steering lock. The roll center correction kit bolts up to the bottom of your standard knuckle and can be removed with no ramifications at all. With the use of our steering rack spacers (non offset) you will see 60 degrees of lock. By far the cheapest way of getting both roll center correction and lock. NOTE: These will increase camber as it pushes the bottom of the wheel out 25mm so best to only use with camber tops. Vehicle Compatibility: - Nissan S14 200SX - Nissan S15 200SX Price: 249 AUD (approx. 214 USD) Shipping cost: From 77 AUD (approx. 73 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/s14-...te-august.html For any inquiries please e-mail us at [email protected]. Last edited by GKTECH; 06-10-2015 at 11:06 PM.. |
07-24-2014, 06:19 AM | #2 |
So effectively, you spaced out the front wheels by 25mm? In order for me to restore my front camber back, I need to space out the top of the wheel by 25mm. So now my wheel is 25mm from where it started.
07-24-2014, 06:35 AM | #4 |
So that's about 4.5 degrees of negative camber to correct for, using positive camber via plates. I just don't see how one corrects that much while maintaining the wheels under fenders.
Great product design and idea though. Glad there are companies that are still innovative. |
07-24-2014, 08:22 PM | #6 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
You guys are cry babies.
I run -4.5 degrees of camber on an 18x9.5 +13 with a 32mm spacer.
Best way to do business with me? Make your best offer FIRST. |
07-24-2014, 10:51 PM | #7 |
Depending on your previous wheel setting you might indeed need a wider fender. If you want more lock and better RC with this product then you have to take in to account that the wheel will have to move out a bit. The same is the case with extended lower control arms. Moving the wheel out gives you more chassis rail clearance though. The negative camber can be reduced by using camber tops.
07-25-2014, 01:48 PM | #10 |
Man, I can't decide if I want these or modded knuckles... These just look so cool. And I could definitely use the added clearance from the wheel to the LCA/Tension rod since i'm running 10j up front.
07-25-2014, 05:08 PM | #11 |
Super Moderator
Trader Rating: (73)
This is exactly how I feel. I could tack a few more dollars onto the asking price and get some PBM drop knuckles. decisions decisions.
11-02-2014, 10:16 PM | #13 | |
We have an S13 version and we have an S14/S15 version. I'm not sure what your question about the tension rods is? Clearance depends on your wheel fitment and what tension rods you're running but it's easiest for you to see how much clearance you have rather than me guess. Having the rack moved forward is no issue. |
11-17-2014, 01:40 AM | #15 |
We've sold around 200 pairs to date and the feedback has been really good so far. There is a video on YouTube from one of our curstomers drivers driving his wifes A31 Cefiro which is running our RC correction kit (same suspension setup as an S13) http://youtu.be/J4lUADaT5jI?list=UUv...st0sNHdj1huD3A
05-28-2015, 07:44 AM | #16 |
Super Moderator
Trader Rating: (73)
Bumping this because you guys posted on IG and I bought a pair.
Do I need to get longer tie rods? Can you offer any more information about them since the initial release?
05-28-2015, 07:11 PM | #19 |
It depends on how much adjustment you have on your tie rods and also on how your suspension is sitting. You MAY have enough adjustment but best to check on the actual car with your setup before going any longer.
06-20-2015, 05:45 PM | #20 |
FYI to anybody who buys these and thier offset rack spacers, you will need short tie rods. I bought a pair of brand new tien inner and outers with this setup and they were way too long, im getting my lcas extended 25mm to compensate.
06-22-2015, 11:36 PM | #21 | |
Cutting the tie rods down is common practice. Are you saying that even with them cut down there wasn't enough thread? |
06-23-2015, 05:38 AM | #22 | |
06-23-2015, 07:16 PM | #23 |
The required length depends on a number of factors and having a list of all the variables would probably confuse people more than not having a length listed. The length needs to be set based on your setup and in some cases it doesn't need to be altered at all but when you move the tie rods out there is a chance that cutting may be required.
06-22-2015, 10:05 AM | #24 |
Super Moderator
Trader Rating: (73)
I recently bought these and had to sell them.
They didn't work with my wheel set up at all. S14 Running stock LCAs with Moog tie rods My wheels were 18x10+5 and didn't clear. The wheels were too wide and hit everything in the wheel well. I know that's a ridic spec and most people don't run that, but just a fair warning on the site would be nice with a recommended wheel spec.
06-22-2015, 11:38 PM | #25 | |
The only downside to the RC correction is that it increases your scrub radius just like a low offset rim or wheel spacers do. Essentially with your +5 wheels you then went to a -20mm offset with the increase in scrub radius. Although it's never been raised before, I will put more of an emphasis of this on the website. |
06-23-2015, 07:45 AM | #26 |
Super Moderator
Trader Rating: (73)
For reference, I'm running 18x10-19 (18x10+6 with a 25mm spacer) and I have full clearance, which is why I thought the RCA would give me more clearance, but it changed too much of the geometry and I couldn't figure it out.
Have to go with cut and shut knuckles for now.
06-23-2015, 07:19 PM | #27 | |
Having an 18x10 -19 offset wheel and trying to get lots of steering lock without having +50mm or more lengthened LCA's is going to be impossible. |
06-23-2015, 07:04 PM | #28 |
would these work on a S13 with S14 LCA (S13 balljoint), SPL inner/outer tie rod ends, slip-on steering angle spacer on inner tie rod, 18x9 +15?
do i need to change anything?
07-14-2015, 03:56 PM | #30 |
here is something to mention, if you use s13 balljoints with these they come with a tapered insert for them to fit in the knuckle. if you try removing your flcas, this might get stuck in them.
I had one side come out, the other size wouldn't budge. I had to cut the ball joint off of the flca, and hammer the insert out with a socket. I tried to just knock it off with a hammer, chisel, pb oil, and other things but I didn't want to ruin the insert, and since I was replacing the lcas anyways it didnt matter. Here is the insert I was talking about stuck on my lca, this lca was replaced within the last few months, I was just switching them out for extended ones, and I installed the kit 2 weeks ago and never drove on it, so rust or old parts wasn't the issue. |
