![]() Join Date: Oct 2009
Trader Rating: (18)
![]() Feedback Score: 18 reviews
s14 subframe in s13
I know some people have put a s14 subframe in a s13. I was wondering if it is worth it and how do you like it. Also what control arms and all sis you use.
Thanks, Jason |
Advertiser
![]() Join Date: Dec 2010
Trader Rating: (87)
![]() Feedback Score: 87 reviews
worth it.
easy swap, you use s14 suspension/s14 diff cover now in the rear
LIKE 9K Racing On Facebook for discount and product updates. ![]() Contact 9K racing for any of your tuning or modifying needs. |
![]() Join Date: Sep 2007
You can use all of your s13 suspension.
The ONLY things you need are s13>s14 Conversion bushings, which SPL, and I beileve Stance sell. And s14 rear diff cover. s13 Subframes have a lot of anti squat built into them. s14 Subframe = more grip ![]() |
![]() Join Date: Sep 2009
Trader Rating: (91)
![]() Feedback Score: 91 reviews
S14 sway bar because it's wider than the s13
www.monkeyboysyo.blogspot.com |
![]() Join Date: Sep 2004
Trader Rating: (24)
^No, the arms are the same, the conical spacers are different. The s14 has a wider mounting point.
And the rlca mounting points are wider on the s14 subframe, so if you use s13 rlca's then you need to use washers or something to take up the extra space. |
![]() Join Date: Aug 2011
i know it 7 months old but no need to start a new thread , i just pick up s14 subframe and diff cover , going into s13 , i know i need conversion bushings and im going to get all new arms my guess is it would be easier to get s14 arms , but what about when i get coilovers will s13 rear coils fit or would i need the spacers like they use on s14 front knuckles, or would solid bushing in s13 frame be the same as swapping in s14
#14 | |
Trader Rating: (22)
![]() Feedback Score: 22 reviews
#16 |
Trader Rating: (22)
yeah i use too until i took my car off the road for a build like 5 months ago.. i usually ride out there with my buddy from up north then go drifting and racing at us27 for the night haha.
#18 |
![]() Join Date: Feb 2006
![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Those damn offset bushings are not required to do this swap. Figured I would note that since I keep seeing people insist on using them. The stock rubber bushings will give enough side to side for you to mount the SF up to the car. Your biggest issue with the swap will be exhaust hangers. The only arm you may need to swap is the RLCA, although I just used washers on each side of the bushing until I cleaned up my dookie set of S14 RLCA's.
Also, the only factory suspension I have in the rear is the RLCA so if anything else OEM doesn't fit then I really wouldn't know about it. Haha Good luck. I'm happy with the swap. Glad I took the time to rape the doner car down the road for it's subframe.
Good at wrenching, terrible at electrical. Lord help me... HAHAHA |
#19 | |
#21 |
![]() Join Date: Jul 2011
![]() Feedback Score: 15 reviews
So, to do this swap i need:
1. s14 subframe. 2. s13>s14 Conversion bushings from spl or stance. 3. s14 RLCAs 4. would other s13 suspension parts will work? what coilovers s13 or s14? is there any other parts i need? |
#22 |
![]() Join Date: Apr 2006
bunch of stupid idiots in this thread
yes, you need the fucking offset bushings. i dont know how fuck-face above even suggested stretching the fuck out of the OE bushing to slip it onto the subframe. thats like shoving a fist in a womans vagina and leaving it there, 24-7. you will need................................... offset bushings (with shims) lower control arms long control (toe?) arm (which has proper width, none of that spacer nonsense) spindles diff cover remember that you will need bushings for practically everything since its all old and shot. this means control arms, spindles, and diff bushings. also, dont waste time burning bushings like _every_fucking_idiot_ suggests, as its a complete waste of time (unless you like blowing black bogies out your nose). drill the majority of rubber out of the bushing and use a recip-saw cutting inwards towards the subframe (as opposed to the thin outer areas). i also suggest avoiding poly urethane nonsense, unless you want to spend a lifetime under your car removing the bushings, re-greasing them, and re-installing them. i have yet to see ANYONE make a clean setup w/ grease fittings, its all sloppy joe ghetto style. so bushing alternatives are to get nismo (if you can find them) or get raped financially buying spherical bearings which are harsh and not really ideal for a street car, plus they are not designed to last tens of thousands of miles. remember, people on this forum are STUPID. use your common sense. |
#23 | |
![]() Join Date: Mar 2009
Trade my Rb25 for some wheels. Buy my Sc300. |
#24 | |
read my sig.
#25 | |
Trader Rating: (24)
s13 toe arm in s14 subframe: ![]() Also, most of the people stretching out the bushings to fit are trying to conform to Street Mod autox rules which explicitly prohibit offset bushings. It's not the right way to do it, but that's usually the impetus. The taper is different between rear s13 and s14 ball joints, so you will need to get s14 spindles or take the opportunity to run z32 aluminum uprights (but those will necessitate changing your lower shock mount to z32 fork style). The length between s13 and s14 rlcas is the same, it's just the bushing width that is different. The RLCA inner bushings are 40 mm wide on S13/Z32, 50mm on S14s. Please go read: http://nissanroadracing.com/showthread.php?t=1512 |
#26 |
I tip my hat off to you sir. Not even going to argue because you are indeed correct. My post was just saying "stock for stock." For an OEM bushing to work properly, it needs to be torqued onto the vehicle when laden. Adding washers and doing bullshit like that obviously negates the point of doing all this work, besides being ghetto.
#27 | |
S12 || KN13 || S13 || B16 |
#28 | ||
I plan to RACE my car... not hardpark the shit out of it and say "yeah I have an S13 with all S14 suspension because I'm MadJDMTyte yo!" I have a set of rules to comply with and this mod has been done by more than a few other SM classed 240sx's and run for quite some time successfully WITHOUT offset bushings. Proof that this mod can indeed be safely completed WITHOUT the offset bushings. Thanks for the sweet words though. I almost blushed.
