![]() Join Date: Nov 2007
Running without o2 sensor
Ok guys, i just bought a megan turbo elbow and its for a fat o2 sensor and my redtop has a skinny o2 sensor. Question...What to do...Do I run without an o2 sensor? The car is obd 1 so the o2 sensor doesn't do much though it will improve gas mileage at cruising speeds.
Or..do i weld the skinny o2sensor to the fat bung and hope that it works. I know there's other options but dont really want to go out and buy a fatty o2 sensor or another elbow to suit my needs. Any help is appreciated. thanks ![]() |
![]() Join Date: Jan 2008
Location: You can tell how I walk, I ain't from around herr..Five6Duece, Kings Only
I think theres adapters availiable....also I know the stock exhaust manifold on an sohc has and adapter. I figured that out when I put headers on my sohc, I unscrewed the o2 and it was obviously to skinny for the hole on my headers then I realized I could unscrew the other part on my exhaust manifold. I have an extra one you can have, wortha try?
![]() Join Date: May 2006
Yeah, all the new Megan elbows come with an adapter. I drilled/tapped my "plug" to fit the skinny one once, and then on my next one just got a blacktop o2 sensor that fit the hole, and then replaced that elbow and the new one had the adapter
![]() Don't run without an o2 sensor if you can help it.
![]() Join Date: Dec 2006
this ones more expensive but if ya can't find it at the dealer her ya go http://enjukuracing.com/spec-sensor-...ml?cPath=24_57
![]() Join Date: Apr 2004
Run a Z32 O2 sensor. Problem solved.
Cliff's notes of the earlier o2 threads: Some say skinny and fatty are different and not interchangeable. I say if you can show the data stream for a skinny vs. a fatty on the same engine and recording data at the same time, then maybe you can make a case that they're different. But even then, you have to show that the ECU is actually processing the two signals differently somehow. So far no one cared enough to do this so run whatever you want. |
^--spot on.
depending how crusty and old your skinny o2 sensor is, just pick up a new fat type o2 sensor from a z32. same plug and everything. the exact details are in the SR20DET FAQs. just look at it this way, do you REALLY wanna waste your time buying an adapter to adapt the skinny type that isn't even available here? it's like buying a big as TV antenna and putting it on your roof, which is a waste because they're turnign off analog air broadcasts in 2009 anyway lol |
I don't want to dig it up again, but the big arguments from them was that the skinny and the fatty send a different signal to the ECU, and the ECU gets confused if you mix and match.
My position was that at best the signal is more responsive on one type over the other, but the ECU takes an average of the sensor reading over a period of time, and o2 reading isn't a crucial parameter anyway. Does anybody want to run some testing? |
Damn beat me too it^^
Its cheaper (here as far a new one goes) http://www.thenismoshop.com/ikorb.ph...roduct_id=1607 Fat Vs Skinny One uses a voltage signal and the other uses a resistor there was a thread on this about a month ago
#15 | |
I think it was this one http://www.zilvia.net/f/showthread.p...rconia+ceramic More Info http://en.wikipedia.org/wiki/O2_sensor somthing along the lines of One sent a signal and the other recived and used a resistior to change the voltage and send it back to the ECU.
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 05-13-2008 at 09:08 AM.. Reason: Sites |
#16 |
Depending on whether or not you can find it at the dealer, and depending on how much it costs, getting it from Megan might be cheaper. It's not on their website, but you can call them and ask for it directly. $15 shipped. (626)581-0988
A lot cheaper than $20 plus shipping (probably $10) that Enjuku wants. $30? For a bolt? Come the fuck on, guys.
My seller review thread |
#17 | ||
You are the ECU and I am the O2 sensor. We're connected by a straw (wire) and we can blow spit wads (electrons) at each other. When I suck spit wads from you, I am a voltage triggered sensor. Electrons flow from negative (you/ECU) to positive electrical potential (me/sensor). I'm sending a signal to you because I'm sucking your spit wads away. When I blow spit wads at you, I am a current triggered sensor. Electrons flow from negative (me/sensor) to positive electrical potential (you/ECU). I'm sending you resistance because the more resistance I send, the more spit wads will get blown your way. It has to do with which way the spit wads are going. The ECU has to know whether it wil get blown or sucked ![]() Now, does skinny and fatty each suck or blow? |
#18 |
Lets end this. These are your options:
1. Buy $10 adapter piece at the Nissan dealership. 2. Buy an E5 ECU and a Z32 TT fatty o2 sensor. Hmm decisions, decisions.
#19 |
Fatty - Blows
The zirconium dioxide, or zirconia, lambda sensor is based on a solid-state electrochemical fuel cell called the Nernst cell. Its two electrodes provide an output voltage corresponding to the quantity of oxygen in the exhaust relative to that in the atmosphere. Skinny - Sucks and Blows This type does not generate its own voltage, but changes its electrical resistance in response to the oxygen concentration. The resistance of the titania is a function of the oxygen partial pressure and the temperature.
#20 | |||
We're still trying to figure out which is which, for all those inquiring Zilvian minds. Quote:
How do you know if the skinny is not a Nernst cell? |
#21 | ||
The tip reads the exhaust and the outer body reads the outside atomshere. The two electrodes are the 02 body and the tip. yes Im very aware that electrons go from (-) to (+) such as lightining travles from the ground to the sky. Quote:
control unit feeds the sensor with a small electrical current and measures the resulting voltage across the sensor the skinny is a Titania sensor which has a ceramic element Zirconia sensor is based off of the Nernst Cell. So thats how i know the skinny is not a Nernst Cell
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 05-13-2008 at 11:49 AM.. Reason: Busy at work, hard to think |
#22 |
![]() Join Date: Feb 2008
So they arent interchangeable? I'm using the fatty on my redtop. When I first give it some throttle, the A/F goes to 20 then takes a couple seconds to get back down to 14.7
Should I be using the skinny one? I have the 62 ECU. |
#23 |
Get the skinny o2. ('87 Turbo 300zx). And the adapter piece., see if the A/F no longer jumps to 20 and remains around 14.7.
#24 | |
http://www.thenismoshop.com/ikorb.ph...roduct_id=1607 Autozone wants like 90-100 bucks
#25 |
Wow, didn't think this thread would go this far.. i'm off to get the adapter piece. seeing that i'll be at WOT most of the time or at a stop, the sensor probably won't be as crucial to my performance as some might think. 11 bucks is a bargain.
#26 |
I also use a fatty sensor on a redtop, with no 'known' problems... but I'd love to see if your A/Fs change, Killer2001.
#27 | |
#29 | |
240Atlanta Thread HERE |
#30 |
![]() Join Date: Jun 2010
get more cool backfires and shittier gas mileage
i ran no sensor for aobut a year it was fine, when i put it back in i didnt see a difference at all except for gas and backfiring |
