Rear Rotor question
How difficult is it to remove the rear rotors off a 95 240SX LE?? I need to change them to pass inspection and I am not about to pay some one to do it. I have a new set of stock Nissan rotors just need to know how hard its gonna be and if I should know anything special. I have changed rotors on at least 8 civics so that is what I am comparing them too. Any input would be of great help.
Thanks, Chad |
![]() Join Date: May 2002
easy in a way..
unbolt caliper remove caliper (pads will fall out) remove rotor have to compress the piston on rear caliper (need the special tool is easiest, but needle nose pliers work ok too) install rotor reinstall pads on caliper rebolt caliper on that's it first time? expect 2 hours give or take (that's working relatively slow and sometimes those rear calipers are a HUGE PITA). if you do it often, can have it done within an hour easy. |
its a cube shaped thing
u can find it at auto stores easily it attaches to a socket wrench you dont PUSH the rear calipers in, but rather you 'screw' them back in needle nose pliers do the same job.i find the cube much easier though. |
