![]() Join Date: Mar 2009
Helppppppppppppphelppppppppppppp
alright so i just finished throwing in this ca18det swap in my s14 . i upgraded the stock turbo to a gt28 turbo , i am noticing when i drive the car , 1-3 gears are fine when i get to 4th gear and hit about 3100 rpm with the throttle fully open nothing happen after that point until i go under the 3100 rpm mark. its usually right before the boost kicks in in those high gears.
and when i get to 5th gear i can not exceede about 2500 rpm . i am not sure if this would link to a maf problem. or a boost problem . but i can pretty much red line the car in the first 3 gears and boost no problem. some input would be nice ! thanks ZILVIA PEEPS. |
Not too familiar with the CA18, are there 4th gear and 5th gear sensors in the transmission? If so, are those plugged in? Does it feel like a fuel cut when you exceed the rpms?
#3 | |
it feels like everything cuts out, and not slowly its as if the car shut off or something, it only does this once i get to that rpm. the car use to be automatic ka but i converted the harness and rewired it onto the tranny |
![]() Join Date: Dec 2006
what MPH are you at at 3,100 in 4th?
i dont think its the maf cause its the same maf the kid before me had in his s13 and i new him and drove with him and never had this problem ,and as for a leak , its doesnt feel liek aleak problem , once i hit 3100 rpm the pedal becomes completely useless no matter how far i push it it feels like a dead pedal
#14 |
yeah check ecu out... ive seen some picky motors with similar issues and it was just a simple ecu swap... there picky lil things lol, i cud imagin in a s14 also
what ecu and maf are u running? |
#15 | |
the numbers on the ecu MEC-D016B and number 78 it says its for a MT . so i shouldnt see why theres a problem |
#17 |
you mean to a z32 one. this wouldnt have this much affect on it tho! i test drove the car today and i got it to rev in 4th and 5th but i was redling it in 3rd and switched to 4 and redlined it again and then to 5th then i turned the car around and the car died.
#19 |
ya the kid before burnt his wire harness and the ecu so i got it rewired and got a ecu off someone . the ecu is a bit different as the old one was from a silvia and the one i got was from a 180sx ca18det but the motor is the same so i dont see why it would affect it. i figured this problem occurss when i reach a certain speed.
Tags |
240sx, ca18det, ka24de, s13, s14 |
