02-18-2010, 08:39 AM | #1 |
FS: S14, RB25, RB26, Aero, Navan, Interior, Lighting
S14 / RB Parts For Sale
– Pioneer DEH-P4100 Radio w/ aux input CD changer adapter, speaker outputs on harness are chopped off, but was used with external amp so didn’t matter. Just need a new harness if you want to use the speaker outputs - $40 shipped – S14 Sunroof Weather stripping Brand new in box from dealership, $70 – R34 RB25DET Neo Exhaust camshaft. Make offer – RB25 Head studs OEM used, not sure of mileage. Make offer $50 – R34 RB25DET Cylinder head camshaft oil splash covers, gold in color, 4 of them, $25 – S14 Radio brackets, slightly bent, still work perfect - $20 – S14 left front corner light, broken top tab, and small internal crack on lenses, but does not leak, still useable with other mounting points. $30 – 5-bolt turbo downpipe gasket, with brand new bolts $20 – RB25 neo upper intake plenum gasket rubber, have two of these, $18 – R34 RB25det turbo manifold OEM $80 – RB25DET top mount turbo manifold, eBay brand, modified to fit properly, need Wastegate flange, $120 – S14 oem used rear traction rods, $50 – Apexi 3” power intake filter, used, great shape, $80 – S14 SE power mirror switch, small crack on the face of switch, but still fully functional $10 – S14 Stock rubber shift knob, dirty, needs some cleaning up, $10 – JDM Navan S14 oem front amber corner lights, new in box, $80 – S14 sunroof assembly complete minus fiberglass trim ring around outer edge of glass. Comes with drain tubes as well. $ Make offer, prefer pickup only, large item – S14 SE sunroof headliner, great shape no stains, cracks, etc. Pick-up only $50 – S14 SE sunroof headliner trim ring around pull shade, $40 – S14 SE overhead light console with sunroof switches $35 – S14 M-sport D-style FRP +20mm wide front fenders new in box, $290, buyer pays shipping, large box approx $110 to ship – RB25 oem head gasket new in box, $70 – S14 SE airbag control module $90 – S14 SE airbag control harness $50 – S14 SE passenger side airbag, $100 – RB25DE Neo Cylinder Head (machined, no cams) $400 plus shipping FS: R34 RB25EDE Neo Cylinder head, Complete Machined head minus cams: Engine / Drivetrain (for sale): Nissan Forums / Infiniti Forums - NICOclub -- Perrin Universal Dual Gauge Pod $40 Im picking up a new shortblock soon, just throwing this out there. Anyone interested? May part out the block depending on what i get offered for the various parts. fresh never run completely assembled. Sitting on engine stand at the moment at a shop. R34 RB25DET Block .40 Over Bore, Line Honed, Deck Re-surfaced & Micropolished R33 RB26DETT Crank, longer Crank Collar R33 RB26DETT Rods, Micro-polished CP 87mm RB26DETT Pistons, 8.5:1 Compression, CP Piston Rings ARP Rod, Main, Head Bolts ACL Race Rod & Main Bearings Tomei Oil Restrictors here are the specs for the bottom end: Cylinder Bore Size 87 Piston Stroke Length 73.7 Head Gasket Bore Diameter 88 Piston Deck Clearance Negative If ABOVE Deck (Use '-') : -0.5715 Make me an offer, something reasonable. no loballers. lots of time and money went into this build. All prices are OBO, do not include shipping unless stated, and i can be reached best by email at [email protected] Thanks for looking Last edited by whatbrokethistime; 03-06-2010 at 07:51 PM.. |
02-21-2010, 06:34 PM | #2 |
you dont by chance have the aluminum mount for the CAS for the rb25? the mount attaches to the head with 3 bolts and covers the cam, then the CAS bolts to it.
02-21-2010, 07:55 PM | #3 | |
I dont, im sorry. best bet though is to contact Ricky @ rawbrokerage.com he always has RB parts that are hard to find. good luck! |
03-25-2010, 12:02 AM | #7 |
will usdm sockets plug into the navan bumper blinkers? or is anything else needed? if possible n u still have them, please email me pics at [email protected]
S14-vlsd/coilovers. L33 swap, ENGAGE! www.arnaturalselection.blogspot.com Last edited by Darkvillin; 03-25-2010 at 12:04 AM.. Reason: interested in the item...wanna see pics. |
08-15-2010, 06:48 AM | #9 | |
alex, sorry i didnt get back to you, i havent been watching this thread. I've got it still. I'll call you later on this afternoon. -John |
08-15-2010, 06:50 AM | #10 | |
search google for "navan bumper" and you'll see the bumper lights they do not fit in USDM bumpers |
Tags |
part out, rb25, rb26, s14, sr20 |
