Car sits UNLEVEL.. WTF....HELP!!!!
Ok... My car has Apexi WS Coilovers, and suspension tech swaybars front/rear.
NOW...wherever i park, no matter what, my car sits uneven in the rear. The DRIVERS SIDE REAR is ALWAYS lower(one finger gap) than the Passenger side REAR(two-three finger gap). At first I thought this was due to ONE coilover spring sagging, or being adjusted higher than the rear.. SO.... I SWAPPED REAR COILOVERS.... Put the left on the right, and the right on the left. I didn't adjust them at all during the swap... NOW...the car still does the EXACT same thing... WHATS GOING ON? thanks guys. |
I know bad stock buhsings can cause this if some of them tore away from the metal sheel alowing it to move more like a ES buhsing or pillow ball type bearing....brand new teh stock bushing aren;t allowed to move around the metal sleeve there basically under tension the whole time which can effective aid if the supension wanting to left teh car or not if they are shot out...
Uneven camber can cause height issues Sometimes corner balancing is need to get the car to sit even |
#4 | |
there is NO bondo on the car at all. I didn't install the rear sway...It came on the car.
Should i jack up the rear, and loosen the nuts that hold the bar to the car, and then retighten them? I'm not sure how that could possibly help, but i'm willing to try anything right now.. |
No more nissan.
![]() Join Date: Jan 2003
Worth a shot. Sway might be bent.
Has this been a problem ever since you got the car? If the coilovers are at the same height and the sway is tightened properly, try taking it to an alignment shop and see if they can look at it. It'd be a good idea to go to a shop that also does corner weighting because they'll have more experience with that.
thanks neme....
I just raised the rear of the car completly.. Loosened all of the sway bar nuts/bolts, and retightened everything.. STILL the SAME THING!!! GRRR. I guess i'll try an allignment shop.... Is there a way to tell if i have a bent sway bar? They are Suspension techniques, but i cant even find their website... I even searched google!? Anyways, i'm wondering if i could send them to S.T. and see if they would tell me if they are good or bad? |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
One side of my car always looks higher, but I think it's because I'm crazy.
I have more camber on one side of my car than the other in the front.
corner weighing a car probably won't help w/ the gap issue because the result is not to get the ride height the same all around. it' normal for cars to sit uneven, especially old cars with older bushings. just fill up your gas tank, and keep it filled, lol. But, if you really are that concerned with the gaps being the same, just change the height of the coilovers.
![]() Join Date: May 2009
I'm having the same problem on my hatch. Just that I dont have Coilovers, I'm running KYB Gr2's with Tein springs. The passenger front sits higher then all other corners following the rear passenger sitting just a tad lower. The driver side sits even more or less. The lowest side is the driver rear making it have a Gangster lean. Its so annoying, i love looking at the driver side but hate looking at the passenger side. i wish i knew what can be done to fix this other then buying coilovers...
#14 |
![]() Join Date: Jan 2008
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
i have the same problem went to wheelstore did alignment,corner balance,they adjusted my rear coils to make my car sit right but my coils are uneven in order to make my car sit even
#15 | |
![]() Join Date: Jan 2009
Trader Rating: (25)
![]() Feedback Score: 25 reviews
#16 |
This is like one of my most hated things about a car when its uneven, man it pisses me off. Well i had more camber on one side than the other and my fender was slightly bent so i felt stupid afterwards. Hope you figure it out.
Nothing says racecar like a stock car with no interior. |
#19 |
This thread is old, and there have also been other threads on this.
It is normal. That is how the car was made. The passenger side rear fender sits higher than the driver side one. |
