10-01-2010, 04:07 PM | #1 |
Rear clunking noise, only under acceleration
Ok so I am about to pull every hair out in my head at this point. There is a clunking noise from the rear, towards to back right wheel of my S14. I have coils, RUCA's, toe rods, traction rods that are aftermarket back there. Stock rear brakes.
Ok so here's the problem. When I start off in 1st gear, nothing makes noise. In every gear after that, this clunking noise begins. It only happens when the car is under acceleration, when there is force/pressure being applied. I have gone through several phases of lowering and raising the car. Before I raised it up a little bit, the car was pretty low. And at that height it never made this funky noise. But when I raised it back up to where is sits now, that's when it started. I have checked every link, nothing is rubbing, etc...I don't know what else to frackin do. Someone pleeeeaaaase shed some light on this sitiation! |
10-02-2010, 09:47 AM | #7 |
Well it had an open. Put a vlsd in and then it started making that noise. Thought it could have possibly been a faulty pumpkin, so I put the open back in. Still makes the noise. Maybe the extra length of the vlsd being ABS on my non-ABS car made the driveshaft and something along side it get out of whack.
10-02-2010, 04:00 PM | #13 |
Trader Rating: (83)
Feedback Score: 83 reviews
check ur collars, check your axles for any play, check subframe nuts if their tight enough, basically re-tighten (or maybe too tight) all nuts and bolts that you took out initially when swapping aftermarket parts. lastly, check the 4 bolts that holds the hub.
07-09-2021, 10:10 PM | #14 | |
