12-13-2013, 12:52 PM | #2 |
This is a very interesting build.
How much power does something like this put down? I got a buddy i am getting into the car world, and would be good to get him in a N/A s13 with a bit more thump
petrolhead |
12-13-2013, 02:11 PM | #3 | |
thanks brotha, at the moment hasn't been dyno'd but id guess right now around 165-170, this thing has instant torque and great response..if you get a tune to dial it in on N/A setup theres no doubt in my mind it would be in the low 190's...ka-t would be around 230-245. |
12-13-2013, 01:23 PM | #4 |
Stock rebuilt KA, stock SOHC pistons, high compression, 370cc injectors, Cometic headgasket and boost? Sounds like you're building a bomb not an engine...
12-13-2013, 02:07 PM | #5 |
lol, make sure you do some more researching before you just talk outta your ass. it would be low boost around ~5-7psi when it is ka-t. the E85 is 104 octane which is guaranteed to NOT knock. thanks for the bump!
12-13-2013, 04:16 PM | #6 | |
I'm sure this motor runs great N/A and I wish you glws, but boost is not a good idea for that motor...
12-15-2013, 12:57 AM | #7 | |
Here's a vid of a similar spec running T3/T4, obviously larger injectors, maf it will hold on done right and properly tuned. |
12-15-2013, 01:09 AM | #8 | |
12-13-2013, 05:34 PM | #9 |
I'd boost it start at 12psi.....I didn't know there was such pussys in this world....stock Honda ITR motor is 11:1 or higher and they will make well into the 500s with just headstuds and last... Your gonna need bigger injectors,fuel pump and a clutch
Quote Originally Posted by andresr20 ffffffuuuuuuuuuuuuukkkkkkkkkk HONDAS |
12-13-2013, 11:43 PM | #10 |
haha word brotha. I forgot to mention it does have a 255 but im not looking for big numbers just something to have fun with and be reliable., either way its a solid setup as is..or ka-t. ill probably look into s15 injectors not a bad idea
Tags |
bam, e85, hatch, ka-t, silvia front |
