Old 09-11-2014, 11:16 PM   #1
Nizmology
Nizmology is an unknown quantity at this point
440HP RB25, caged, RPF1, Garrett, TIAL, Quality Build.
SOLD
YT]TPesozgU98s&feature=youtu.be[/YT]
Originally purchased in January 2013 from a Zilvia member who was very honest and up front about everything. I genuinely appreciated that so I am doing the same. Please PM me any questions/requests for pictures/videos and I will gladly help you out. Enjoy!
The Car:
1989 Nissan 240sx Coupe
Factory two-tone paint "Seafoam" (silver/green)
172,000 Miles on chassis
*CLEAN TITLE.
*PINK SLIP IN HAND.
*REGISTERED UNTIL JAN 2015
Powerplant:
The engine was professionally built and installed by Alex and Adrian at Vildini Motorsport in 2009. The bottom end is built with CP forged pistons and ACL race bearings. The exterior is the only place that needs attention. I personally think the imperfections add character but you could say it needs paint. Few spots of surface rust around the windshield and sunroof. There are a few dings and stuff as well. Typical stuff for a 25 year old car.
In December 2013, the new Garrett turbo, all new intercooler piping, injectors, fuel rail, and tune were completed by Bardabe Performance. Car was dyno'd and is currently putting down 440HP to the wheels. Car weighs less than 3000lbs. I have all of the receipts/paperwork for the work that was done. Tons of quality parts.
Engine and Drivetrain Specifics:
RB25DET
Garrett GTX3076R turbo
Greddy Fuel Rail
Tomei Fuel Pressure regulator
Injector Dynamics 1000CC injectors
Modified stock exhaust manifold for TIAL external wastegate
Custom fabricated 3" aluminum piping for intercooler with new couplers/t-bolts
CP forged pistons
ACL race bearings
Metal head gasket
McKinney motor mounts with polyurethane bushings.
Custom driveshaft
Greddy style intake manifold
Z32 MAF
Spec Stage 3 clutch
Greddy Front Mount intercooler. Painted matte black heat resistant paint.
TIAL BOV
TIAL External Wastegate w/20LB spring and blast pipe pointed to ground running right along turbo/steering column
Trust air filter
Custom 3 inch straight through exhaust from the turbo back, tucked up as high as possible to maximize ground clearance
"Stock looking" straight flow muffler with two 3" tips. Painted with matte heat resistant paint.
Mishimoto radiator w/ Flexalite High-flow fans sealed to radiator.
VMS Motorsports vented oil catch can
Aluminum coolant overflow reservoir
New Optima Red Top (2014) battery relocated to trunk
Apexi Power FC commander
Powder coated valve covers (wrinkle red)
Power coated engine block (gloss black)
Nismo 1.5 way LSD with 4.3 final drive
Suspension, Chassis and Brakes:
Apexi EXV coilovers
Battle Version Rear Traction Rods
Battle Version Rear Toe Arms
Battle Version Front Tension Rods
Battle Version Rear Upper Control Arms
Cusco front strut tower brace
Cusco rear triangle strut tower brace
Enkei RPF1 rims:
17x9 +22 fronts, BF Goodrich G Force Sport front tires, 225/45/17 90% tread.
17x10 +18 rears, Yokohama S Drive rear tires, 235/45/17 90% tread.
5 lug conversion
Rebuilt Z32 TT front calipers (powder coated red)
Drilled and slotted front rotors
S14 rear rotors
Stainless steel braided brake lines
Stainless steel power steering high pressure line
StopTech rear brake pads (installed 8/2014)
Hawk Performance front brake pads (installed 8/2014)
Silvia trunk lock and badge on rear.
Interior:
Cracked dash typical of 240's
Nardi 350mm Deep Corn steering wheel
NRG quick release hub
Tomei shift knob
Autometer oil temp, voltage, and boost gauge in central vent area
Quick release parking brake
Sparco Torino driver seat
S14 passenger seat.
Sparco harness tethered to cage
Autopower 4 point cage.
Fire extinguisher mounted on cage.
LED dome and trunk lights.
DYNAMAT sound deadening mat entire trunk.
Definitely gets a lot of looks/thumbs up and is an absolute V8 hunter/destroyer. The car is located in San Jose, CA. I am sure I left off a couple things I've upgraded so if you have any questions, please post/PM me! If you are in the bay area, I welcome you to come see it in person, I can always meet you halfway
Asking a modest $12,000. Cash is king.
ENJOY IN HD!
Exterior Walkaround:
http://www.youtube.com/watch?v=qY11ztKgmzo&list=UUabqEP13n6Jb1tt4kEZcY8w
Interior:
http://www.youtube.com/watch?v=IkkwOhLj4pM&list=UUabqEP13n6Jb1tt4kEZcY8w
Start up: Engine/exhaust Idle:
http://www.youtube.com/watch?v=ImlEmHWc1Mw&list=UUabqEP13n6Jb1tt4kEZcY8w
Fly By:
http://www.youtube.com/watch?v=dDSkrlYImAA&list=UUabqEP13n6Jb1tt4kEZcY8w
On Ramp:
http://www.youtube.com/watch?v=8h_kIU7Zvqk&feature=youtu.be
Dyno Pull:
http://www.youtube.com/watch?v=r9sEBNOrEzk
Last edited by Nizmology; 01-04-2015 at 11:33 AM.. Reason: Ad description/videos/Price
Nizmology is offline   Reply With Quote
Old 09-11-2014, 11:23 PM   #2
Nizmology
Tuning Dyno Pull
https://www.youtube.com/watch?v=r9sEBNOrEzk
Old 09-12-2014, 07:50 AM   #3
hobbs
Trader Rating: (43)
hobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the rough
Feedback Score: 43 reviews
This was gearheads car correct? This thing is pretty awesome.
hobbs is offline   Reply With Quote
Old 09-12-2014, 07:55 AM   #4
Nizmology
Yes sir, thanks! Body has remained the same for the most part, just
built up the motor and added the appropriate supporting mods for brakes, body, and fuel.
Old 09-14-2014, 03:49 PM   #5
gearhead55
gearhead55's Avatar
yes sir. I can vouch for the bottom end and suspension/brake/wheel build, all high quality. Nizmology is a great dude and i'm sure the new turbo set up is top notch too. definitely worth what he is asking. somebody needs to get in the two tone gang with this
440hp BYAAAAHHHH
gearhead55 is offline   Reply With Quote
Old 09-15-2014, 08:22 PM   #6
Nizmology
440hp BYAAAAHHHH
Haha, Byaaahhh is when boost hits for sure!
Old 09-12-2014, 08:11 AM   #7
hobbs
Trader Rating: (43)
Really sweet car, I'll be watching the price on this one, could use a trip out west!
Old 09-12-2014, 09:55 AM   #8
Nizmology
Come on out and take her for a spin!
Old 09-13-2014, 07:44 AM   #9
Nizmology
Uodate 9/13/14
-All new NGK spark plugs installed.
-Car will come with a full tank of gas, full interior and exterior cleaning, and a hand waxed finish.
-Will also throw in a pignose lip.
Old 09-12-2014, 09:00 AM   #10
BIGSxNPTACTIX19
BIGSxNPTACTIX19 is an unknown quantity at this point
drooling right now!! GLWS
BIGSxNPTACTIX19 is offline   Reply With Quote
Old 09-13-2014, 09:36 AM   #11
lunchboxhero
lunchboxhero is an unknown quantity at this point
REALLY REALLY nice car, I remember when it was for sale last and I couldn't pick my jaw up off the ground, still can't.
GLWS man, It's worth the asking price IMO.
lunchboxhero is offline   Reply With Quote
Old 09-13-2014, 10:45 AM   #12
Nizmology
Thanks man!
Old 09-13-2014, 12:34 PM   #13
tobroketobuildarealcar
tobroketobuildarealcar is an unknown quantity at this point
Nice car
But really 14k
tobroketobuildarealcar is offline   Reply With Quote
Old 09-13-2014, 01:02 PM   #14
Nizmology
RB
Originally Posted by tobroketobuildarealcar View Post
Nice car
But really 14k
Yes, really. With cash in hand I'm flexible.
Old 09-13-2014, 12:38 PM   #15
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
looking good man
Old 09-13-2014, 01:41 PM   #16
Nazdog247
Nazdog247 is an unknown quantity at this point
Damn one bad ass car, I love in the Bay Area and would love to own this machine. Only if I had about 7k more ! Lol
Nazdog247 is offline   Reply With Quote
Old 09-13-2014, 03:50 PM   #17
Toomuchboost12
Toomuchboost12's Avatar
Toomuchboost12 can only hope to improve
thats a sexy Two tone GLWS !
Toomuchboost12 is offline   Reply With Quote
Old 09-13-2014, 09:33 PM   #18
Nizmology
Thanks! Trying to find her a good home.
Old 09-14-2014, 08:36 AM   #19
Nizmology
Be the envy of your neighborhood with this Sunday Funday machine!
Old 09-14-2014, 09:36 AM   #20
TwelveAM
TwelveAM's Avatar
Trader Rating: (26)
TwelveAM is an unknown quantity at this point
Feedback Score: 26 reviews
Bump for this car. I remember rolling with you to the s chassis meet last year from the donut place by LAX. I was in the champagne coupe.
GLWS sucks you can't keep it.
TwelveAM is offline   Reply With Quote
Old 09-14-2014, 03:11 PM   #21
Nizmology
Smile
Yeah man! I remember you. Want to drive up to NorCal and buy it off me?
Old 09-14-2014, 03:58 PM   #22
thebaytola
thebaytola is an unknown quantity at this point
This thing is the real deal. I met this owner, Mike, in real life...I wouldnt want to buy a car from anyone else, pretty sure he made my car OCD look like nothing....This thing is CLEAN!! Isn't this thing on LOW boost putting down 440? the turbo is capable of much more this is literally a 700hp capable car with a $350 tune
thebaytola is offline   Reply With Quote
Old 09-15-2014, 08:16 AM   #23
Nizmology
Thanks dude. You're right, I'm currently running a conservative tune (daily/weekender type driving). As the former owner/builder in the post above (Gearhead) stated, the bottom is solid and can handle the power!
I HIGHLY recommend that the new owner switch to an E85 tune, new fuel pump, and turn that boost up and enjoy 600+ HP! That's what the 1000CC injectors are made for!
Old 09-15-2014, 08:41 PM   #24
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
What seat brackets are you using with the Sparco??
RalliartRsX is offline   Reply With Quote
Old 09-15-2014, 08:50 PM   #25
Nizmology
They look like this, I just googled this image but it is the same one. Direct bolt on to the 240sx seat bolt pattern.
http://i2.photobucket.com/albums/y12...l/CIMG5929.jpg
Old 09-16-2014, 07:24 AM   #26
Nizmology
Any offers? Send me a PM!
Old 09-16-2014, 05:36 PM   #27
Nizmology
As she sits currently.
Old 09-16-2014, 08:59 PM   #28
XgoldzenkiX
XgoldzenkiX is an unknown quantity at this point
good luck with sale. beautiful two tone. love it!
XgoldzenkiX is offline   Reply With Quote
Old 09-17-2014, 09:13 AM   #29
Nizmology
Thanks! Where in the bay are you?
Old 09-17-2014, 03:02 PM   #30
Nizmology
Price Drop: $13,500. Come and get it.
