01-25-2013, 04:27 PM | #1 |
New flca to hit the market soon
so im finally willing to leak these photos of a product i have been doin R&D on for many months.
i will be testing these at the track this weekend (with a swaybar that will clear MAJOR angle and bolt up in the stock location......soon to come with pics on that) just want some feed back on what you guys think not going to give away to many details but I will say this..... This is the most advanced FLCA to hit the market for 240sx It will clear more angle than ANY of the competition currently on the market MUCH stronger than stock Lighter than stock MADE IN THE USA- AND USING ALL USA MADE ROD ENDS (unlike most of the popular brands that are going to china) price will be around $900 .................................................. .................................................. ......... please let me know what you guys think and feel free to ask me any questions about this item. Last edited by Bink Industries; 01-28-2013 at 10:21 AM.. Reason: made a mistake |
01-27-2013, 01:32 PM | #6 |
Not with your design.
As you extend the "tension rod" heim to adjust caster, you change the distance between the subframe and tension rod bracket. Since this distance is fixed, all you're doing is putting pressure on the subrame and tension rod bracket. In my MSPaint picture, the green line is the "correct" distance between the two points. As you extend the rod end along the orange arrow, you change the physical distance between the two points. The purple line is the new distance, and when you rotate the LCA around the subframe rod end to "adjust" caster, the distance is incorrect and you're stressing the subframe and tension rod bracket. The tension rod needs to pivot on the LCA or the angle at which it mounts to the tension rod bracket needs to be adjustable, like the TDP kit. |
01-27-2013, 10:14 PM | #7 |
note the shims on the tension rod side!
i have already bolted this to the car adjusted from stock to 15 degrees of caster. i wouldnt build something unless i could beat out the competion. and FYI just because the gktech /tdp stuff looks like robocop doesnt mean anything. I dont have time to explain to you guys 6 months of research and a group of some of the nations best fabricators looking into every aspect of this part. oh and its FD compliant |
02-01-2013, 12:05 AM | #8 | |
You were having so much fun in ms paint you probably forgot to notice that the adjustable caster arms on your 240 pose the same problem. Hahahaha see I'm on no ones side. Congrats on the new product, it looks sick, just a little expensive. May want to outsource those ball joints to china lol |
01-27-2013, 09:28 AM | #11 |
This is by far NOT the most advanced FLCA on the market, and if i was willing to spend that kind of money, i would add 300$ to get a pair of adjustable knuckes from gktech /tdp, along with various other parts.
That and advertising without a trading account may get you in trouble. edit: this is from TDP and the full set is 1200$ if memory serves. |
01-28-2013, 02:34 PM | #14 |
i just finished reading the rule book again just to be sure my part is full legal
the other TDP/ WISEFAB style ones are not because the relocate the the strut. 8.3.2.2. Original suspension design type must remain: Double wishbone, MacPherson strut etc. Suspension relocation brackets that move suspension points or pivots regardless if they are bolt in to the chassis will not be allowed. |
01-27-2013, 11:45 PM | #17 |
the $900 is set as i would rather overprice then underprice this early. but it will more then likley not be even close to that much if i can get my manufaturing cost down (in the USA).
01-28-2013, 05:29 AM | #18 |
The justification for the cost is more then likely that the amount it costs him to have them made is high. If the cost is 300 to have them made, then hes gonna ask 900 for them to make some decent money back.
01-28-2013, 08:16 AM | #19 |
Where did you find a tapered shank to fit s13 and s14 taper (or custom?)? Will you offer both s13 and s14 versions? Will you offer different length shanks to adjust roll center? How much does caster change with each shim? What is the adjustment range for the length of the arm? Will you be making a swaybar to take advantage of the extra wheel clearance provided by this design? thanks.
01-28-2013, 09:37 AM | #20 | |
the shank length that is on there is pretty long already. longer then most of the competion. so i wasnt really planing on it but my ears are always open to what you guys want to see in a product. how much roll center adjustment would you want? Keep in mind this was designed with a drop spindle knuckle in mind. i will be working on that in the next few months you are able to rotate the rod end one half turn with out moving the shims around. turn it another half turn in the same direction and you will have to swap 1 shim over other wise it will bind. the amount of caster change one half turn on the rod end will get you depends on your ride height. rally car?....less movement VIP car? more movement per turn on the rod end. i did not design it with a whole lot of track width change as you are messing with susension geometry angles in the strut. that being said it will go 2 1/4 wider than stock S13 overall. As far as the sway bar, yes. i just finished testing this weekend. works great. it will clear the latest PBM angle kit at full lock with room to spare. and it has the ability to swap center swaybar rates for MUCH cheaper then buying a whole new sway bar. clears sr ka with nismo power brace. and the best part......It bolts up in the stock location soon to come one that clears LS1 Last edited by Bink Industries; 01-28-2013 at 10:20 AM.. Reason: forgot something |
01-28-2013, 12:20 PM | #21 |
Nice, thanks for the answers. I guess I missed the swaybar mentioned in the original post. So the shank will work like SPL's tie rod ends, using spacers above or below to adjust roll center. The only thing I would still worry about is the amount of articulation in that outer spherical, especially with an extended shank there, they bind much sooner than a ball joint. Like you said though, using a knuckle that raises roll center is the better way. I guess testing will prove one way or another on the binding, good luck, and I'm interested in the knuckles
01-28-2013, 12:58 PM | #22 | |
the factory has there ball joint angled the same way.maybe they were on to something it is tilted down to match the angle of knuckle and pointed BACKWARD slightly to acount for the caster angle. some of the competitions FLCA are almost completly maxed out of its articulation range just sitting still and to fix the problem they offer TWO DIFFERANT CONTROL ARMS??? with differant cup angles??? I decieded to just make ONE the right way. I tested these lower control arms at the track this weekend no binding of any kind. |
01-28-2013, 01:12 PM | #23 |
here is a top shot of the arm installed with the clearance. this is full lock (COMPLETLY STOCK KUCKLE) 225 on 18x8 30mm offset
3.75 camber and 10 degrees caster if that makes any differance to you guys. dont mind the tube sticking out that was part of my mock up swaybar. |
01-28-2013, 10:52 AM | #24 |
i am not trying to advertise at ALL
if you guys feel i am please remove this post. i mean no disrespect and am trying to follow the rules. not much of a forums guy I just want to see what you guys think so i can make sure im on the right track. i will be starting on a RLCA prototype and sway bar in the next few weeks. if you guys like the design elements in this arm i would like to continue the trend on the back and trough out the other products i build. |
01-28-2013, 04:39 PM | #25 | |
AFC #1
Any more photos of it installed? Can't see much from that top down shot.
Comments should be taken as Opinions not as Statements of Fact |
01-28-2013, 06:46 PM | #26 | |
and here is two more pictures for you guys. |
01-28-2013, 04:54 PM | #28 | ||
01-28-2013, 06:14 PM | #29 | |
that is really light though. gunna be hard to beat thats for sure. looks like they got the cup angle right and they look like some great tig welds |
01-28-2013, 11:17 AM | #30 |
Trader Rating: (82)
Feedback Score: 82 reviews
You should have priced them at 899 and people would have said this guy is crazy he wants 800 bucks.... It's an advertising gimmick ...
NEED Bolt kits for your car? |
Tags |
flca, major angle, s13 240sx, steering angle |
