06-09-2013, 11:20 AM | #1 |
Tomei Parts, Wiring Specialties, Apexi S14 PFC, Going LS~
S14 240sx/SR20DET parts that I am looking to sell
Full album of everything that is available: 240sx Parts - Imgur Would prefer Local pickup but willing to ship per request All Prices are OBO but do not include shipping unless stated. -Tomei Solid pivot lifters w/ Machined rockers, has some test shims but not a complete set - $225 shipped -FMIC w/ Piping - $75 Comes with knock off BOV Core is 22"x11"x3". over all length from one end tank to the other is 29" -ISIS Exhaust Manifold V2 - $90 -ISIS Turbo Outlet has 1 broken stud/bolt in it will need to be drilled out - $45 -Megan Racing Turbo outlet, no divider, wastegate side bashed in a bit to clear the steering rack - $40 shipped -Stainless Downpipe with stainless Wideband Bung - $50 -ISIS Rear upper control Arms, replaced them with some SPL arms but they were fine before removing - $40 shipped -Stock Catalytic converter - $50 -Spec Stage 2 Clutch with Flywheel and Pressure plate, Not sure of mileage; even wear or the pressure plate side. Flywheel facing side only the outside edge seems to be worn. Held up great when it was in the car and no heat spots on the Flywheel or Pressure plate. Will take off $25 if you don't want the flywheel - $150 -Miata battery, Just purchased from Auto Zone, 375CCA Starts the SR20 fine. - $90 -T25 oil drain - $20 Shipped -S14 Engine Damper - $20 Shipped -S14 VTC Intake Gear and Exhaust cam gear - $60 - SOLD -T25 turbo outlet - $20 Shipped - SOLD -Pro Injector Harness Rectangle connector for temp sensor - $35 shipped - SOLD -T28 oil drain and hose -$30 Shipped - SOLD -Tomei Oil Block adapter with 10an relocation lines and Remote Filter Bracket - $150 shipped - SOLD -Greddy Rocker arm stoppers Fits any SR20DET - $60 - SOLD -Semi-built S14 Head, Has Tomei Type A Springs, New Supertech valve stem seals (both intake and exhaust) and the valves were lapped. Also has the VTC solenoid and all the stock lifters/shims/rockers - $300 - SOLD -S14 SR20 into S14 w/ABS engine Harness - $350 - SOLD -S14 Transmission/Lower harness - $80 - SOLD -Wiring Specialties Pro Coilpack Harness - $40 - SOLD -Peak Performance Transmission Mount - $45 - SOLD -Apexi PowerFC w/Commander L-jetro for S14 Zenki and Boost Control Kit (Solenoid and MAP sensor) - $700 - SOLD -Pro S14 Knock Sensor harness - $15 -Tomei Type S Fuel Pressure Regulator with 6an line from Fuel rail + Fuel Rail adapter and Tomei Fuel Pressure gauge (Used for <3k miles) - $150 shipped - SOLD -Real Greddy Type RS BOV w/ Recirculating fitting - $175 - SOLD -Powered By Max Gold Hood Spacers - $30 Shipped - SOLD -S14 T28 Wastegate - $30 shipped - SOLD -T28 Turbo Inlet - $20 Shipped - SOLD -Cusco SR20DET Engine Mounts - $120 - SOLD -Origin Lab S14/S15 Coil Pack Cover (Doesn't fit well you will need to do some drilling to make it work) comes with stainless bolts - $15 - SOLD -10x Togue Factory Extended Wheel Studs 12x1.25 Stock thread pitch (Fits rear on S14's or front and rear on S13's) - $20 Shipped - SOLD -10x Togue Factory Extended Wheel studs 12x1.5 thread pitch (Fits S14 Fronts) - $20 Shipped - SOLD -Stock Garrett T25 Turbo very little play side to side no in and out play. - Sold Includes Inlet and Outlet, New gaskets for both. No bolts for the outlet. Comes with stock Oiling feed line and stainless coolant lines and new 4 bolt T25/T28 gasket. - $100 Please PM me with any questions. Last edited by smartoss; 11-03-2013 at 05:16 AM.. Reason: Lowered Prices |
Tags |
apexi power fc, cusco, greddy, powered by max, tomei |
